[postgis-tickets] r17928 - Fix ST_ConcaveHull under FDW
Raul raul at rmr.ninja
Thu Oct 17 04:10:17 PDT 2019
Author: algunenano
Date: 2019-10-17 04:10:16 -0700 (Thu, 17 Oct 2019)
New Revision: 17928
   branches/2.4/NEWS
   branches/2.4/postgis/Makefile.in
   branches/2.4/postgis/postgis.sql.in
   branches/2.4/raster/rt_pg/Makefile.in
   branches/2.4/raster/rt_pg/rtpostgis.sql.in
References #4546
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2019-10-17 11:09:35 UTC (rev 17927)
+++ branches/2.4/NEWS	2019-10-17 11:10:16 UTC (rev 17928)
@@ -16,6 +16,7 @@
   - #4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)
   - #4536, Fix leak in lwcollection_from_wkb_state (Raúl Marín)
   - #4537, Fix leak in WKT collection parser (Raúl Marín)
+  - #4546, Fix ST_ConcaveHull under FDW (Raúl Marín)
 PostGIS 2.4.8
Modified: branches/2.4/postgis/Makefile.in
--- branches/2.4/postgis/Makefile.in	2019-10-17 11:09:35 UTC (rev 17927)
+++ branches/2.4/postgis/Makefile.in	2019-10-17 11:10:16 UTC (rev 17928)
@@ -211,7 +211,7 @@
 # replace @extschema at . with nothing, this is only used as placeholder for extension install
 %.sql: %.sql.in
 	$(SQLPP) -I../libpgcommon $< | grep -v '^#' | \
-	$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g" > $@
+	$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g;s'SET search_path = @extschema@''g;" > $@
 postgis_upgrade_for_extension.sql: postgis_drop_before.sql postgis_upgrade_for_extension.sql.in postgis_drop_after.sql
 	cat $^ > $@
Modified: branches/2.4/postgis/postgis.sql.in
--- branches/2.4/postgis/postgis.sql.in	2019-10-17 11:09:35 UTC (rev 17927)
+++ branches/2.4/postgis/postgis.sql.in	2019-10-17 11:10:16 UTC (rev 17928)
@@ -5235,7 +5235,7 @@
 	geom := @extschema at .ST_BuildArea(mline);
-	IF GeometryType(geom) != 'POLYGON'
+	IF @extschema at .GeometryType(geom) != 'POLYGON'
 	THEN
 		RAISE EXCEPTION 'Input returns more then a single polygon, try using BdMPolyFromText instead';
 	END IF;
@@ -5243,7 +5243,8 @@
 	RETURN geom;
 END;
-LANGUAGE 'plpgsql' IMMUTABLE STRICT _PARALLEL;
+LANGUAGE 'plpgsql' IMMUTABLE STRICT _PARALLEL
+SET search_path = @extschema@;
 -- SFSQL 1.1
@@ -5280,7 +5281,8 @@
 	RETURN geom;
 END;
 /* Should we include the .sql directly here ? */
 #include "long_xact.sql.in"
@@ -5810,7 +5812,8 @@
 	END;
-  LANGUAGE plpgsql IMMUTABLE STRICT _PARALLEL;
+  LANGUAGE plpgsql IMMUTABLE STRICT _PARALLEL
+  SET search_path = @extschema@;
 CREATE OR REPLACE FUNCTION ST_ConcaveHull(param_geom geometry, param_pctconvex float, param_allow_holes boolean DEFAULT false) RETURNS geometry AS
@@ -5965,6 +5968,7 @@
 	END;
 -- ST_ConcaveHull and Helper functions end here --
Modified: branches/2.4/raster/rt_pg/Makefile.in
--- branches/2.4/raster/rt_pg/Makefile.in	2019-10-17 11:09:35 UTC (rev 17927)
+++ branches/2.4/raster/rt_pg/Makefile.in	2019-10-17 11:10:16 UTC (rev 17928)
@@ -101,7 +101,7 @@
 %.sql: %.sql.in
 	$(SQLPP) -I../../postgis/ -I../../ $< | grep -v '^#' | \
-	$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/rtpostgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g" > $@
+	$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/rtpostgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g;s'SET search_path = @extschema@''g;" > $@
 rtpostgis_for_extension.sql: rtpostgis.sql.in
Modified: branches/2.4/raster/rt_pg/rtpostgis.sql.in
--- branches/2.4/raster/rt_pg/rtpostgis.sql.in	2019-10-17 11:09:35 UTC (rev 17927)
+++ branches/2.4/raster/rt_pg/rtpostgis.sql.in	2019-10-17 11:10:16 UTC (rev 17928)
@@ -2364,7 +2364,8 @@
 		RETURN @extschema at ._ST_asraster(g, scale_x, scale_y, NULL, NULL, $3, $4, $5, NULL, NULL, ul_x, ul_y, skew_x, skew_y, $6);
 	END;
-	$$ LANGUAGE 'plpgsql' IMMUTABLE _PARALLEL;
+	$$ LANGUAGE 'plpgsql' IMMUTABLE _PARALLEL
 CREATE OR REPLACE FUNCTION st_asraster(
 	geom geometry,
@@ -7444,7 +7445,8 @@
 		RETURN  @extschema at ._add_raster_constraint(cn, sql);
 	END;
 	$$ LANGUAGE 'plpgsql' VOLATILE STRICT
-	COST 100;
+	COST 100
 CREATE OR REPLACE FUNCTION _drop_raster_constraint_coverage_tile(rastschema name, rasttable name, rastcolumn name)
 	RETURNS boolean AS
@@ -8801,7 +8803,8 @@
   RETURN;
 END;
-$$ LANGUAGE 'plpgsql' STABLE STRICT;
+$$ LANGUAGE 'plpgsql' STABLE STRICT
 -- ST_CreateOverview
