[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-63-gb6b33b0
Tue Apr 21 08:08:41 PDT 2020
the project "PostGIS".
       via  b6b33b0dc65025a11993b42899cd94db8a25eb04 (commit)
      from  c83c3dfdc123b9ca42d6ba3d520ca086c241966a (commit)
revisions in full, below.
commit b6b33b0dc65025a11993b42899cd94db8a25eb04
Author: Raúl Marín <git at rmr.ninja>
Date:   Tue Apr 21 16:41:19 2020 +0200
    ST_AddPoint: Fix bug when a positive position is requested
    References #4670
    Introduced in #4599, so backpatching through 2.5
diff --git a/NEWS b/NEWS
index 8659b46..94ed614 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,7 @@ Only tickets not included in 3.1.0alpha1
 * Bug fixes *
   - #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
   - #4661, Fix access to spatial_ref_sys with a non default schema (Raúl Marín)
+  - #4670, ST_AddPoint: Fix bug when a positive position is requested (Raúl Marín)
 PostGIS 3.1.0alpha1
 2020/02/01
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 4d0daa2..6fc2803 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2252,9 +2252,13 @@ Datum LWGEOM_addpoint(PG_FUNCTION_ARGS)
 		else if (where < 0 || where > (int32)line->points->npoints)
-			elog(ERROR, "Invalid offset");
+			elog(ERROR, "%s: Invalid offset", __func__);
 			PG_RETURN_NULL();
+		else
+			uwhere = where;
 	point = lwgeom_as_lwpoint(lwgeom_from_gserialized(pglwg2));
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 4e1b3e0..842bd07 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1288,3 +1288,10 @@ select '#4399', 'ST_AsGeoJSON', ST_AsGeoJSON(geom)::text from geom;
 SELECT '#4599-1', ST_AsEWKT(ST_AddPoint(ST_GeomFromEWKT('LINESTRING(0 0 1, 1 1 1)'), ST_MakePoint(1, 2, 3)));
 SELECT '#4599-2', ST_AsEWKT(ST_AddPoint(ST_GeomFromEWKT('LINESTRING(0 0 1, 1 1 1)'), ST_MakePoint(1, 2, 3), 0));
 SELECT '#4599-3', ST_AsEWKT(ST_AddPoint(ST_GeomFromEWKT('LINESTRING(0 0 1, 1 1 1)'), ST_MakePoint(1, 2, 3), -1));
+SELECT '#4670-0', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 0));
+SELECT '#4670-1', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 1));
+SELECT '#4670-2', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 2));
+SELECT '#4670-3', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 3));
+SELECT '#4670-4', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 4));
+SELECT '#4670-5', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 5));
\ No newline at end of file
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 4b34ba7..fbf9316 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -427,3 +427,9 @@ ERROR:  BOX2D_construct: args can not be empty points
 #4599-1|LINESTRING(0 0 1,1 1 1,1 2 3)
 #4599-2|LINESTRING(1 2 3,0 0 1,1 1 1)
 #4599-3|LINESTRING(0 0 1,1 1 1,1 2 3)
+#4670-0|LINESTRING(2 2,0 0,1 1,3 3,4 4)
+#4670-1|LINESTRING(0 0,2 2,1 1,3 3,4 4)
+#4670-2|LINESTRING(0 0,1 1,2 2,3 3,4 4)
+#4670-3|LINESTRING(0 0,1 1,3 3,2 2,4 4)
+#4670-4|LINESTRING(0 0,1 1,3 3,4 4,2 2)
+ERROR:  LWGEOM_addpoint: Invalid offset
Summary of changes:
 NEWS                             | 1 +
 postgis/lwgeom_functions_basic.c | 6 +++++-
 regress/core/tickets.sql         | 7 +++++++
 regress/core/tickets_expected    | 6 ++++++
 4 files changed, 19 insertions(+), 1 deletion(-)
hooks/post-receive
