[postgis-tickets] [PostGIS] #4559: [raster] PG 13 / GDAL 3.1: rt_gdalwarp regress failing
PostGIS trac at osgeo.org
Tue Oct 29 04:39:06 PDT 2019
  Reporter:  Algunenano  |      Owner:  Bborie Park
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.1.0
 Component:  raster      |    Version:  trunk
Resolution:              |   Keywords:
Comment (by Algunenano):
 I've updated my local gdal to master and it passes the tests:
 ------------ Dependencies --------------
   GEOS config:          /usr/bin/geos-config
   GEOS version:         3.9.0dev
   GDAL config:          /usr/bin/gdal-config
   GDAL version:         3.1.0
   SFCGAL config:        /usr/bin/sfcgal-config
   SFCGAL version:       1.3.7
   PostgreSQL config:    /usr/bin/pg_config
   PostgreSQL version:   PostgreSQL 12.0
   PROJ4 version:        62
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.9
   JSON-C support:       yes
   protobuf support:     yes
   protobuf-c version:   1003002
   PCRE support:         yes
   Perl:                 /usr/bin/perl
   Wagyu:                yes
 So it looks like something related to PG13.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4559#comment:4>
