[postgis-tickets] [PostGIS] #4556: st_asmvtgeom sometimes produces leaking polygons (postgis 3.0)
PostGIS trac at osgeo.org
Tue Oct 22 06:26:55 PDT 2019
 Reporter:  anneb    |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:
 Keywords:           |
 st_AsMVTgeom in postgis 3.0 built with wagyu 0.43 sometimes produces
 leaking polygons.
 if a polygon is the surface of a circular road, the output polygon of
 st_asmvtgeom sometimes changes to a filled circle at lower (zoomed-out)
 zoom levels.
 I am attaching an example. Unfortunately I did not yet succeed to reduce
 the problem to a small data example.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4556>
