[postgis-tickets] [PostGIS] #4667: Fails to build with GCC-10
PostGIS trac at osgeo.org
Fri Apr 17 06:11:04 PDT 2020
  Reporter:  Bas Couwenberg         |      Owner:  Raúl Marín
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:
 Component:  build/upgrade/install  |    Version:  3.0.x
Resolution:                         |   Keywords:
Comment (by Raúl Marín):
 Thanks for testing it.
 I've moved the string declaration to the source file which I hope fixes
 the issue. I did something similar a year ago to liblwgeom cunit tests and
 that isn't complaining, so I guess this should be ok too.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4667#comment:5>
