[postgis-tickets] r17874 - Fix tag issues
Regina Obe lr at pcorp.us
Sun Oct 6 11:57:58 PDT 2019
Author: robe
Date: 2019-10-06 23:57:58 -0700 (Sun, 06 Oct 2019)
New Revision: 17874
   trunk/doc/po/ja/extras_topology.xml.po
   trunk/doc/po/ja/reference.xml.po
   trunk/doc/po/ko_KR/extras_topology.xml.po
   trunk/doc/po/ko_KR/reference.xml.po
   trunk/doc/po/pt_BR/extras_topology.xml.po
   trunk/doc/po/pt_BR/reference.xml.po
Fix tag issues
Modified: trunk/doc/po/ja/extras_topology.xml.po
--- trunk/doc/po/ja/extras_topology.xml.po	2019-10-07 06:40:18 UTC (rev 17873)
+++ trunk/doc/po/ja/extras_topology.xml.po	2019-10-07 06:57:58 UTC (rev 17874)
@@ -1106,8 +1106,8 @@
 "<refpurpose>Takes a topology name and provides summary totals of types of "
 "objects in topology.</refpurpose>"
 msgstr ""
-"トポロジ名を取り、トポロジ内のオブジェクトの型に関する概要の全体を提供しま"
-"す。"
+"<refpurpose>Tトポロジ名を取り、トポロジ内のオブジェクトの型に関する概要の全体を提供しま"
+"す。</refpurpose>"
 #. Tag: funcprototype
 #: extras_topology.xml:430
@@ -1128,8 +1128,8 @@
 "<para>Takes a topology name and provides summary totals of types of objects "
 "in topology.</para>"
 msgstr ""
-"す。"
+"<para>トポロジ名を取り、トポロジ内のオブジェクトの型に関する概要の全体を提供しま"
+"す。</para>"
 #. Tag: para
 #: extras_topology.xml:443 extras_topology.xml:662 extras_topology.xml:800
Modified: trunk/doc/po/ja/reference.xml.po
--- trunk/doc/po/ja/reference.xml.po	2019-10-07 06:40:18 UTC (rev 17873)
+++ trunk/doc/po/ja/reference.xml.po	2019-10-07 06:57:58 UTC (rev 17874)
@@ -70,5 +70,4 @@
 "&reference_constructor; &reference_accessor; &reference_editor; "
 "&reference_output; &reference_operator; &reference_measure; "
 "&reference_sfcgal; &reference_processing; &reference_lrs; "
-"&reference_temporal; &reference_transaction; &reference_misc; "
-"&reference_exception;"
+"&reference_transaction; "
Modified: trunk/doc/po/ko_KR/extras_topology.xml.po
--- trunk/doc/po/ko_KR/extras_topology.xml.po	2019-10-07 06:40:18 UTC (rev 17873)
+++ trunk/doc/po/ko_KR/extras_topology.xml.po	2019-10-07 06:57:58 UTC (rev 17874)
@@ -1068,7 +1068,7 @@
 msgstr ""
-"지형 명칭을 받아 지형 내부에 있는 객체들의 유형 전체의 요약문을 반환합니다."
+"<refpurpose>지형 명칭을 받아 지형 내부에 있는 객체들의 유형 전체의 요약문을 반환합니다.</refpurpose>"
@@ -1089,7 +1089,7 @@
 msgstr ""
+"<para>지형 명칭을 받아 지형 내부에 있는 객체들의 유형 전체의 요약문을 반환합니다.</para>"
 #. Tag: para
Modified: trunk/doc/po/ko_KR/reference.xml.po
--- trunk/doc/po/ko_KR/reference.xml.po	2019-10-07 06:40:18 UTC (rev 17873)
+++ trunk/doc/po/ko_KR/reference.xml.po	2019-10-07 06:57:58 UTC (rev 17874)
@@ -67,3 +67,8 @@
 "&reference_transaction; &reference_version; &reference_guc; "
 "&reference_troubleshooting;"
 msgstr ""
+"&reference_type; &reference_guc; &reference_management; "
+"&reference_constructor; &reference_accessor; &reference_editor; "
+"&reference_output; &reference_operator; &reference_measure; "
+"&reference_sfcgal; &reference_processing; &reference_lrs; "
Modified: trunk/doc/po/pt_BR/extras_topology.xml.po
--- trunk/doc/po/pt_BR/extras_topology.xml.po	2019-10-07 06:40:18 UTC (rev 17873)
+++ trunk/doc/po/pt_BR/extras_topology.xml.po	2019-10-07 06:57:58 UTC (rev 17874)
@@ -1097,8 +1097,8 @@
 msgstr ""
-"Pega um nome de topologia e fornece totais resumidos de tipos dos objetos na "
-"topologia. "
+"<refpurpose>Pega um nome de topologia e fornece totais resumidos de tipos dos objetos na "
+"topologia.</refpurpose>"
@@ -1119,8 +1119,8 @@
 msgstr ""
-"topologia. "
+"<para>Pega um nome de topologia e fornece totais resumidos de tipos dos objetos na "
+"topologia.</para>"
 #. Tag: para
Modified: trunk/doc/po/pt_BR/reference.xml.po
--- trunk/doc/po/pt_BR/reference.xml.po	2019-10-07 06:40:18 UTC (rev 17873)
+++ trunk/doc/po/pt_BR/reference.xml.po	2019-10-07 06:57:58 UTC (rev 17874)
@@ -75,5 +75,4 @@
\ No newline at end of file
