[postgis-tickets] [PostGIS] #4515: 00-regress-install doesn't get created legacy regress fails
PostGIS trac at osgeo.org
Sun Oct 6 09:08:48 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 Regarding this issue, I discovered regress is being installed, but for
 some reason, it's installing in the root of my msys:
 C:\ming64gcc81\msys\00-regress-install
 instead of my source folder.  The only thing I override is export
 PGIS_REG_TMPDIR, but winnie overrides that too and doesn't seem to suffer
 from same issue.  The only other significant difference I can think of how
 we are configures is her source folder is on E: drive (separate drive from
 ming/msys environment)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4515#comment:7>
