[postgis-tickets] [PostGIS] #4671: ST_Length(geography) leaks memory
PostGIS trac at osgeo.org
Thu Apr 23 01:57:37 PDT 2020
  Reporter:  komzpa   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by Raúl Marín):
 Maybe the leak is in the cast, and not in the ST_Length call. Have you
 tested with PROJ6+?
 Do you have some kind of repro we can test?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4671#comment:2>
