[postgis-tickets] [PostGIS] #4338: Census block level data (tabblock table) not installing
PostGIS trac at osgeo.org
Fri Sep 27 19:52:11 PDT 2019
  Reporter:  jedaniel        |      Owner:  robe
      Type:  defect          |     Status:  new
  Priority:  high            |  Milestone:  PostGIS 3.0.0
 Component:  tiger geocoder  |    Version:  2.5.x
Resolution:                  |   Keywords:  census block tabblock windows
Comment (by robe):
 In [changeset:"17825" 17825]:
 #!CommitTicketReference repository="" revision="17825"
 Fix issue with loading tabblock
 Update geocoder to load 2019 data
 Closes #4509 for PostGIS 3.0
 References #4338 for PostGIS 3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4338#comment:3>
