[postgis-tickets] [PostGIS] #4515: 00-regress-install doesn't get created legacy regress fails (was: 00-regress-install doesn't get created)
PostGIS trac at osgeo.org
Sat Sep 28 04:10:23 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 I should add I also get this in the legacy regress failure which is kinda
 odd but perhaps related because it never was able to install legacy.sql
 Why a non-existent file would produce too many open files seems a little
 strange.
 +psql:legacy.sql:12: error: legacy.sql: Too many open files
  Starting up MapServer/Geoserver tests...
  Setting up the data table...
  public.wmstest.pt SRID:4326 TYPE:POLYGON DIMS:2
  Running Geoserver 2.0 NG tests...
  Geoserver1|POLYGON
  Geoserver2|4326
 -Geoserver3|-500|AAAAAAMAAAABAAA
 -Geoserver4|1
 -Geoserver5|25|AAAAAAMAAAABAAA
 -Geoserver6|25|AAAAAAMAAAABAAA
 +ERROR:  function force_2d(geometry) does not exist at character 50
 +ERROR:  function geomfromtext(unknown, integer) does not exist at
 character 69
  MapServer1|id
 -MapServer2|-9465|AQcAAAABAAAAAQM|-9465
 -MapServer2|-9460|AQcAAAABAAAAAQM|-9460
 +ERROR:  function force_2d(geometry) does not exist at character 67
  MapServer3|id
 -MapServer4|-9465|010700000001000|-9465
 -MapServer4|-9460|010700000001000|-9460
  Removing the data table...
  Done.
 -1869|POINT(1 2)
 +ERROR:  function st_asbinary(unknown) is not unique at character 37
 +psql:legacy.sql:54: error: uninstall_legacy.sql: No such file or
 directory
 +Starting up MapServer/Geoserver tests...
 +Setting up the data table...
 +public.wmstest.pt SRID:4326 TYPE:POLYGON DIMS:2
 +Running Geoserver 2.0 NG tests...
 +Geoserver1|POLYGON
 +Geoserver2|4326
 character 69
 +MapServer1|id
 +MapServer3|id
 +Removing the data table...
 +Done.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4515#comment:2>
