[postgis-tickets] [PostGIS] #4474: bessie32 FreeBSD12 32-bit wagyu compile causes undefined symbol error
PostGIS trac at osgeo.org
Mon Sep 30 10:50:53 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.5.x
Resolution:             |   Keywords:
Comment (by robe):
 The above sadly still failed with same error, even though it shows it's
 using gcc8 in both cases now.
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/1498/consoleFull
 12:41:54
 12:41:54  -------------- Compiler Info -------------
 12:41:54   C compiler:           gcc8 -std=gnu99 -Wall -Wmissing-
 prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels
 -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv
 -fexcess-precision=standard -Wno-format-trunc -fno-math-errno -fno-signed-
 zeros
 12:41:54   C++ compiler (Wagyu): gcc8 -std=c++11 -x c++
 12:41:54   CPPFLAGS:              -I/usr/local/include
 -I/usr/local/include  -I/usr/local/include  -I/usr/local/include/libxml2
 -I/usr/include -I/usr/local/include -I/usr/local/include/json-c
 12:41:54   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:20>
