[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-86-g121956b
Mon Apr 27 16:29:46 PDT 2020
the project "PostGIS".
       via  121956bb7ecdfdcbafd5dc69cca2aa1df8283b40 (commit)
      from  2d6fab0cf9c892e9e3a9d7bbf27e23b892b86049 (commit)
revisions in full, below.
commit 121956bb7ecdfdcbafd5dc69cca2aa1df8283b40
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Apr 27 19:29:41 2020 -0400
    Get rid of CTE in first and just nest the function call, shorter. move note about lateral to second example since the first no longer uses LATERAL
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 44921ec..8026775 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -851,7 +851,6 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
 			</imageobject></inlinemediaobject></para>
 			<para>Availability: 3.1</para>
-			<note><para>All calls in the examples use an implicit LATERAL construct although you don't see the LATERAL keywor.  The LATERAL keyword is optional for set returning functions and is implied when using a input from prior table in the FROM.</para></note>
 		</refsection>
@@ -859,12 +858,10 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
 		<title>Example: Counting points in hexagons</title>
 		<para>To do a point summary against a hexagonal tiling, generate a hexagon grid using the
 		extent of the points as the bounds, then spatially join to that grid.</para>
-		 <programlisting>WITH bounds AS (
- 		SELECT ST_SetSRID(ST_EstimatedExtent('pointtable', 'geom'),3857) AS geom
- SELECT COUNT(*), hexes.geom
- FROM bounds
- 	CROSS JOIN ST_HexagonGrid(10000, bounds.geom) AS hexes
+		 <programlisting>SELECT COUNT(*), hexes.geom
+ FROM ST_HexagonGrid(10000,
+ 			 ST_SetSRID(ST_EstimatedExtent('pointtable', 'geom'),3857)
+ 		) AS hexes
 	INNER JOIN pointtable AS pts ON ST_Intersects(pts.geom, hexes.geom)
  GROUP BY hexes.geom;</programlisting>
 		</refsection>
@@ -874,6 +871,7 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
 		<para>If we generate a set of hexagons for each polygon boundary and filter
 			out those that do not intersect their hexagons, we end up with a tiling for
 			each polygon.</para>
+		<note><para>The LATERAL keyword is optional for set returning functions and is implied when using a input from prior table in the FROM. So CROSS JOIN LATERAL, CROSS JOIN, or just plain , are equivalent constructs.</para></note>
 		<para><inlinemediaobject><imageobject>
 			<imagedata fileref='images/st_hexagongrid03.png' />
Summary of changes:
 doc/reference_constructor.xml | 12 +++++-------
 1 file changed, 5 insertions(+), 7 deletions(-)
hooks/post-receive
