[postgis-tickets] [PostGIS] #4556: st_asmvtgeom sometimes produces leaking polygons (wagyu)
PostGIS trac at osgeo.org
Thu Oct 31 05:39:06 PDT 2019
  Reporter:  anneb    |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.1
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by Raul Marin <git@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"570fbdb10de728e56957f3b7b449ac9532a53a47/git" 570fbdb/git]:
 #!CommitTicketReference repository="git"
 revision="570fbdb10de728e56957f3b7b449ac9532a53a47"
 Fix oversimplification of polygon inner rings
 This also adapts a MVT test which is checking whether it crashes with an
 input or not. Since the exact output depends on the backend
 (GEOS vs wagyu), we just ensure the input passes through the function.
 Closes #4568
 Closes #4556
 Closes https://github.com/postgis/postgis/pull/504
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4556#comment:5>
