[postgis-tickets] r17989 - Fix version numbers that got reset to old
Regina Obe lr at pcorp.us
Wed Oct 23 03:46:03 PDT 2019
Author: robe
Date: 2019-10-23 15:46:02 -0700 (Wed, 23 Oct 2019)
New Revision: 17989
   trunk/doc/po/de/release_notes.xml.po
   trunk/doc/po/ja/release_notes.xml.po
Modified: trunk/doc/po/de/release_notes.xml.po
--- trunk/doc/po/de/release_notes.xml.po	2019-10-21 05:23:23 UTC (rev 17988)
+++ trunk/doc/po/de/release_notes.xml.po	2019-10-23 22:46:02 UTC (rev 17989)
@@ -6,8 +6,8 @@
 msgid ""
 msgstr ""
 "Project-Id-Version: PostGIS\n"
-"Report-Msgid-Bugs-To: http://bugs.kde.org\n"
-"POT-Creation-Date: 2019-10-18 12:22+0000\n"
+"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
+"POT-Creation-Date: 2019-10-23 20:58+0000\n"
 "PO-Revision-Date: 2019-03-11 09:32+0000\n"
 "Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
 "Language-Team: German (http://www.transifex.com/postgis/postgis/language/"
@@ -34,13 +34,13 @@
 #: release_notes.xml:7
 #, fuzzy, no-c-format
 msgid "Release 3.0.0"
-msgstr "Release 2.0.0"
+msgstr "Release 3.0.0"
 #. Tag: para
 #: release_notes.xml:8
 msgid "Release date: 2019/10/20"
-msgstr "Freigabedatum: 2017/07/01"
+msgstr "Freigabedatum: 2019/10/20"
 #. Tag: para
 #: release_notes.xml:9
Modified: trunk/doc/po/ja/release_notes.xml.po
--- trunk/doc/po/ja/release_notes.xml.po	2019-10-21 05:23:23 UTC (rev 17988)
+++ trunk/doc/po/ja/release_notes.xml.po	2019-10-23 22:46:02 UTC (rev 17989)
@@ -5,8 +5,8 @@
 msgid ""
 msgstr ""
 "PO-Revision-Date: 2018-09-26 00:41+0000\n"
 "Last-Translator: TERAMOTO Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese (http://www.transifex.com/postgis/postgis/language/"
@@ -33,13 +33,13 @@
-msgstr "リリース 2.0.0"
+msgstr "リリース 3.0.0"
 #. Tag: para
-msgstr "リリース日: 2019/10/08"
+msgstr "リリース日: 2019/10/20"
 #. Tag: para
@@ -7243,7 +7243,7 @@
 #, no-c-format
 msgid ""
 "This is a bug fix release, addressing issues that have been filed since the "
-"2.0.0 release."
+"2.0.1 release."
 msgstr ""
 "この版は誤り訂正版です。2.0.0版以降に送られた問題の処理が行われました。"
