[postgis-tickets] r17831 - Add note about additional performance enhancements with GEOS 3.8
Regina Obe lr at pcorp.us
Sat Sep 28 04:54:32 PDT 2019
Author: robe
Date: 2019-09-28 16:54:32 -0700 (Sat, 28 Sep 2019)
New Revision: 17831
   trunk/doc/release_notes.xml
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml	2019-09-28 23:28:14 UTC (rev 17830)
+++ trunk/doc/release_notes.xml	2019-09-28 23:54:32 UTC (rev 17831)
@@ -8,7 +8,8 @@
       <para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
       <para>Supported PostgreSQL versions for this release are:
       PostgreSQL 9.5 - PostgreSQL 12
-      GEOS >= 3.6. Additional features enabled if you running Proj6+ and/or PostgreSQL 12</para>
+      GEOS >= 3.6. Additional features enabled if you running Proj6+ and/or PostgreSQL 12.
+      Performance enhancements if running GEOS 3.8+</para>
       <simplesect>
         <title>Major highlights</title>
           <para>4492, Fix ST_Simplify ignoring the value of the 3rd parameter (Raúl Marín)</para>
