[postgis-tickets] [PostGIS] #4530: upgrade postgis 2.3 to postgis 3.0.0rc1 fails at raster
PostGIS trac at osgeo.org
Mon Oct 7 20:42:20 PDT 2019
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 Is this a new test?
 https://dronie.osgeo.org/postgis/postgis/696/1/2
 /usr/share/postgresql/9.5/contrib/postgis-2.3/rtpostgis_proc_set_search_path.sql
 ERROR: query string argument of EXECUTE is null
 CONTEXT: PL/pgSQL function _add_raster_constraint_extent(name,name,name)
 line 27 at EXECUTE
 PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 104 at
 assignment
 PL/pgSQL function
 addrasterconstraints(name,name,name,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean)
 line 53 at RETURN
 Something went wrong adding raster constraints to upgrade_test:
 make: *** [check] Error 1
 make: Leaving directory `/drone/src/raster/test/regress'
 FAIL: upgrade unpackaged2.3--3.0.0rc1
 I don't remember sing this one.  Then again seems to be erroring on
 install postgis-2.3 before it even gets to the upgrade step.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4530>
