[postgis-tickets] [PostGIS] #4538: ST_Difference(g1, g2) throws lwgeom_difference: GEOS Error: TopologyException: found non-noded intersection
PostGIS trac at osgeo.org
Fri Oct 25 08:13:32 PDT 2019
#4538: ST_Difference(g1,g2) throws lwgeom_difference: GEOS Error:
  Reporter:  laopsahl  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS GEOS
 Component:  postgis   |    Version:  2.5.x
Resolution:            |   Keywords:
Comment (by mdavis):
 This a classic case where nearly co-incident segments produce a robustness
 issue during overlay.  The first one fails in JTS too.
 There was some work done on numerical robustness in 3.8, but it clearly
 was not a general solution to the robustness problem.
 There is a new approach to overlay in the works which handles cases like
 this (and this is a very good test example).  Until that lands, the only
 options is the usual one of reducing precision by snapping to a grid.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4538#comment:2>
