[postgis-tickets] [PostGIS] #4661: ST_Distance(geography, geography) fails when schema name contains hyphen character
PostGIS trac at osgeo.org
Thu Apr 9 07:12:55 PDT 2020
character
  Reporter:  kunszabo67  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:
 Component:  postgis     |    Version:  2.5.x
Resolution:              |   Keywords:
Comment (by Algunenano):
 There are also multiple issues when spatial_ref_sys is not in the
 search_path:
 Select "schema-with-hyphen".ST_AsGeoJSON('SRID=3827; POINT(1 1)'::"schema-
 with-hyphen".geometry);
 ERROR:  relation "spatial_ref_sys" does not exist
 LINE 1: SELECT auth_name||':'||auth_srid           FROM spatial_ref_...
 QUERY:  SELECT auth_name||':'||auth_srid                        FROM
 spatial_ref_sys WHERE srid='3827'
 The following C functions are either not adding the schema or adding it
 without quotes:
 - getSRSbySRID
 - getSRIDbySRS
 - gml_is_srid_planar
 - rtpg_getSR
 - SetSpatialRefSysSchema -> GetProjStringsSPI
 - getPostgisConstants (unused)
 Also, as Komzpa alerted, this will now break if the schema has quotes in
 it, so we should find the proper way to fully escape the identifier and
 then ensure all functions use it correctly.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4661#comment:4>
