[postgis-tickets] r17963 - Undo quiet option change
Raul raul at rmr.ninja
Fri Oct 18 07:30:22 PDT 2019
Author: algunenano
Date: 2019-10-18 07:30:22 -0700 (Fri, 18 Oct 2019)
New Revision: 17963
   branches/2.3/regress/dump_expected
   branches/2.3/regress/isvaliddetail_expected
   branches/2.3/regress/run_test.pl
References #4549
Modified: branches/2.3/regress/dump_expected
--- branches/2.3/regress/dump_expected	2019-10-18 14:27:28 UTC (rev 17962)
+++ branches/2.3/regress/dump_expected	2019-10-18 14:30:22 UTC (rev 17963)
@@ -16,4 +16,6 @@
 t9|{5,1}|POLYGON((0 0,0 9,9 9,9 0,0 0),(5 5,5 6,6 6,5 5))
 t10|0
 t11|0
+BEGIN
 t12|POLYGON((0 0,0 1,1 1,1 0,0 0))|POLYGON((0 0,0 1,1 1,1 0,0 0))
+COMMIT
Modified: branches/2.3/regress/isvaliddetail_expected
--- branches/2.3/regress/isvaliddetail_expected	2019-10-18 14:27:28 UTC (rev 17962)
+++ branches/2.3/regress/isvaliddetail_expected	2019-10-18 14:30:22 UTC (rev 17963)
@@ -8,4 +8,6 @@
 6|t||
 6s|t
 5r|Valid Geometry
+BEGIN
 7|f|Self-intersection|POINT(70 400)
+COMMIT
Modified: branches/2.3/regress/run_test.pl
--- branches/2.3/regress/run_test.pl	2019-10-18 14:27:28 UTC (rev 17962)
+++ branches/2.3/regress/run_test.pl	2019-10-18 14:30:22 UTC (rev 17963)
@@ -725,7 +725,7 @@
           . " -v \"scriptdir=$scriptdir\""
           . " -v \"regdir=$REGDIR\""
           . " -v \"schema=$OPT_SCHEMA.\""
-          . " -tXAq $DB < $sql > $outfile 2>&1";
+          . " -tXA $DB < $sql > $outfile 2>&1";
 	my $rv = system($cmd);
 	# Check for ERROR lines
