[postgis-tickets] r17821 - Speed up ST_Simplify
Raul raul at rmr.ninja
Tue Sep 24 03:58:30 PDT 2019
Author: algunenano
Date: 2019-09-24 03:58:30 -0700 (Tue, 24 Sep 2019)
New Revision: 17821
   trunk/NEWS
   trunk/liblwgeom/cunit/cu_misc.c
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/liblwgeom_internal.h
   trunk/liblwgeom/lwgeom.c
   trunk/liblwgeom/lwgeom_geos_split.c
   trunk/liblwgeom/measures.c
   trunk/liblwgeom/ptarray.c
   trunk/postgis/lwgeom_functions_analytic.c
Closes #4510
Closes https://github.com/postgis/postgis/pull/480
Modified: trunk/NEWS
--- trunk/NEWS	2019-09-24 10:45:43 UTC (rev 17820)
+++ trunk/NEWS	2019-09-24 10:58:30 UTC (rev 17821)
@@ -16,6 +16,7 @@
   - #4505, Speed up conversion of geometries to/from GEOS (Dan Baston)
   - #4507, Use GEOSMakeValid and GEOSBuildArea for GEOS 3.8+ (Dan Baston)
   - #4491, Speed up ST_RemoveRepeatedPoints (Raúl Marín)
+  - #4510, Speed up ST_Simplify (Raúl Marín)
 PostGIS 3.0.0alpha4
 2019/08/10
Modified: trunk/liblwgeom/cunit/cu_misc.c
--- trunk/liblwgeom/cunit/cu_misc.c	2019-09-24 10:45:43 UTC (rev 17820)
+++ trunk/liblwgeom/cunit/cu_misc.c	2019-09-24 10:58:30 UTC (rev 17821)
@@ -62,6 +62,14 @@
 	lwgeom_free(geom);
 	lwgeom_free(geom2d);
 	lwfree(wkt_out);
+	geom = lwgeom_from_wkt("POLYGON((0 0,1 1,1 3,0 4,-2 3,-1 1,0 0))", LW_PARSER_CHECK_NONE);
+	geom2d = lwgeom_simplify(geom, 1, LW_FALSE);
+	wkt_out = lwgeom_to_ewkt(geom2d);
+	CU_ASSERT_STRING_EQUAL("POLYGON((0 0,0 4,-2 3,0 0))", wkt_out);
+	lwgeom_free(geom);
+	lwgeom_free(geom2d);
+	lwfree(wkt_out);
 static void test_misc_count_vertices(void)
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2019-09-24 10:45:43 UTC (rev 17820)
+++ trunk/liblwgeom/liblwgeom.h.in	2019-09-24 10:58:30 UTC (rev 17821)
@@ -1265,7 +1265,6 @@
 /* general utilities 2D */
 extern double  distance2d_pt_pt(const POINT2D *p1, const POINT2D *p2);
-extern double  distance2d_pt_seg(const POINT2D *p, const POINT2D *A, const POINT2D *B);
 extern double  distance2d_sqr_pt_seg(const POINT2D *p, const POINT2D *A, const POINT2D *B);
 extern LWGEOM* lwgeom_closest_line(const LWGEOM *lw1, const LWGEOM *lw2);
 extern LWGEOM* lwgeom_furthest_line(const LWGEOM *lw1, const LWGEOM *lw2);
@@ -1362,7 +1361,7 @@
 extern void lwgeom_reverse_in_place(LWGEOM *lwgeom);
 extern void lwgeom_force_clockwise(LWGEOM *lwgeom);
 extern void lwgeom_longitude_shift(LWGEOM *lwgeom);
-extern void lwgeom_simplify_in_place(LWGEOM *igeom, double dist, int preserve_collapsed);
+extern int lwgeom_simplify_in_place(LWGEOM *igeom, double dist, int preserve_collapsed);
 extern void lwgeom_affine(LWGEOM *geom, const AFFINE *affine);
 extern void lwgeom_scale(LWGEOM *geom, const POINT4D *factors);
 extern int lwgeom_remove_repeated_points_in_place(LWGEOM *in, double tolerance);
Modified: trunk/liblwgeom/liblwgeom_internal.h
--- trunk/liblwgeom/liblwgeom_internal.h	2019-09-24 10:45:43 UTC (rev 17820)
+++ trunk/liblwgeom/liblwgeom_internal.h	2019-09-24 10:58:30 UTC (rev 17821)
@@ -210,7 +210,7 @@
  * @param minpts minimum number of points to retain, if possible.
-void ptarray_simplify_in_place(POINTARRAY *pa, double epsilon, uint32_t minpts);
+void ptarray_simplify_in_place(POINTARRAY *pa, double tolerance, uint32_t minpts);
 * The possible ways a pair of segments can interact. Returned by lw_segment_intersects
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c	2019-09-24 10:45:43 UTC (rev 17820)
+++ trunk/liblwgeom/lwgeom.c	2019-09-24 10:58:30 UTC (rev 17821)
@@ -1711,18 +1711,19 @@
-void
+int
 lwgeom_simplify_in_place(LWGEOM *geom, double epsilon, int preserve_collapsed)
+	int modified = LW_FALSE;
 	switch (geom->type)
 		/* No-op! Cannot simplify points or triangles */
 		case POINTTYPE:
-			return;
+			return modified;
 		case TRIANGLETYPE:
 			if (preserve_collapsed)
-				return;
+				return modified;
 			LWTRIANGLE *t = lwgeom_as_lwtriangle(geom);
 			POINTARRAY *pa = t->points;
 			ptarray_simplify_in_place(pa, epsilon, 0);
@@ -1729,13 +1730,17 @@
 			if (pa->npoints < 3)
 				pa->npoints = 0;
+				modified = LW_TRUE;
+			break;
 		case LINETYPE:
 			LWLINE *g = (LWLINE*)(geom);
 			POINTARRAY *pa = g->points;
+			uint32_t in_npoints = pa->npoints;
 			ptarray_simplify_in_place(pa, epsilon, 2);
+			modified = in_npoints != pa->npoints;
 			/* Invalid output */
 			if (pa->npoints == 1 && pa->maxpoints > 1)
@@ -1771,12 +1776,20 @@
 				/* Skip zero'ed out rings */
 				if(!pa)
 					continue;
 				ptarray_simplify_in_place(pa, epsilon, minpoints);
+				modified |= in_npoints != pa->npoints;
 				/* Drop collapsed rings */
 				if(pa->npoints < 4)
-					ptarray_free(pa);
-					continue;
+					/* Any ring deeper than this one is, by OGR definition, smaller
+					 * so we drop them all */
+					for (; i < g->nrings; i++)
+						pa = g->rings[i];
+						ptarray_free(pa);
+					break;
 				g->rings[j++] = pa;
@@ -1797,7 +1810,7 @@
 				LWGEOM *g = col->geoms[i];
 				if (!g) continue;
-				lwgeom_simplify_in_place(g, epsilon, preserve_collapsed);
+				modified |= lwgeom_simplify_in_place(g, epsilon, preserve_collapsed);
 				/* Drop zero'ed out geometries */
 				if(lwgeom_is_empty(g))
@@ -1816,7 +1829,12 @@
 			break;
-	return;
+	if (modified)
+		lwgeom_drop_bbox(geom);
+	return modified;
 LWGEOM* lwgeom_simplify(const LWGEOM *igeom, double dist, int preserve_collapsed)
Modified: trunk/liblwgeom/lwgeom_geos_split.c
--- trunk/liblwgeom/lwgeom_geos_split.c	2019-09-24 10:45:43 UTC (rev 17820)
+++ trunk/liblwgeom/lwgeom_geos_split.c	2019-09-24 10:58:30 UTC (rev 17821)
@@ -209,7 +209,7 @@
 lwline_split_by_point_to(const LWLINE* lwline_in, const LWPOINT* blade_in,
                          LWMLINE* v)
-	double mindist = -1;
+	double mindist_sqr = -1;
 	POINT4D pt, pt_projected;
 	POINT4D p1, p2;
 	POINTARRAY *ipa = lwline_in->points;
@@ -238,23 +238,28 @@
 	for ( i = 0; i < nsegs; i++ )
 		getPoint4d_p(ipa, i+1, &p2);
-		double dist;
-		dist = distance2d_pt_seg((POINT2D*)&pt, (POINT2D*)&p1, (POINT2D*)&p2);
-		LWDEBUGF(4, " Distance of point %g %g to segment %g %g, %g %g: %g", pt.x, pt.y, p1.x, p1.y, p2.x, p2.y, dist);
-		if (i==0 || dist < mindist )
+		double dist_sqr = distance2d_sqr_pt_seg((POINT2D *)&pt, (POINT2D *)&p1, (POINT2D *)&p2);
+		LWDEBUGF(4, "Distance (squared) of point %g %g to segment %g %g, %g %g: %g",
+				 pt.x, pt.y,
+				 p1.x, p1.y,
+				 p2.x, p2.y,
+				 dist_sqr);
+		if (i == 0 || dist_sqr < mindist_sqr)
-			mindist = dist;
+			mindist_sqr = dist_sqr;
 			seg=i;
-			if ( mindist == 0.0 ) break; /* can't be closer than ON line */
+			if (mindist_sqr == 0.0)
+				break; /* can't be closer than ON line */
 		p1 = p2;
 	LWDEBUGF(3, "Closest segment: %d", seg);
-	LWDEBUGF(3, "mindist: %g", mindist);
+	LWDEBUGF(3, "mindist: %g", mindist_sqr);
 	/* No intersection */
-	if ( mindist > 0 ) return 0;
+	if (mindist_sqr > 0)
+		return 0;
 	/* empty or single-point line, intersection on boundary */
 	if ( seg == UINT32_MAX ) return 1;
Modified: trunk/liblwgeom/measures.c
--- trunk/liblwgeom/measures.c	2019-09-24 10:45:43 UTC (rev 17820)
+++ trunk/liblwgeom/measures.c	2019-09-24 10:58:30 UTC (rev 17821)
@@ -2403,22 +2403,21 @@
 	return hypot(hside, vside);
+/* return distance squared, useful to avoid sqrt calculations */
 double
-distance2d_pt_seg(const POINT2D *p, const POINT2D *A, const POINT2D *B)
+distance2d_sqr_pt_seg(const POINT2D *C, const POINT2D *A, const POINT2D *B)
-	double r, s;
 	/*if start==end, then use pt distance */
 	if ((A->x == B->x) && (A->y == B->y))
-		return distance2d_pt_pt(p, A);
+		return distance2d_sqr_pt_pt(C, A);
 	 * otherwise, we use comp.graphics.algorithms
 	 * Frequently Asked Questions method
-	 *  (1)     	      AC dot AB
+	 *  (1)     	AC dot AB
 	 *         r = ---------
-	 *               ||AB||^2
+	 *              ||AB||^2
 	 *	r has the following meaning:
 	 *	r=0 P = A
 	 *	r=1 P = B
@@ -2427,13 +2426,17 @@
 	 *	0<r<1 P is interior to AB
-	r = ((p->x - A->x) * (B->x - A->x) + (p->y - A->y) * (B->y - A->y)) /
-	    ((B->x - A->x) * (B->x - A->x) + (B->y - A->y) * (B->y - A->y));
+	double ba_x = (B->x - A->x);
+	double ba_y = (B->y - A->y);
+	double ab_length_sqr = (ba_x * ba_x + ba_y * ba_y);
+	double ca_x = (C->x - A->x);
+	double ca_y = (C->y - A->y);
+	double dot_ac_ab = (ca_x * ba_x + ca_y * ba_y);
-	if (r < 0)
-	if (r > 1)
-		return distance2d_pt_pt(p, B);
+	if (dot_ac_ab <= 0)
+	if (dot_ac_ab >= ab_length_sqr)
+		return distance2d_sqr_pt_pt(C, B);
 	 * (2)
@@ -2445,45 +2448,12 @@
-	s = ((A->y - p->y) * (B->x - A->x) - (A->x - p->x) * (B->y - A->y)) /
+	double s_numerator = ca_x * ba_y - ca_y * ba_x;
-	return FP_ABS(s) * sqrt((B->x - A->x) * (B->x - A->x) + (B->y - A->y) * (B->y - A->y));
+	/* Distance = (s_num / ab) * (s_num / ab) * ab == s_num * s_num / ab) */
+	return s_numerator * s_numerator / ab_length_sqr;
-/* return distance squared, useful to avoid sqrt calculations */
-double
-distance2d_sqr_pt_seg(const POINT2D *p, const POINT2D *A, const POINT2D *B)
-	double r, s;
-	if ((A->x == B->x) && (A->y == B->y))
-		return distance2d_sqr_pt_pt(p, A);
-	if (r < 0)
-	if (r > 1)
-		return distance2d_sqr_pt_pt(p, B);
-	 * (2)
-	 *	     (Ay-Cy)(Bx-Ax)-(Ax-Cx)(By-Ay)
-	 *	s = -----------------------------
-	 *	             	L^2
-	 *	Then the distance from C to P = |s|*L.
-	return s * s * ((B->x - A->x) * (B->x - A->x) + (B->y - A->y) * (B->y - A->y));
  * Compute the azimuth of segment AB in radians.
  * Return 0 on exception (same point), 1 otherwise.
Modified: trunk/liblwgeom/ptarray.c
--- trunk/liblwgeom/ptarray.c	2019-09-24 10:45:43 UTC (rev 17820)
+++ trunk/liblwgeom/ptarray.c	2019-09-24 10:58:30 UTC (rev 17821)
@@ -1331,13 +1331,13 @@
 	/* Loop through pointarray looking for nearest segment */
 	for (t=1; t<pa->npoints; t++)
-		double dist;
+		double dist_sqr;
 		end = getPoint2d_cp(pa, t);
-		dist = distance2d_pt_seg(&p, start, end);
+		dist_sqr = distance2d_sqr_pt_seg(&p, start, end);
-		if ( dist < mindist )
+		if (dist_sqr < mindist)
-			mindist = dist;
+			mindist = dist_sqr;
 			seg=t-1;
 			if ( mindist == 0 )
@@ -1348,6 +1348,7 @@
 		start = end;
+	mindist = sqrt(mindist);
 	if ( mindistout ) *mindistout = mindist;
@@ -1514,143 +1515,151 @@
 	return;
-static void
-ptarray_dp_findsplit_in_place(const POINTARRAY *pts, int p1, int p2, int *split, double *dist)
+/* Out of the points in pa [itfist .. itlast], finds the one that's farthest away from
+ * the segment determined by pts[itfist] and pts[itlast].
+ * Returns itfirst if no point was found futher away than max_distance_sqr
+static uint32_t
+ptarray_dp_findsplit_in_place(const POINTARRAY *pts, uint32_t it_first, uint32_t it_last, double max_distance_sqr)
-	int k;
-	const POINT2D *pk, *pa, *pb;
-	double tmp, d;
+	uint32_t split = it_first;
+	if ((it_first - it_last) < 2)
+		return it_first;
-	LWDEBUG(4, "function called");
+	const POINT2D *A = getPoint2d_cp(pts, it_first);
+	const POINT2D *B = getPoint2d_cp(pts, it_last);
-	*split = p1;
-	d = -1;
-	if (p1 + 1 < p2)
+	if (distance2d_sqr_pt_pt(A, B) < DBL_EPSILON)
-		pa = getPoint2d_cp(pts, p1);
-		pb = getPoint2d_cp(pts, p2);
-		LWDEBUGF(4, "P%d(%f,%f) to P%d(%f,%f)",
-		         p1, pa->x, pa->y, p2, pb->x, pb->y);
-		for (k=p1+1; k<p2; k++)
+		/* If p1 == p2, we can just calculate the distance from each point to A */
+		for (uint32_t itk = it_first + 1; itk < it_last; itk++)
-			pk = getPoint2d_cp(pts, k);
-			LWDEBUGF(4, "P%d(%f,%f)", k, pk->x, pk->y);
-			/* distance computation */
-			tmp = distance2d_sqr_pt_seg(pk, pa, pb);
-			if (tmp > d)
+			const POINT2D *pk = getPoint2d_cp(pts, itk);
+			double distance_sqr = distance2d_sqr_pt_pt(pk, A);
+			if (distance_sqr > max_distance_sqr)
-				d = tmp;	/* record the maximum */
-				*split = k;
-				LWDEBUGF(4, "P%d is farthest (%g)", k, d);
+				split = itk;
+				max_distance_sqr = distance_sqr;
-		*dist = d;
+		return split;
-	else
+	/* This is based on distance2d_sqr_pt_seg, but heavily inlined here to avoid recalculations */
+	/* To avoid the division by ab_length_sqr in the 3rd path, we normalize here
+	 * and multiply in the first two paths [(dot_ac_ab < 0) and (> ab_length_sqr)] */
+	max_distance_sqr *= ab_length_sqr;
-		LWDEBUG(3, "segment too short, no split/no dist");
-		*dist = -1;
+		const POINT2D *C = getPoint2d_cp(pts, itk);
+		double distance_sqr;
+		if (dot_ac_ab <= 0.0)
+			distance_sqr = distance2d_sqr_pt_pt(C, A) * ab_length_sqr;
+		else if (dot_ac_ab >= ab_length_sqr)
+			distance_sqr = distance2d_sqr_pt_pt(C, B) * ab_length_sqr;
+		else
+			distance_sqr = s_numerator * s_numerator; /* Missing division by ab_length_sqr on purpose */
+			split = itk;
+	return split;
-static int
-int_cmp(const void *a, const void *b)
-	/* casting pointer types */
-	const int *ia = (const int *)a;
-	const int *ib = (const int *)b;
-	/* returns negative if b > a and positive if a > b */
-	return *ia - *ib;
 void
-ptarray_simplify_in_place(POINTARRAY *pa, double epsilon, uint32_t minpts)
+ptarray_simplify_in_place(POINTARRAY *pa, double tolerance, uint32_t minpts)
-	static size_t stack_size = 256;
-	int *stack, *outlist; /* recursion stack */
-	int stack_static[stack_size];
-	int outlist_static[stack_size];
-	int sp = -1; /* recursion stack pointer */
-	int p1, split;
-	uint32_t outn = 0;
-	int pai = 0;
-	uint32_t i;
-	double dist;
-	double eps_sqr = epsilon * epsilon;
 	/* Do not try to simplify really short things */
-	if (pa->npoints < 3) return;
+	if (pa->npoints < 3 || pa->npoints <= minpts)
+		return;
-	/* Only heap allocate book-keeping arrays if necessary */
-	if (pa->npoints > stack_size)
-		stack = lwalloc(sizeof(int) * pa->npoints);
-		outlist = lwalloc(sizeof(int) * pa->npoints);
-	else
-		stack = stack_static;
-		outlist = outlist_static;
+	/* We use this array to keep track of the points we are keeping, so
+	 * we store just TRUE / FALSE in their position */
+	uint8_t *kept_points = lwalloc(sizeof(uint8_t) * pa->npoints);
+	memset(kept_points, LW_FALSE, sizeof(uint8_t) * pa->npoints);
+	kept_points[0] = LW_TRUE;
+	kept_points[pa->npoints - 1] = LW_TRUE;
+	uint32_t keptn = 2;
-	p1 = 0;
-	stack[++sp] = pa->npoints-1;
+	/* We use this array as a stack to store the iterators that we are going to need
+	 * in the following steps.
+	 * This is ~10% faster than iterating over @kept_points looking for them
+	uint32_t *iterator_stack = lwalloc(sizeof(uint32_t) * pa->npoints);
+	iterator_stack[0] = 0;
+	uint32_t iterator_stack_size = 1;
-	/* Add first point to output list */
-	outlist[outn++] = 0;
-	do
+	uint32_t it_first = 0;
+	uint32_t it_last = pa->npoints - 1;
+	const double tolerance_sqr = tolerance * tolerance;
+	/* For the first @minpts points we ignore the tolerance */
+	double it_tol = keptn >= minpts ? tolerance_sqr : -1.0;
+	while (iterator_stack_size)
-		ptarray_dp_findsplit_in_place(pa, p1, stack[sp], &split, &dist);
-		if ((dist > eps_sqr) || ((outn + sp+1 < minpts) && (dist >= 0)))
+		uint32_t split = ptarray_dp_findsplit_in_place(pa, it_first, it_last, it_tol);
+		if (split == it_first)
-			stack[++sp] = split;
+			it_first = it_last;
+			it_last = iterator_stack[--iterator_stack_size];
 		else
-			outlist[outn++] = stack[sp];
-			p1 = stack[sp--];
+			kept_points[split] = LW_TRUE;
+			keptn++;
+			iterator_stack[iterator_stack_size++] = it_last;
+			it_last = split;
+			it_tol = keptn >= minpts ? tolerance_sqr : -1.0;
-	while (!(sp<0));
-	/* Put list of retained points into order */
-	qsort(outlist, outn, sizeof(int), int_cmp);
-	/* Copy retained points to front of array */
-	for (i = 0; i < outn; i++)
+	const size_t pt_size = ptarray_point_size(pa);
+	/* The first point is already in place, so we don't need to copy it */
+	size_t kept_it = 1;
+	if (keptn == 2)
-		int j = outlist[i];
-		/* Indexes the same, means no copy required */
-		if (j == pai)
+		/* If there are 2 points remaining, it has to be first and last as
+		 * we added those at the start */
+		memcpy(pa->serialized_pointlist + pt_size * kept_it,
+		       pa->serialized_pointlist + pt_size * (pa->npoints - 1),
+		       pt_size);
+	else
+		for (uint32_t i = 1; i < pa->npoints; i++)
-			pai++;
-			continue;
+			if (kept_points[i])
+				       pa->serialized_pointlist + pt_size * i,
+				       pt_size);
+				kept_it++;
-		/* Indexes different, copy value down */
-		ptarray_copy_point(pa, j, pai++);
+	pa->npoints = keptn;
-	/* Adjust point count on array */
-	pa->npoints = outn;
-	/* Only free if arrays are on heap */
-	if (stack != stack_static)
-		lwfree(stack);
-	if (outlist != outlist_static)
-		lwfree(outlist);
-	return;
+	lwfree(kept_points);
+	lwfree(iterator_stack);
Modified: trunk/postgis/lwgeom_functions_analytic.c
--- trunk/postgis/lwgeom_functions_analytic.c	2019-09-24 10:45:43 UTC (rev 17820)
+++ trunk/postgis/lwgeom_functions_analytic.c	2019-09-24 10:58:30 UTC (rev 17821)
@@ -63,33 +63,32 @@
 PG_FUNCTION_INFO_V1(LWGEOM_simplify2d);
 Datum LWGEOM_simplify2d(PG_FUNCTION_ARGS)
-	GSERIALIZED *geom = PG_GETARG_GSERIALIZED_P(0);
+	GSERIALIZED *geom = PG_GETARG_GSERIALIZED_P_COPY(0);
 	double dist = PG_GETARG_FLOAT8(1);
 	GSERIALIZED *result;
 	int type = gserialized_get_type(geom);
-	LWGEOM *in, *out;
+	LWGEOM *in;
 	bool preserve_collapsed = false;
+	/* Can't simplify points! */
+	if ( type == POINTTYPE || type == MULTIPOINTTYPE )
+		PG_RETURN_POINTER(geom);
 	/* Handle optional argument to preserve collapsed features */
 	if ((PG_NARGS() > 2) && (!PG_ARGISNULL(2)))
 		preserve_collapsed = PG_GETARG_BOOL(2);
-	/* Can't simplify points! */
-	if ( type == POINTTYPE || type == MULTIPOINTTYPE )
-		PG_RETURN_POINTER(geom);
 	in = lwgeom_from_gserialized(geom);
-	out = lwgeom_simplify(in, dist, preserve_collapsed);
-	if ( ! out ) PG_RETURN_NULL();
+	modified = lwgeom_simplify_in_place(in, dist, preserve_collapsed);
+	if (!modified)
-	/* COMPUTE_BBOX TAINTING */
-	if (in->bbox)
-		lwgeom_refresh_bbox(out);
+	if (!in || lwgeom_is_empty(in))
+		PG_RETURN_NULL();
-	result = geometry_serialize(out);
-	lwgeom_free(out);
-	PG_FREE_IF_COPY(geom, 0);
+	result = geometry_serialize(in);
 	PG_RETURN_POINTER(result);
