[postgis-tickets] [PostGIS] #4554: winnie failing with role "-f" does not exist
PostGIS trac at osgeo.org
Sat Oct 19 16:48:37 PDT 2019
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.1.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 https://winnie.postgis.net:444/job/PostGIS_EDB_Regress_winnie/10012/consoleFull
 PostgreSQL 12.0, compiled by Visual C++ build 1914, 64-bit
   Postgis 3.1.0dev - r17971 - 2019-10-18 18:03:52
   scripts 3.1.0dev r17971
   GEOS: 3.8.0-CAPI-1.13.1
   PROJ: Rel. 5.2.0, September 15th, 2018
 Running tests
  ../loader/Point .... failed (wkt testdiff expected obtained:
 /projects/postgis/tmp/3.1.0dev_pg12_geos3.8.0_gdal2.4.2w64/test_1_diff)
 --- ../loader/Point-w.select.expected   2019-10-14 01:11:13.655425800
 -0400
 +++ /projects/postgis/tmp/3.1.0dev_pg12_geos3.8.0_gdal2.4.2w64/test_1_out
 2019-10-18 14:18:51.449574800 -0400
 @@ -1,3 +1 @@
 -POINT(0 1)
 -POINT(9 -1)
 -POINT(9 -1)
 +psql: error: could not connect to server: FATAL:  role "-f" does not
 exist
  ../loader/PointM ... failed ( wkt test: running shp2pgsql output:
 /projects/postgis/tmp/3.1.0dev_pg12_geos3.8.0_gdal2.4.2w64/loader.err)
 SET
 SET
 BEGIN
 psql:E:/jenkins/postgis/tmp/3.1.0dev_pg12_geos3.8.0_gdal2.4.2w64/loader.out:4:
 ERROR:  relation "loadedshp" already exists
 This started between r17954 and r17971
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4554>
