[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-50-g8b548a4
Thu Apr 9 08:47:03 PDT 2020
the project "PostGIS".
       via  8b548a4697490b7e45508b91cb340eb79b424a92 (commit)
      from  d92c6b7cf4b3c8078b6ffcbc59a91462db57f92a (commit)
revisions in full, below.
commit 8b548a4697490b7e45508b91cb340eb79b424a92
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Apr 9 08:46:56 2020 -0700
    Add a toast cache to index cache infrastructure, so that repeated loads of toasted-to-disk datums can avoid actually having to decompress/detoast the same object, closes #4657
diff --git a/libpgcommon/lwgeom_cache.c b/libpgcommon/lwgeom_cache.c
index 1dcb3f8..4664060 100644
--- a/libpgcommon/lwgeom_cache.c
+++ b/libpgcommon/lwgeom_cache.c
@@ -12,6 +12,7 @@
 #include "postgres.h"
 #include "fmgr.h"
+#include "access/tuptoaster.h"
 #include "../postgis_config.h"
 #include "lwgeom_cache.h"
@@ -145,9 +146,10 @@ GetGeomCache(FunctionCallInfo fcinfo,
 	/* Cache hit on the first argument */
 	if ( g1 &&
-	     cache->argnum != 2 &&
-	     cache->geom1_size == VARSIZE(g1) &&
-	     memcmp(cache->geom1, g1, cache->geom1_size) == 0 )
+	     cache->argnum != 2 && (
+	     (g1 == cache->geom1) ||
+	     (cache->geom1_size == VARSIZE(g1) && memcmp(cache->geom1, g1, cache->geom1_size) == 0)
 		cache_hit = 1;
 		geom = cache->geom1;
@@ -155,9 +157,10 @@ GetGeomCache(FunctionCallInfo fcinfo,
 	/* Cache hit on second argument */
 	else if ( g2 &&
-	          cache->argnum != 1 &&
-	          cache->geom2_size == VARSIZE(g2) &&
-	          memcmp(cache->geom2, g2, cache->geom2_size) == 0 )
+	          cache->argnum != 1 && (
+	          (g2 == cache->geom2) ||
+	          (cache->geom2_size == VARSIZE(g2) && memcmp(cache->geom2, g2, cache->geom2_size) == 0)
 		cache_hit = 2;
 		geom = cache->geom2;
@@ -236,4 +239,73 @@ GetGeomCache(FunctionCallInfo fcinfo,
 	return NULL;
+inline static ToastCache*
+ToastCacheGet(FunctionCallInfo fcinfo)
+	const uint32_t entry_number = TOAST_CACHE_ENTRY;
+	GenericCacheCollection* generic_cache = GetGenericCacheCollection(fcinfo);
+	ToastCache* cache = (ToastCache*)(generic_cache->entry[entry_number]);
+	if (!cache)
+		cache = MemoryContextAllocZero(FIContext(fcinfo), sizeof(ToastCache));
+		cache->type = entry_number;
+		generic_cache->entry[entry_number] = (GenericCache*)cache;
+	return cache;
+GSERIALIZED*
+ToastCacheGetGeometry(FunctionCallInfo fcinfo, uint32_t argnum)
+	Assert(argnum < ToastCacheSize);
+	ToastCache* cache = ToastCacheGet(fcinfo);
+	ToastCacheArgument* arg = &(cache->arg[argnum]);
+	Datum datum = PG_GETARG_DATUM(argnum);
+	struct varlena *attr = (struct varlena *) DatumGetPointer(datum);
+	* In general, you have to detoast the whole object to
+	* determine if it's different from the cached object, but
+	* for toasted objects, the va_valueid and va_toastrelid are
+	* a unique key. Only objects toasted to disk have this
+	* property, but fortunately those are also the objects
+	* that are costliest to de-TOAST, which is why this
+	* cache is a performance win.
+	* https://www.postgresql.org/message-id/8196.1585870220@sss.pgh.pa.us
+	if (!VARATT_IS_EXTERNAL_ONDISK(attr))
+		return (GSERIALIZED*)PG_DETOAST_DATUM(datum);
+	/* Retrieve the unique keys for this object */
+	struct varatt_external ve;
+	VARATT_EXTERNAL_GET_POINTER(ve, attr);
+	Oid valueid = ve.va_valueid;
+	Oid toastrelid = ve.va_toastrelid;
+	/* We've seen this object before? */
+	if (arg->valueid == valueid && arg->toastrelid == toastrelid)
+		if (arg->geom)
+			return arg->geom;
+		/* Take a copy into the upper context */
+		MemoryContext old_context = MemoryContextSwitchTo(FIContext(fcinfo));
+		arg->geom = (GSERIALIZED*)PG_DETOAST_DATUM_COPY(datum);
+		MemoryContextSwitchTo(old_context);
+		return arg->geom;
+	/* New object, clear our old copies and see if it */
+	/* shows up a second time before taking a copy */
+	else
+		if (arg->geom)
+			pfree(arg->geom);
+		arg->valueid = valueid;
+		arg->toastrelid = toastrelid;
+		arg->geom = NULL;
diff --git a/libpgcommon/lwgeom_cache.h b/libpgcommon/lwgeom_cache.h
index 16edb09..745e178 100644
--- a/libpgcommon/lwgeom_cache.h
+++ b/libpgcommon/lwgeom_cache.h
@@ -26,8 +26,9 @@
 #define RTREE_CACHE_ENTRY 2
 #define CIRC_CACHE_ENTRY 3
 #define RECT_CACHE_ENTRY 4
+#define TOAST_CACHE_ENTRY 5
-#define NUM_CACHE_ENTRIES 16
+#define NUM_CACHE_ENTRIES 8
@@ -110,4 +111,24 @@ GeomCache *GetGeomCache(FunctionCallInfo fcinfo,
 			const GSERIALIZED *g1,
 			const GSERIALIZED *g2);
+#define ToastCacheSize 2
+typedef struct
+	Oid valueid;
+	Oid toastrelid;
+	GSERIALIZED *geom;
+} ToastCacheArgument;
+typedef struct
+	int type;
+	ToastCacheArgument arg[ToastCacheSize];
+} ToastCache;
+GSERIALIZED* ToastCacheGetGeometry(FunctionCallInfo fcinfo, uint32_t argnum);
 #endif /* LWGEOM_CACHE_H_ */
diff --git a/postgis/geography_measurement.c b/postgis/geography_measurement.c
index aa66929..851eda0 100644
--- a/postgis/geography_measurement.c
+++ b/postgis/geography_measurement.c
@@ -212,8 +212,8 @@ Datum geography_distance(PG_FUNCTION_ARGS)
 	SPHEROID s;
 	/* Get our geometry objects loaded into memory. */
-	g1 = PG_GETARG_GSERIALIZED_P(0);
-	g2 = PG_GETARG_GSERIALIZED_P(1);
+	g1 = ToastCacheGetGeometry(fcinfo, 0);
+	g2 = ToastCacheGetGeometry(fcinfo, 1);
 	if (PG_NARGS() > 2)
 		use_spheroid = PG_GETARG_BOOL(2);
@@ -230,8 +230,6 @@ Datum geography_distance(PG_FUNCTION_ARGS)
 	/* Return NULL on empty arguments. */
 	if ( gserialized_is_empty(g1) || gserialized_is_empty(g2) )
-		PG_FREE_IF_COPY(g1, 0);
-		PG_FREE_IF_COPY(g2, 1);
 		PG_RETURN_NULL();
@@ -250,10 +248,6 @@ Datum geography_distance(PG_FUNCTION_ARGS)
-	/* Clean up */
 	/* Knock off any funny business at the nanometer level, ticket #2168 */
 	distance = round(distance * INVMINDIST) / INVMINDIST;
@@ -274,8 +268,8 @@ Datum geography_distance(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(geography_dwithin);
 Datum geography_dwithin(PG_FUNCTION_ARGS)
-	GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
-	GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
+	GSERIALIZED *g1 = ToastCacheGetGeometry(fcinfo, 0);
+	GSERIALIZED *g2 = ToastCacheGetGeometry(fcinfo, 1);
 	SPHEROID s;
 	double tolerance = 0.0;
 	bool use_spheroid = true;
@@ -317,8 +311,6 @@ Datum geography_dwithin(PG_FUNCTION_ARGS)
 		lwgeom_free(lwgeom2);
 	PG_RETURN_BOOL(dwithin);
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index d8580ab..8030ece 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -1658,8 +1658,8 @@ Datum overlaps(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(contains);
 Datum contains(PG_FUNCTION_ARGS)
-	GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
-	GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
+	GSERIALIZED *geom1 = ToastCacheGetGeometry(fcinfo, 0);
+	GSERIALIZED *geom2 = ToastCacheGetGeometry(fcinfo, 1);
 	int result;
 	GEOSGeometry *g1, *g2;
 	GBOX box1, box2;
@@ -1777,8 +1777,6 @@ Datum contains(PG_FUNCTION_ARGS)
 	if (result == 2) HANDLE_GEOS_ERROR("GEOSContains");
-	PG_FREE_IF_COPY(geom1, 0);
-	PG_FREE_IF_COPY(geom2, 1);
 	PG_RETURN_BOOL(result > 0);
@@ -1801,8 +1799,8 @@ Datum containsproperly(PG_FUNCTION_ARGS)
 	GBOX 			box1, box2;
 	PrepGeomCache *	prep_cache;
-	geom1 = PG_GETARG_GSERIALIZED_P(0);
-	geom2 = PG_GETARG_GSERIALIZED_P(1);
+	geom1 = ToastCacheGetGeometry(fcinfo, 0);
+	geom2 = ToastCacheGetGeometry(fcinfo, 1);
 	gserialized_error_if_srid_mismatch(geom1, geom2, __func__);
 	/* A.ContainsProperly(Empty) == FALSE */
@@ -1851,9 +1849,6 @@ Datum containsproperly(PG_FUNCTION_ARGS)
 	PG_RETURN_BOOL(result);
@@ -1870,8 +1865,8 @@ Datum covers(PG_FUNCTION_ARGS)
 	GBOX box1, box2;
 	PrepGeomCache *prep_cache;
 	/* A.Covers(Empty) == FALSE */
 	if ( gserialized_is_empty(geom1) || gserialized_is_empty(geom2) )
@@ -1936,8 +1931,6 @@ Datum covers(PG_FUNCTION_ARGS)
 			PG_RETURN_NULL();
 		PG_RETURN_BOOL(retval);
 	else
@@ -1976,11 +1969,7 @@ Datum covers(PG_FUNCTION_ARGS)
 	if (result == 2) HANDLE_GEOS_ERROR("GEOSCovers");
@@ -2005,8 +1994,8 @@ Datum coveredby(PG_FUNCTION_ARGS)
 	GBOX box1, box2;
 	char *patt = "**F**F***";
 	/* A.CoveredBy(Empty) == FALSE */
@@ -2072,8 +2061,6 @@ Datum coveredby(PG_FUNCTION_ARGS)
 			PG_RETURN_NULL();
 	else
@@ -2103,9 +2090,6 @@ Datum coveredby(PG_FUNCTION_ARGS)
 	if (result == 2) HANDLE_GEOS_ERROR("GEOSCoveredBy");
@@ -2174,8 +2158,8 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
 	GBOX box1, box2;
 	/* A.Intersects(Empty) == FALSE */
@@ -2238,8 +2222,6 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
 			PG_RETURN_NULL();
@@ -2283,9 +2265,6 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
 	if (result == 2) HANDLE_GEOS_ERROR("GEOSIntersects");
Summary of changes:
 libpgcommon/lwgeom_cache.c      | 84 ++++++++++++++++++++++++++++++++++++++---
 libpgcommon/lwgeom_cache.h      | 23 ++++++++++-
 postgis/geography_measurement.c | 16 ++------
 postgis/lwgeom_geos.c           | 41 +++++---------------
 4 files changed, 114 insertions(+), 50 deletions(-)
hooks/post-receive
