[postgis-tickets] [PostGIS] #4667: Fails to build with GCC-10
PostGIS trac at osgeo.org
Fri Apr 17 05:14:58 PDT 2020
  Reporter:  Bas Couwenberg         |      Owner:  Raúl Marín
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:
 Component:  build/upgrade/install  |    Version:  3.0.x
Resolution:                         |   Keywords:
Changes (by Raúl Marín):
 * owner:  strk => Raúl Marín
Comment:
 There was a missing guard in the included file, so it should be fixed with
 this.
 Bas, I think this should fix the issue but I don't have gcc 10 available
 without compiling it. If you can confirm it fixes the issue I'll backport
 it to all stable releases.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4667#comment:2>
