[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 368d524d1118b9c6921b14cf74d19cc801e3cc5e
Wed Oct 30 02:14:45 PDT 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
       via  368d524d1118b9c6921b14cf74d19cc801e3cc5e (commit)
       via  f98c360da8df4af93f1516546360afbb77e872ff (commit)
       via  ac76be3953a2c70b7ff0bce8838b711845a3ffd4 (commit)
      from  191568eaf59c60c89e229ad3f09efcc7c41887e7 (commit)
revisions in full, below.
commit 368d524d1118b9c6921b14cf74d19cc801e3cc5e
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Oct 30 09:59:51 2019 +0100
    [run_test.pl] Use postgis_lib_revision() when available
diff --git a/regress/run_test.pl b/regress/run_test.pl
index ccbfea2..5bf3227 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -416,14 +416,15 @@ if ( $OPT_DUMPRESTORE )
 my $geosver =  sql("select postgis_geos_version()");
 my $projver = sql("select postgis_proj_version()");
-# TODO: call postgis_lib_revision() instead of postgis_svn_version
-#       if $libver >= 3.1.0
-my $librev = sql("select postgis_svn_version()");
 my $libbuilddate = sql("select postgis_lib_build_date()");
 my $pgsqlver = sql("select version()");
 my $gdalver = sql("select postgis_gdal_version()") if $OPT_WITH_RASTER;
 my $sfcgalver = sql("select postgis_sfcgal_version()") if $OPT_WITH_SFCGAL;
 my $scriptver = sql("select postgis_scripts_installed()");
+# postgis_lib_revision was introduced in 3.1.0
+my $librev = semver_lessthan($scriptver, "3.1.0") ?
+							sql("select postgis_svn_version()") :
+							sql("select postgis_lib_revision()");
 my $raster_scriptver = sql("select postgis_raster_scripts_installed()")
   if ( $OPT_WITH_RASTER );
commit f98c360da8df4af93f1516546360afbb77e872ff
Date:   Wed Oct 30 09:47:45 2019 +0100
    Drop svn references from revision reading script and docs
    [ci skip]
diff --git a/liblwgeom/cunit/README b/liblwgeom/cunit/README
index 978653c..dc6bbca 100644
--- a/liblwgeom/cunit/README
+++ b/liblwgeom/cunit/README
@@ -80,7 +80,7 @@ Add a new line for your test:
 	PG_ADD_TEST(<your test function name>);
-The tests will be run in the order they appear in the list.
+The tests will be run in the order they appear in the list.
 CU_TEST_INFO_NULL must always be the last entry.
 2.3 Add any necessary init / cleanup code.
@@ -102,8 +102,8 @@ Do the following steps to create a whole new test suite (new .c file).
 3.1 Create the file.
-Create the new file (remember to add to svn as well).  The naming convention
-is cu_<suite name>.c.
+Create the new file (remember to add to repository as well).
+The naming convention is cu_<suite name>.c.
 Make sure to import:
diff --git a/utils/repo_revision.pl b/utils/repo_revision.pl
index cceeb2e..4d4f243 100755
--- a/utils/repo_revision.pl
+++ b/utils/repo_revision.pl
@@ -11,7 +11,7 @@ my $rev_file = $top_srcdir.'/postgis_revision.h';
 my $target = 'local';
 $target = $ARGV[0] if $ARGV[0];
-# Read the svn revision number
+# Read the revision number
 my $rev = &read_rev($target);
 # Write it
@@ -31,7 +31,7 @@ sub read_rev_git {
   # TODO: test on old systems, I think I saw some `which`
   #       implementations returning "nothing found" or something
-  #       like that, making the later if ( ! $svn_exe ) always false
+  #       like that, making the later if ( ! $git_exe ) always false
   my $git_exe = `which git`;
   if ( ! $git_exe ) {
commit ac76be3953a2c70b7ff0bce8838b711845a3ffd4
Date:   Wed Oct 30 09:46:56 2019 +0100
    [winnie] Drop svn references from winnie recipe
    [ci skip]
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 0b31ae6..3113e66 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -74,7 +74,7 @@ export PATHOLD=$PATH
 WEB=/home/www/postgis/htdocs
 DWN=${WEB}/download
-export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin:/c/ming${OS_BUILD}}${GCC_TYPE}/svn"
+export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin"
 #export PG_VER=9.2beta2
 echo PATH BEFORE: $PATH
@@ -100,13 +100,12 @@ export REL_PGVER=${PG_VER//./} #strip the period
 export RELDIR=${PROJECTS}/postgis/builds/${POSTGIS_MINOR_VER}
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}${GCC_TYPE}
 export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PCRE_VER=8.33
+export PCRE_VER=8.33
 #PATH="${PGPATH}/bin:${PGPATH}/lib:${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gtkw${OS_BUILD}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
 #echo PATH AFTER: $PATH
 outdir="${RELDIR}/${RELVERDIR}"
 package="${RELDIR}/${RELVERDIR}.zip"
 verfile="${RELDIR}/${RELVERDIR}/version.txt"
-#svnurl="http://svn.osgeo.org/postgis/trunk"
 rm -rf $outdir
 rm $package
 mkdir -p $outdir
@@ -206,10 +205,6 @@ cp doc/*_comments.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MIN
 cp postgis/*.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 cp raster/rt_pg/*.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 cp utils/*.pl ${RELDIR}/${RELVERDIR}/utils
-#add extras
-#svn export "${svnurl}/extras" ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}/extras
-#cp raster/rt_pg/rtpostgis.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
-#cp raster/rt_pg/rtpostgis_upgrade_20_minor.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 cp raster/loader/.libs/raster2pgsql.exe ${RELDIR}/${RELVERDIR}/bin
 cp liblwgeom/.libs/*.dll ${RELDIR}/${RELVERDIR}/bin
@@ -254,4 +249,4 @@ cd ${RELDIR}
 zip -r $package ${RELVERDIR}
 #scp $package robe at www.refractions.net:${DWN}/${REL_PGVER}/buildbot/${RELVERDIR}.zip
 cp $package ${PROJECTS}/postgis/win_web/download/windows/pg${REL_PGVER}/buildbot
-cd ${POSTGIS_SRC}
\ No newline at end of file
+cd ${POSTGIS_SRC}
Summary of changes:
 ci/winnie/package_postgis.sh | 11 +++--------
 liblwgeom/cunit/README       |  6 +++---
 regress/run_test.pl          |  7 ++++---
 utils/repo_revision.pl       |  4 ++--
 4 files changed, 12 insertions(+), 16 deletions(-)
hooks/post-receive
