[postgis-tickets] [PostGIS] #4514: GEOS master breaks topology tests
PostGIS trac at osgeo.org
Fri Sep 27 17:01:40 PDT 2019
  Reporter:  Algunenano  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS GEOS
 Component:  postgis     |    Version:  trunk
Resolution:              |   Keywords:
Comment (by robe):
 strk if you don't like my solution, feel free to revise.  If you are okay
 with it, then we should probably backport to at least 2.5.
 I also changed the check_changes in addpolygon test to have a label like
 you had in linestring one, as it was hard to tell which was failing
 otherwise.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4514#comment:4>
