[postgis-tickets] [PostGIS] #4503: Speed up the calculation of cartesian bbox
PostGIS trac at osgeo.org
Fri Sep 6 08:47:39 PDT 2019
 Reporter:  Algunenano   |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 3.0.0
Component:  postgis      |    Version:  trunk
 Keywords:               |
 After fixing several functions not updating the bbox of the output
 geometry (ST_RemoveRepeatedPoints, ST_Simplify and ST_SnapToGrid) those
 functions have received an important performance impact; to the point
 where they might spend more time calculating the bbox than doing the
 actual work; e.g.:
    - 97.47% ST_RemoveRepeatedPoints
       + 32.26% lwgeom_calculate_gbox_cartesian
       + 23.72% lwgeom_remove_repeated_points_in_place
       + 22.67% heap_tuple_untoast_attr
       + 16.47% gserialized2_from_lwgeom
       + 2.31% lwgeom_from_gserialized2
 I've made some improvements to the lwgeom_calculate_gbox_cartesian
 function to improve it's performance.
 PR in https://github.com/postgis/postgis/pull/475
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4503>
