[postgis-tickets] [PostGIS] #4483: Can't upgrade from PostGIS 3.0.0alpha3 to 3.0.0alpha4 or 3.0.0alpha5dev (ST_AsGeoJSON)
PostGIS trac at osgeo.org
Tue Oct 15 00:54:03 PDT 2019
(ST_AsGeoJSON)
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by myon):
 pg_upgradecluster 12 main.old --rename main -m upgrade --old-
 bindir=/var/tmp/postgresql-12-201907221/bin
 The old bin directory is needed so it can actually read the old data
 directory which was using a different catalog version.
 When implementing this I thought extension modules were not necessary for
 dumping the old catalog structure, but that's wrong. We should copy the
 whole bin+lib directories instead.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4483#comment:22>
