[postgis-tickets] [PostGIS] #4536: Leak in WKB collection parser
PostGIS trac at osgeo.org
Thu Oct 10 00:16:28 PDT 2019
 Reporter:  komzpa   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.0.1
Component:  postgis  |    Version:  2.5.x
 Keywords:           |
 https://oss-fuzz.com/testcase-detail/5727346518130688
 ==1==ERROR: LeakSanitizer: detected memory leaks
 Direct leak of 121472 byte(s) in 3796 object(s) allocated from:
     #0 0x49692d in malloc /src/llvm/projects/compiler-
 rt/lib/asan/asan_malloc_linux.cpp:145:3
     #1 0x6064be in lwcollection_construct_empty
 /src/postgis/liblwgeom/lwcollection.c:101:8
     #2 0x611bf2 in lwcollection_from_wkb_state
 /src/postgis/liblwgeom/lwin_wkb.c:639:22
     #3 0x611c77 in lwcollection_from_wkb_state
 /src/postgis/liblwgeom/lwin_wkb.c:655:10
     #4 0x611c77 in lwcollection_from_wkb_state
     #5 0x611c77 in lwcollection_from_wkb_state
     #6 0x611c77 in lwcollection_from_wkb_state
     #7 0x611c77 in lwcollection_from_wkb_state
     #8 0x611c77 in lwcollection_from_wkb_state
     #9 0x611c77 in lwcollection_from_wkb_state
     #10 0x611c77 in lwcollection_from_wkb_state
     #11 0x611c77 in lwcollection_from_wkb_state
     #12 0x611c77 in lwcollection_from_wkb_state
     #13 0x611c77 in lwcollection_from_wkb_state
     #14 0x611c77 in lwcollection_from_wkb_state
     #15 0x611c77 in lwcollection_from_wkb_state
     #16 0x611c77 in lwcollection_from_wkb_state
     #17 0x611c77 in lwcollection_from_wkb_state
     #18 0x611c77 in lwcollection_from_wkb_state
     #19 0x611c77 in lwcollection_from_wkb_state
     #20 0x611c77 in lwcollection_from_wkb_state
     #21 0x611c77 in lwcollection_from_wkb_state
     #22 0x611c77 in lwcollection_from_wkb_state
     #23 0x611c77 in lwcollection_from_wkb_state
     #24 0x611c77 in lwcollection_from_wkb_state
     #25 0x611c77 in lwcollection_from_wkb_state
     #26 0x611c77 in lwcollection_from_wkb_state
     #27 0x611c77 in lwcollection_from_wkb_state
     #28 0x611c77 in lwcollection_from_wkb_state
     #29 0x611c77 in lwcollection_from_wkb_state
 The following leaks are not necessarily related to the first leak.
 Direct leak of 32 byte(s) in 1 object(s) allocated from:
     #4 0x611eda in lwgeom_from_wkb /src/postgis/liblwgeom/lwin_wkb.c:783:9
     #5 0x4c9d2d in LLVMFuzzerTestOneInput
 /src/postgis/fuzzers/wkb_import_fuzzer.cpp:116:22
     #6 0x51a546 in fuzzer::Fuzzer::ExecuteCallback(unsigned char const*,
 unsigned long) /src/libfuzzer/FuzzerLoop.cpp:556:15
     #7 0x4cb08f in fuzzer::RunOneTest(fuzzer::Fuzzer*, char const*,
 unsigned long) /src/libfuzzer/FuzzerDriver.cpp:292:6
     #8 0x4d8cf2 in fuzzer::FuzzerDriver(int*, char***, int (*)(unsigned
 char const*, unsigned long)) /src/libfuzzer/FuzzerDriver.cpp:774:9
     #9 0x4ca6d7 in main /src/libfuzzer/FuzzerMain.cpp:19:10
     #10 0x7f04a770382f in __libc_start_main /build/glibc-
 LK5gWL/glibc-2.23/csu/libc-start.c:291
     #6 0x611eda in lwgeom_from_wkb /src/postgis/liblwgeom/lwin_wkb.c:783:9
     #7 0x4c9d2d in LLVMFuzzerTestOneInput
     #8 0x51a546 in fuzzer::Fuzzer::ExecuteCallback(unsigned char const*,
     #9 0x4cb08f in fuzzer::RunOneTest(fuzzer::Fuzzer*, char const*,
     #10 0x4d8cf2 in fuzzer::FuzzerDriver(int*, char***, int (*)(unsigned
     #11 0x4ca6d7 in main /src/libfuzzer/FuzzerMain.cpp:19:10
     #12 0x7f04a770382f in __libc_start_main /build/glibc-
 ..... many more lines ...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4536>
