[postgis-tickets] [PostGIS] #4559: [raster] PG 13 / GDAL 3.1: rt_gdalwarp regress failing
PostGIS trac at osgeo.org
Mon Oct 28 15:21:08 PDT 2019
  Reporter:  Algunenano  |      Owner:  Bborie Park
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.1.0
 Component:  raster      |    Version:  trunk
Resolution:              |   Keywords:
Comment (by robe):
 I'm seeing it on debbie's dev runs for PG 13, this is with
 https://debbie.postgis.net/view/PostgreSQL/job/PostGIS_Regress_PGDEV_Weekly/10546/console
  -------------- Compiler Info -------------
   C compiler:           gcc -std=gnu99 -g -O2 -fno-math-errno -fno-signed-
 zeros
   C++ compiler (Wagyu): gcc -std=c++11 -x c++
   CPPFLAGS:
 -I/var/lib/jenkins/workspace/geos/rel-3.8w64/include
 -I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c
   LDFLAGS:               -lm
   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
  -------------- Additional Info -------------
   Interrupt Tests:   DISABLED use: --with-interrupt-tests to enable
  -------------- Dependencies --------------
   GEOS config:          /var/lib/jenkins/workspace/geos/rel-3.8w64/bin
 /geos-config
   GEOS version:         3.9.0dev
   GDAL config:          /var/lib/jenkins/workspace/gdal/rel-2.4w64/bin
 /gdal-config
   GDAL version:         2.4.3
   SFCGAL config:        /usr/bin/sfcgal-config
   SFCGAL version:       1.3.7
   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg13w64/bin/pg_config
   PostgreSQL version:   PostgreSQL 13devel
   PROJ4 version:        62
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.4
   JSON-C support:       yes
   protobuf support:     yes
   protobuf-c version:   1003002
   PCRE support:         no
   Perl:                 /usr/bin/perl
   Wagyu:                yes
  --------------- Extensions ---------------
   PostGIS Raster:                     enabled
   PostGIS Topology:                   enabled
   SFCGAL support:                     enabled
   Address Standardizer support:       disabled
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:     /usr/share/xml/docbook/stylesheet/docbook-xsl
   dblatex:              /usr/bin/dblatex
   convert:              /usr/bin/convert
   mathml2.dtd:          /usr/share/xml/schema/w3c/mathml/dtd/mathml2.dtd
  rt_gdalwarp .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/branches/3.1/tmp/3_1_pg13w64/test_52_diff)
 --- rt_gdalwarp_expected        2019-10-28 21:42:58.098356962 +0000
 /var/lib/jenkins/workspace/postgis/regress_pgdev/branches/3.1/tmp/3_1_pg13w64/test_52_out
 2019-10-28 21:50:33.970353820 +0000
 @@ -7,27 +7,48 @@
  NOTICE:  Raster has default geotransform. Adjusting metadata for use of
 GDAL Warp API
  NOTICE:  Values must be provided for both X and Y when specifying the
 scale.  Returning original raster
 +NOTICE:  SRID value 2139062143 > SRID_MAXIMUM converted to 999346
  0.0|||||||||||||
 0.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 0.10|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.11|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 0.12|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600009.000|t|t|t
 0.13|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500100.000|600950.000|t|t|t
 -0.14|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4559#comment:2>
