[postgis-tickets] [PostGIS] #4674: lwgeom_cache doesn't live through not inline functions
PostGIS trac at osgeo.org
Tue Apr 28 12:02:12 PDT 2020
 Reporter:  Raúl Marín  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  medium      |  Milestone:  PostGIS 3.1.0
Component:  postgis     |    Version:  master
 Keywords:              |
 While I was working on #4672, I noticed that the ST_AsGML cache wasn't
 working all the time (in fact it was working with geographies but not
 geometries).
 After adding some logs, it seems that if the function is inlined, the
 cache (installed in the parent memory context) lives for the next row, but
 if it isn't then you loose the cache and everything needs to be recreated
 again.
 Example that isn't inlined:
 # explain (analyze, verbose) Select ST_AsGML(the_geom::geometry) from
 benchmark_7773a711c8441d4b494a51fd9feebeac7a9b9c734619398620293 limit
 4;NOTICE:  GetGenericCacheCollection not found
 NOTICE:  generic_cache not found
 NOTICE:  Cache not found. Expected: 4326 1. Found: 0 0 null
 QUERY PLAN
  Limit  (cost=0.00..1.25 rows=4 width=32) (actual time=0.780..2.497 rows=4
 loops=1)
    Output: (st_asgml(the_geom, 15, 0))
    ->  Seq Scan on
 public.benchmark_7773a711c8441d4b494a51fd9feebeac7a9b9c734619398620293
 (cost=0.00..213260.58 rows=683833 width=32) (actual time=0.778..2.492
 rows=4 loops=1)
          Output: st_asgml(the_geom, 15, 0)
  Planning Time: 0.213 ms
  Execution Time: 2.534 ms
 (6 rows)
 Example that is inlined:
 # explain (analyze, verbose) Select ST_AsGML(3, the_geom::geometry) from
 benchmark_7773a711c8441d4b494a51fd9feebeac7a9b9c734619398620293 limit 4;
 NOTICE:  Cache FOUND. Expected: 4326 1
 QUERY PLAN
  Limit  (cost=0.00..10.25 rows=4 width=32) (actual time=0.418..0.535
 rows=4 loops=1)
    Output: (_st_asgml(3, the_geom, 15, 0, NULL::text, NULL::text))
    ->  Seq Scan on
 (cost=0.00..1751884.83 rows=683833 width=32) (actual time=0.417..0.533
 rows=4 loops=1)
          Output: _st_asgml(3, the_geom, 15, 0, NULL::text, NULL::text)
  Planning Time: 0.152 ms
  Execution Time: 0.562 ms
 (6 rows)
 I'm not sure if this affects more functions (probably anything doing
 indirect calls within SQL is susceptible to this behaviour) but it's
 indeed a PITA.
 Is there a query context that we can hook us to that lives for the whole
 duration of the query (instead of a transaction / function)?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4674>
