[postgis-tickets] [PostGIS] #4562: Add git browse capabilities to PostGIS Trac
PostGIS trac at osgeo.org
Sun Oct 27 07:32:50 PDT 2019
 Reporter:  strk     |      Owner:  robe
     Type:  task     |     Status:  assigned
 Priority:  medium   |  Milestone:  Management 2.0
Component:  website  |    Version:
 Keywords:           |
 The repository "git" has been added.
     You should now run trac-admin "/var/www/trac/env/postgis" repository
 resync "git" to synchronize Trac with the repository.
     You should also set up a post-commit hook on the repository to call
 trac-admin "/var/www/trac/env/postgis" changeset added "git" $REV for each
 committed changeset. See the documentation for more information.
 NOTE: the trac-admin call failed for me with:
 Error: Unable to get database connection within 0 seconds.
 (OperationalError: fe_sendauth: no password supplied)
 I'd have to learn Trac again after the migration to lxc...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4562>
