[postgis-tickets] [PostGIS] #4515: 00-regress-install doesn't get created legacy regress fails
PostGIS trac at osgeo.org
Mon Oct 7 13:01:04 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 Okay I'm going to dismiss my issue as user error.
 After trying to compare what is different between my script and winnie's
 script, I tossed my script out and used hers and put back my different
 versions of things.  Seem to work fine. No more errors.  Have no clue what
 was wrong with my script before.
 Also reverting to the 3.0.0beta1 did not help my issue evidentally started
 before then.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4515#comment:10>
