[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-94-gb28cfb9
Thu Apr 30 03:45:30 PDT 2020
the project "PostGIS".
       via  b28cfb9b923d2190877065fc6dd47a1a6bd961bb (commit)
       via  5dbe34cb7b61f748e97712956913cf6230b6f5cf (commit)
       via  acd1ac8d2b883d268465b069c7aba73577800f0c (commit)
      from  591d0c69ba762a8fa4415b628a6f70ec985221d7 (commit)
revisions in full, below.
commit b28cfb9b923d2190877065fc6dd47a1a6bd961bb
Author: Raúl Marín <git at rmr.ninja>
Date:   Tue Apr 28 11:36:45 2020 +0200
    Reduce _COST_LOW and _COST_MEDIUM and change ST_Simplify
    Closes https://github.com/postgis/postgis/pull/556
    References #4490
diff --git a/NEWS b/NEWS
index 4bd10d3..e79c549 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,7 @@ Only tickets not included in 3.1.0alpha1
 * Enhancements *
   - #4651: ST_Simplify: Don't copy if nothing is removed (Raúl Marín)
   - #4657: Avoid De-TOASTing where possible (Paul Ramsey)
+  - #4490, Tweak function costs (Raúl Marín)
 * Bug fixes *
   - #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index e984fd2..1edec95 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3264,14 +3264,14 @@ CREATE OR REPLACE FUNCTION ST_Simplify(geometry, float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_simplify2d'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
-	_COST_MEDIUM;
+	_COST_LOW;
 -- Availability: 2.2.0
 CREATE OR REPLACE FUNCTION ST_Simplify(geometry, float8, boolean)
 	RETURNS geometry
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_SimplifyVW(geometry, float8)
diff --git a/postgis/sqldefines.h.in b/postgis/sqldefines.h.in
index 7f46244..5f81466 100644
--- a/postgis/sqldefines.h.in
+++ b/postgis/sqldefines.h.in
@@ -24,8 +24,8 @@
 #if POSTGIS_PGSQL_VERSION >= 120
 #define _COST_DEFAULT COST 1
-#define _COST_LOW COST 100
-#define _COST_MEDIUM COST 1000
+#define _COST_LOW COST 50
+#define _COST_MEDIUM COST 500
 #define _COST_HIGH COST 10000
 #else
commit 5dbe34cb7b61f748e97712956913cf6230b6f5cf
Date:   Mon Apr 27 17:32:05 2020 +0200
    postgis.sql: tabs
index 5ff0b9d..e984fd2 100644
@@ -11,10 +11,10 @@
 -- WARNING: Any change in this file must be evaluated for compatibility.
---          Changes cleanly handled by postgis_upgrade.sql are fine,
---	    other changes will require a bump in Major version.
---	    Currently only function replaceble by CREATE OR REPLACE
---	    are cleanly handled.
+--		Changes cleanly handled by postgis_upgrade.sql are fine,
+--		other changes will require a bump in Major version.
+--		Currently only function replaceble by CREATE OR REPLACE
+--		are cleanly handled.
@@ -453,8 +453,8 @@ CREATE OR REPLACE FUNCTION geometry_hash(geometry)
 -- Availability: 2.5.0
 CREATE OPERATOR CLASS hash_geometry_ops
 	DEFAULT FOR TYPE geometry USING hash AS
-    OPERATOR    1   = ,
-    FUNCTION    1   geometry_hash(geometry);
+	OPERATOR	1   = ,
+	FUNCTION	1   geometry_hash(geometry);
 -- GiST 2D GEOMETRY-over-GSERIALIZED INDEX
@@ -631,14 +631,14 @@ CREATE OR REPLACE FUNCTION geometry_distance_box(geom1 geometry, geom2 geometry)
 -- Availability: 2.0.0
 CREATE OPERATOR <-> (
-    LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_distance_centroid,
-    COMMUTATOR = '<->'
+	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_distance_centroid,
+	COMMUTATOR = '<->'
 CREATE OPERATOR <#> (
-    LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_distance_box,
-    COMMUTATOR = '<#>'
+	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_distance_box,
+	COMMUTATOR = '<#>'
@@ -933,9 +933,9 @@ CREATE OR REPLACE FUNCTION geometry_distance_centroid_nd(geometry,geometry)
 CREATE OPERATOR <<->> (
-    PROCEDURE = geometry_distance_centroid_nd,
-    COMMUTATOR = '<<->>'
+	PROCEDURE = geometry_distance_centroid_nd,
+	COMMUTATOR = '<<->>'
@@ -952,9 +952,9 @@ CREATE OR REPLACE FUNCTION geometry_distance_cpa(geometry, geometry)
 CREATE OPERATOR |=| (
-    PROCEDURE = geometry_distance_cpa,
-    COMMUTATOR = '|=|'
+	PROCEDURE = geometry_distance_cpa,
+	COMMUTATOR = '|=|'
@@ -1153,21 +1153,21 @@ CREATE OR REPLACE FUNCTION postgis_addbbox(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_addBBOX'
-        _COST_LOW;
+	_COST_LOW;
 -- Availability: 1.5.0
 CREATE OR REPLACE FUNCTION postgis_dropbbox(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_dropBBOX'
-        _COST_LOW;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION postgis_hasbbox(geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'LWGEOM_hasBBOX'
-        _COST_DEFAULT;
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_QuantizeCoordinates(g geometry, prec_x int, prec_y int DEFAULT NULL, prec_z int DEFAULT NULL, prec_m int DEFAULT NULL)
@@ -1773,17 +1773,17 @@ CREATE OR REPLACE FUNCTION ST_Polygonize (geometry[])
 CREATE OR REPLACE FUNCTION ST_ClusterIntersecting(geometry[])
-    RETURNS geometry[]
-    AS 'MODULE_PATHNAME',  'clusterintersecting_garray'
-    LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
-    _COST_HIGH;
+	RETURNS geometry[]
+	AS 'MODULE_PATHNAME',  'clusterintersecting_garray'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_ClusterWithin(geometry[], float8)
-    AS 'MODULE_PATHNAME',  'cluster_within_distance_garray'
-    _COST_HIGH;
+	AS 'MODULE_PATHNAME',  'cluster_within_distance_garray'
+	_COST_HIGH;
 -- Availability: 2.3
 CREATE OR REPLACE FUNCTION ST_ClusterDBSCAN (geometry, eps float8, minpoints int)
@@ -1893,14 +1893,14 @@ CREATE OR REPLACE FUNCTION ST_Scale(geometry,float8,float8,float8)
 	--AS 'SELECT ST_Affine($1,  $2, 0, 0,  0, $3, 0,  0, 0, $4,  0, 0, 0)'
 	AS 'SELECT @extschema at .ST_Scale($1, @extschema at .ST_MakePoint($2, $3, $4))'
 	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
-        _COST_LOW;
+	_COST_LOW;
 -- Availability: 1.2.2
 CREATE OR REPLACE FUNCTION ST_Scale(geometry,float8,float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Scale($1, $2, $3, 1)'
-        _COST_LOW;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Transscale(geometry,float8,float8,float8,float8)
@@ -1908,7 +1908,7 @@ CREATE OR REPLACE FUNCTION ST_Transscale(geometry,float8,float8,float8,float8)
 	AS 'SELECT @extschema at .ST_Affine($1,  $4, 0, 0,  0, $5, 0,
 		0, 0, 1,  $2 * $4, $3 * $5, 0)'
-        _COST_LOW;
+	_COST_LOW;
 -- Dumping
@@ -1941,7 +1941,7 @@ CREATE OR REPLACE FUNCTION ST_DumpRings(geometry)
 -- that returns a path and all the points that make up a particular geometry.
 CREATE OR REPLACE FUNCTION ST_DumpPoints(geometry)
-    RETURNS SETOF geometry_dump
+	RETURNS SETOF geometry_dump
 	AS 'MODULE_PATHNAME', 'LWGEOM_dumppoints'
 	_COST_HIGH;
@@ -1977,16 +1977,16 @@ CREATE OR REPLACE FUNCTION populate_geometry_columns(use_typmod boolean DEFAULT
 	RETURNS text AS
 DECLARE
-	inserted    integer;
-	oldcount    integer;
-	probed      integer;
-	stale       integer;
-	gcs         RECORD;
-	gc          RECORD;
-	gsrid       integer;
-	gndims      integer;
-	gtype       text;
-	query       text;
+	inserted	integer;
+	oldcount	integer;
+	probed	  integer;
+	stale	   integer;
+	gcs		 RECORD;
+	gc		  RECORD;
+	gsrid	   integer;
+	gndims	  integer;
+	gtype	   text;
+	query	   text;
 	gc_is_valid boolean;
 BEGIN
@@ -2029,9 +2029,9 @@ BEGIN
 	END LOOP;
 	IF oldcount > inserted THEN
-	    stale = oldcount-inserted;
+		stale = oldcount-inserted;
 	ELSE
-	    stale = 0;
+		stale = 0;
 	END IF;
 	RETURN 'probed:' ||probed|| ' inserted:'||inserted;
@@ -2066,15 +2066,15 @@ CREATE OR REPLACE FUNCTION populate_geometry_columns(tbl_oid oid, use_typmod boo
 	RETURNS integer AS
 DECLARE
-	gcs         RECORD;
-	gc          RECORD;
-	gc_old      RECORD;
-	gsrid       integer;
-	gndims      integer;
-	gtype       text;
-	query       text;
+	gcs		 RECORD;
+	gc		  RECORD;
+	gc_old	  RECORD;
+	gsrid	   integer;
+	gndims	  integer;
+	gtype	   text;
+	query	   text;
-	inserted    integer;
+	inserted	integer;
 	constraint_successful boolean := false;
 BEGIN
@@ -3804,20 +3804,20 @@ CREATE OR REPLACE FUNCTION ST_DelaunayTriangles(g1 geometry, tolerance float8 DE
 CREATE OR REPLACE FUNCTION _ST_Voronoi(g1 geometry, clip geometry DEFAULT NULL, tolerance float8 DEFAULT 0.0, return_polygons boolean DEFAULT true)
-       RETURNS geometry
-       AS 'MODULE_PATHNAME', 'ST_Voronoi'
-       LANGUAGE 'c' IMMUTABLE PARALLEL SAFE
-       _COST_HIGH;
+	   RETURNS geometry
+	   AS 'MODULE_PATHNAME', 'ST_Voronoi'
+	   LANGUAGE 'c' IMMUTABLE PARALLEL SAFE
+	   _COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_VoronoiPolygons(g1 geometry, tolerance float8 DEFAULT 0.0, extend_to geometry DEFAULT NULL)
-       RETURNS geometry
-       AS $$ SELECT @extschema at ._ST_Voronoi(g1, extend_to, tolerance, true) $$
-       LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
+	   RETURNS geometry
+	   AS $$ SELECT @extschema at ._ST_Voronoi(g1, extend_to, tolerance, true) $$
+	   LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
 CREATE OR REPLACE FUNCTION ST_VoronoiLines(g1 geometry, tolerance float8 DEFAULT 0.0, extend_to geometry DEFAULT NULL)
-       RETURNS geometry
-       AS $$ SELECT @extschema at ._ST_Voronoi(g1, extend_to, tolerance, false) $$
+	   RETURNS geometry
+	   AS $$ SELECT @extschema at ._ST_Voronoi(g1, extend_to, tolerance, false) $$
 -- Aggregates and their supporting functions
@@ -4536,14 +4536,14 @@ CREATE OR REPLACE FUNCTION ST_GeomFromGML(text)
 	RETURNS geometry
 	AS 'SELECT @extschema at ._ST_GeomFromGML($1, 0)'
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GMLToSQL(text)
 	RETURNS geometry
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GMLToSQL(text, int4)
@@ -4648,7 +4648,7 @@ CREATE OR REPLACE FUNCTION ST_AsGML(geom geometry, maxdecimaldigits int4 DEFAULT
 	RETURNS TEXT
 	AS $$ SELECT @extschema at ._ST_AsGML(2, $1, $2, $3, null, null); $$
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 -- ST_AsGML(version, geom, precision, option)
 -- Availability: 1.4.0
@@ -4661,7 +4661,7 @@ CREATE OR REPLACE FUNCTION ST_AsGML(version int4, geom geometry, maxdecimaldigit
 	RETURNS TEXT
 	AS $$ SELECT @extschema at ._ST_AsGML($1, $2, $3, $4, $5, $6); $$
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 -- KML OUTPUT
@@ -4701,14 +4701,14 @@ CREATE OR REPLACE FUNCTION json(geometry)
 	RETURNS json
 	AS 'MODULE_PATHNAME','geometry_to_json'
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 -- Availability: 3.0.0
 CREATE OR REPLACE FUNCTION jsonb(geometry)
 	RETURNS jsonb
 	AS 'MODULE_PATHNAME','geometry_to_jsonb'
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 CREATE CAST (geometry AS json) WITH FUNCTION json(geometry);
@@ -4725,35 +4725,35 @@ CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement)
 	RETURNS internal
 	AS 'MODULE_PATHNAME', 'pgis_asmvt_transfn'
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 -- Availability: 2.4.0
 CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text)
 	RETURNS internal
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, int4)
 	RETURNS internal
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, int4, text)
 	RETURNS internal
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, int4, text, text)
 	RETURNS internal
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION pgis_asmvt_finalfn(internal)
@@ -4853,7 +4853,7 @@ CREATE OR REPLACE FUNCTION ST_AsMVTGeom(geom geometry, bounds box2d, extent int4
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_AsMVTGeom'
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION postgis_libprotobuf_version()
@@ -5096,10 +5096,10 @@ CREATE OR REPLACE FUNCTION ST_AsText(geometry)
 -- PostGIS equivalent function: AsText(geometry, int4)
 CREATE OR REPLACE FUNCTION ST_AsText(geometry, int4)
-    RETURNS TEXT
-    AS 'MODULE_PATHNAME','LWGEOM_asText'
-    _COST_MEDIUM;
+	RETURNS TEXT
+	AS 'MODULE_PATHNAME','LWGEOM_asText'
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GeometryFromText(text)
@@ -5661,8 +5661,8 @@ CREATE OR REPLACE FUNCTION ST_SwapOrdinates(geom geometry, ords cstring)
 	_COST_LOW;
 -- NOTE: same as ST_SwapOrdinates(geometry, 'xy')
---       but slightly faster in that it doesn't need to parse ordinate
---       spec strings
+--	   but slightly faster in that it doesn't need to parse ordinate
+--	   spec strings
 CREATE OR REPLACE FUNCTION ST_FlipCoordinates(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_FlipCoordinates'
@@ -5865,7 +5865,7 @@ $$
 SELECT replace(replace(split_part(s.consrc, ' = ', 2), ')', ''), '(', '')::integer
 		 FROM pg_class c, pg_namespace n, pg_attribute a
 		 , (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
-		    FROM pg_constraint) AS s
+			FROM pg_constraint) AS s
 		 WHERE n.nspname = $1
 		 AND c.relname = $2
 		 AND a.attname = $3
@@ -5884,7 +5884,7 @@ $$
 SELECT  replace(split_part(s.consrc, ' = ', 2), ')', '')::integer
 		 AND c.relname = $2
 		 AND a.attname = $3
@@ -5905,7 +5905,7 @@ $$
 SELECT  replace(split_part(s.consrc, '''', 2), ')', '')::varchar
 		 AND c.relname = $2
 		 AND a.attname = $3
@@ -6141,7 +6141,7 @@ CREATE OR REPLACE FUNCTION ST_Square(size float8, cell_i integer, cell_j integer
 -- Availability: 3.1.0
 CREATE OR REPLACE FUNCTION ST_HexagonGrid(size float8, bounds geometry, OUT geom geometry, OUT i integer, OUT j integer)
-    RETURNS SETOF record
+	RETURNS SETOF record
 	AS 'MODULE_PATHNAME', 'ST_ShapeGrid'
 	PARALLEL SAFE
@@ -6149,7 +6149,7 @@ CREATE OR REPLACE FUNCTION ST_HexagonGrid(size float8, bounds geometry, OUT geom
 CREATE OR REPLACE FUNCTION ST_SquareGrid(size float8, bounds geometry, OUT geom geometry, OUT i integer, OUT j integer)
 	PARALLEL SAFE
@@ -6415,14 +6415,14 @@ CREATE OR REPLACE FUNCTION _ST_AsX3D(int4, geometry, int4, int4, text)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asX3D'
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 -- ST_AsX3D(geom, precision, options)
 CREATE OR REPLACE FUNCTION ST_AsX3D(geom geometry, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0)
 	RETURNS TEXT
 	AS $$SELECT @extschema at ._ST_AsX3D(3,$1,$2,$3,'');$$
-        _COST_MEDIUM;
+	_COST_MEDIUM;
 -- ST_Angle
@@ -6432,7 +6432,7 @@ CREATE OR REPLACE FUNCTION ST_AsX3D(geom geometry, maxdecimaldigits integer DEFA
 CREATE OR REPLACE FUNCTION ST_Angle(line1 geometry, line2 geometry)
 	RETURNS float8 AS 'SELECT ST_Angle(St_StartPoint($1), ST_EndPoint($1), St_StartPoint($2), ST_EndPoint($2))'
-        _COST_LOW;
+	_COST_LOW;
 -- make views and spatial_ref_sys public viewable --
 GRANT SELECT ON TABLE geography_columns TO public;
@@ -6444,7 +6444,7 @@ CREATE OR REPLACE FUNCTION ST_3DLineInterpolatePoint(geometry, float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_3DLineInterpolatePoint'
-        _COST_LOW;
+	_COST_LOW;
 -- moved to separate file cause its invovled
commit acd1ac8d2b883d268465b069c7aba73577800f0c
Date:   Mon Apr 27 17:24:28 2020 +0200
    Update function costs
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index 0c3b49f..3b43617 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -103,34 +103,35 @@ CREATE OR REPLACE FUNCTION ST_AsText(geography)
 	RETURNS TEXT
-	_COST_LOW;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_AsText(geography, int4)
 	RETURNS TEXT
-	_COST_LOW;
+	_COST_MEDIUM;
 -- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
 CREATE OR REPLACE FUNCTION ST_AsText(text)
 	RETURNS text AS
 	$$ SELECT @extschema at .ST_AsText($1::@extschema at .geometry);  $$
-	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
+	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
+        _COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GeographyFromText(text)
 	RETURNS geography
 	AS 'MODULE_PATHNAME','geography_from_text'
-	_COST_LOW;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GeogFromText(text)
 	RETURNS geography
-	_COST_LOW;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GeogFromWKB(bytea)
@@ -407,13 +408,14 @@ CREATE OR REPLACE FUNCTION ST_AsSVG(geog geography, rel int4 DEFAULT 0, maxdecim
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_svg'
-	_COST_LOW;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_AsSVG(text)
 	RETURNS text AS
 	$$ SELECT @extschema at .ST_AsSVG($1::@extschema at .geometry,0,15);  $$
+        _COST_MEDIUM;
 -- GML OUTPUT
@@ -428,20 +430,21 @@ CREATE OR REPLACE FUNCTION ST_AsGML(version int4, geog geography, maxdecimaldigi
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_gml'
-	_COST_LOW;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_AsGML(geog geography, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0, nprefix text DEFAULT 'gml', id text DEFAULT '')
 	RETURNS text
-	_COST_LOW;
+	_COST_MEDIUM;
 -- Change 2.0.0 to use base function
 CREATE OR REPLACE FUNCTION ST_AsGML(text)
 	RETURNS text AS
 	$$ SELECT @extschema at ._ST_AsGML(2,$1::@extschema at .geometry,15,0, NULL, NULL);  $$
+        _COST_MEDIUM;
 -- KML OUTPUT
@@ -453,14 +456,15 @@ CREATE OR REPLACE FUNCTION ST_AsKML(geog geography, maxdecimaldigits int4 DEFAUL
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_kml'
-	_COST_LOW;
+	_COST_MEDIUM;
 -- Deprecated 2.0.0
 CREATE OR REPLACE FUNCTION ST_AsKML(text)
 	RETURNS text AS
 	$$ SELECT @extschema at .ST_AsKML($1::@extschema at .geometry, 15);  $$
+        _COST_MEDIUM;
 -- GeoJson Output
@@ -470,14 +474,15 @@ CREATE OR REPLACE FUNCTION ST_AsGeoJson(geog geography, maxdecimaldigits int4 DE
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_geojson'
-	_COST_LOW;
+	_COST_MEDIUM;
 -- Deprecated in 2.0.0
 CREATE OR REPLACE FUNCTION ST_AsGeoJson(text)
 	RETURNS text AS
 	$$ SELECT @extschema at .ST_AsGeoJson($1::@extschema at .geometry, 9, 0);  $$
+        _COST_MEDIUM;
@@ -703,13 +708,14 @@ CREATE OR REPLACE FUNCTION ST_AsEWKT(geography)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asEWKT'
-	_COST_LOW;
+	_COST_MEDIUM;
 -- Availability: 2.0.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
 CREATE OR REPLACE FUNCTION ST_AsEWKT(text)
 	RETURNS text AS
 	$$ SELECT @extschema at .ST_AsEWKT($1::@extschema at .geometry);  $$
+        _COST_MEDIUM;
 CREATE OR REPLACE FUNCTION GeometryType(geography)
index 62f8f19..5ff0b9d 100644
@@ -350,32 +350,38 @@ CREATE TYPE gidx (
 CREATE OR REPLACE FUNCTION geometry_lt(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'lwgeom_lt'
-	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_le(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'lwgeom_le'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_gt(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'lwgeom_gt'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_ge(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'lwgeom_ge'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_eq(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'lwgeom_eq'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_cmp(geom1 geometry, geom2 geometry)
 	RETURNS integer
 	AS 'MODULE_PATHNAME', 'lwgeom_cmp'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_sortsupport(internal)
@@ -582,7 +588,7 @@ CREATE OR REPLACE FUNCTION geometry_overlaps(geom1 geometry, geom2 geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_overlaps_2d'
-	_COST_LOW;
+	_COST_DEFAULT;
 -- Availability: 0.1.0
 -- Changed: 2.0.0 use gserialized selectivity estimators
@@ -598,7 +604,7 @@ CREATE OR REPLACE FUNCTION geometry_same(geom1 geometry, geom2 geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_same_2d'
-	_COST_LOW;
+	_COST_DEFAULT;
 CREATE OPERATOR ~= (
@@ -619,8 +625,9 @@ CREATE OR REPLACE FUNCTION geometry_distance_centroid(geom1 geometry, geom2 geom
 	RETURNS float8
-  AS 'MODULE_PATHNAME', 'gserialized_distance_box_2d'
+	AS 'MODULE_PATHNAME', 'gserialized_distance_box_2d'
+	_COST_DEFAULT;
@@ -638,13 +645,15 @@ CREATE OPERATOR <#> (
 CREATE OR REPLACE FUNCTION geometry_contains(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_contains_2d'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_within(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_within_2d'
+	_COST_DEFAULT;
 CREATE OPERATOR @ (
@@ -664,7 +673,8 @@ CREATE OPERATOR ~ (
 CREATE OR REPLACE FUNCTION geometry_left(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_left_2d'
+	_COST_DEFAULT;
 CREATE OPERATOR << (
@@ -677,7 +687,8 @@ CREATE OPERATOR << (
 CREATE OR REPLACE FUNCTION geometry_overleft(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_overleft_2d'
+	_COST_DEFAULT;
 CREATE OPERATOR &< (
@@ -689,7 +700,8 @@ CREATE OPERATOR &< (
 CREATE OR REPLACE FUNCTION geometry_below(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_below_2d'
+	_COST_DEFAULT;
 CREATE OPERATOR <<| (
@@ -702,7 +714,8 @@ CREATE OPERATOR <<| (
 CREATE OR REPLACE FUNCTION geometry_overbelow(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_overbelow_2d'
+	_COST_DEFAULT;
 CREATE OPERATOR &<| (
@@ -714,7 +727,8 @@ CREATE OPERATOR &<| (
 CREATE OR REPLACE FUNCTION geometry_overright(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_overright_2d'
+	_COST_DEFAULT;
 CREATE OPERATOR &> (
@@ -726,7 +740,8 @@ CREATE OPERATOR &> (
 CREATE OR REPLACE FUNCTION geometry_right(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_right_2d'
+	_COST_DEFAULT;
 CREATE OPERATOR >> (
@@ -739,7 +754,8 @@ CREATE OPERATOR >> (
 CREATE OR REPLACE FUNCTION geometry_overabove(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_overabove_2d'
+	_COST_DEFAULT;
 CREATE OPERATOR |&> (
@@ -751,7 +767,8 @@ CREATE OPERATOR |&> (
 CREATE OR REPLACE FUNCTION geometry_above(geom1 geometry, geom2 geometry)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'gserialized_above_2d'
+	_COST_DEFAULT;
 CREATE OPERATOR |>> (
@@ -799,43 +816,50 @@ CREATE OPERATOR CLASS gist_geometry_ops_2d
 CREATE OR REPLACE FUNCTION geometry_gist_consistent_nd(internal,geometry,int4)
 	RETURNS bool
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent'
-	LANGUAGE 'c' PARALLEL SAFE;
+	LANGUAGE 'c' PARALLEL SAFE
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_gist_compress_nd(internal)
 	RETURNS internal
 	AS 'MODULE_PATHNAME','gserialized_gist_compress'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_gist_penalty_nd(internal,internal,internal)
 	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_penalty'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_gist_picksplit_nd(internal, internal)
 	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_picksplit'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_gist_union_nd(bytea, internal)
 	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_union'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_gist_same_nd(geometry, geometry, internal)
 	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_same'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_gist_decompress_nd(internal)
 	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_decompress'
+	_COST_DEFAULT;
 -- N-D GEOMETRY Operators
@@ -845,7 +869,8 @@ CREATE OR REPLACE FUNCTION geometry_gist_decompress_nd(internal)
 CREATE OR REPLACE FUNCTION geometry_overlaps_nd(geometry, geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_overlaps'
+	_COST_DEFAULT;
 CREATE OPERATOR &&& (
@@ -859,7 +884,8 @@ CREATE OPERATOR &&& (
 CREATE OR REPLACE FUNCTION geometry_contains_nd(geometry, geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_contains'
+	_COST_DEFAULT;
 CREATE OPERATOR ~~ (
@@ -873,7 +899,8 @@ CREATE OPERATOR ~~ (
 CREATE OR REPLACE FUNCTION geometry_within_nd(geometry, geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_within'
+	_COST_DEFAULT;
 CREATE OPERATOR @@ (
@@ -887,7 +914,8 @@ CREATE OPERATOR @@ (
 CREATE OR REPLACE FUNCTION geometry_same_nd(geometry, geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_same'
+	_COST_DEFAULT;
 CREATE OPERATOR ~~= (
@@ -919,7 +947,8 @@ CREATE OPERATOR <<->> (
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'ST_DistanceCPA'
+	_COST_HIGH;
@@ -932,7 +961,8 @@ CREATE OPERATOR |=| (
 CREATE OR REPLACE FUNCTION geometry_gist_distance_nd(internal,geometry,int4)
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'gserialized_gist_distance'
+	_COST_DEFAULT;
 CREATE OPERATOR CLASS gist_geometry_ops_nd
@@ -963,13 +993,15 @@ CREATE OPERATOR CLASS gist_geometry_ops_nd
 CREATE OR REPLACE FUNCTION ST_ShiftLongitude(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_longitude_shift'
+	_COST_LOW;
 -- Availability: 2.3.0
 CREATE OR REPLACE FUNCTION ST_WrapX(geom geometry, wrap float8, move float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_WrapX'
+	_COST_LOW;
 --  BOX3D FUNCTIONS
@@ -979,37 +1011,43 @@ CREATE OR REPLACE FUNCTION ST_WrapX(geom geometry, wrap float8, move float8)
 CREATE OR REPLACE FUNCTION ST_XMin(box3d)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','BOX3D_xmin'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_YMin(box3d)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','BOX3D_ymin'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_ZMin(box3d)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','BOX3D_zmin'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_XMax(box3d)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','BOX3D_xmax'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_YMax(box3d)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','BOX3D_ymax'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_ZMax(box3d)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','BOX3D_zmax'
+	_COST_DEFAULT;
 --  BOX2D FUNCTIONS
@@ -1019,25 +1057,29 @@ CREATE OR REPLACE FUNCTION ST_ZMax(box3d)
 CREATE OR REPLACE FUNCTION ST_Expand(box2d,float8)
 	RETURNS box2d
 	AS 'MODULE_PATHNAME', 'BOX2D_expand'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_Expand(box box2d, dx float8, dy float8)
 	RETURNS box2d
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION postgis_getbbox(geometry)
 	RETURNS box2d
 	AS 'MODULE_PATHNAME','LWGEOM_to_BOX2DF'
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_MakeBox2d(geom1 geometry, geom2 geometry)
 	RETURNS box2d
 	AS 'MODULE_PATHNAME', 'BOX2D_construct'
+	_COST_DEFAULT;
 -- ST_ESTIMATED_EXTENT( <schema name>, <table name>, <column name> )
@@ -1110,19 +1152,22 @@ LANGUAGE 'plpgsql' STABLE STRICT PARALLEL SAFE;
 	RETURNS geometry
+        _COST_LOW;
 	RETURNS geometry
+        _COST_LOW;
 	RETURNS bool
+        _COST_DEFAULT;
@@ -1140,7 +1185,7 @@ CREATE OR REPLACE FUNCTION ST_MemSize(geometry)
 	RETURNS int4
 	AS 'MODULE_PATHNAME', 'LWGEOM_mem_size'
-	_COST_LOW;
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_Summary(geometry)
@@ -1439,27 +1484,28 @@ CREATE OR REPLACE FUNCTION ST_Reverse(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_reverse'
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_ForcePolygonCW(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_clockwise_poly'
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_ForcePolygonCCW(geometry)
 	RETURNS geometry
 	AS $$ SELECT @extschema at .ST_Reverse(@extschema at .ST_ForcePolygonCW($1)) $$
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_ForceRHR(geometry)
 	RETURNS geometry
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION postgis_noop(geometry)
@@ -1480,7 +1526,7 @@ CREATE OR REPLACE FUNCTION ST_Normalize(geom geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_Normalize'
-	_COST_LOW;
+	_COST_MEDIUM;
 -- Deprecation in 1.5.0
 CREATE OR REPLACE FUNCTION ST_zmflag(geometry)
@@ -1501,21 +1547,21 @@ CREATE OR REPLACE FUNCTION ST_AsEWKT(geometry)
 	RETURNS TEXT
-	_COST_LOW;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_AsTWKB(geom geometry, prec int4 default NULL, prec_z int4 default NULL, prec_m int4 default NULL, with_sizes boolean default NULL, with_boxes boolean default NULL)
 	RETURNS bytea
 	AS 'MODULE_PATHNAME','TWKBFromLWGEOM'
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_AsTWKB(geom geometry[], ids bigint[], prec int4 default NULL, prec_z int4 default NULL, prec_m int4 default NULL, with_sizes boolean default NULL, with_boxes boolean default NULL)
 	RETURNS bytea
 	AS 'MODULE_PATHNAME','TWKBFromLWGEOMArray'
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_AsEWKB(geometry)
@@ -1762,95 +1808,107 @@ CREATE OR REPLACE FUNCTION ST_Affine(geometry,float8,float8,float8,float8,float8
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_affine'
-	_COST_MEDIUM; -- reset cost, see #3675
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Affine(geometry,float8,float8,float8,float8,float8,float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Affine($1,  $2, $3, 0,  $4, $5, 0,  0, 0, 1,  $6, $7, 0)'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Rotate(geometry,float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Affine($1,  cos($2), -sin($2), 0,  sin($2), cos($2), 0,  0, 0, 1,  0, 0, 0)'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Rotate(geometry,float8,float8,float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Affine($1,  cos($2), -sin($2), 0,  sin($2),  cos($2), 0, 0, 0, 1,	$3 - cos($2) * $3 + sin($2) * $4, $4 - sin($2) * $3 - cos($2) * $4, 0)'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Rotate(geometry,float8,geometry)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Affine($1,  cos($2), -sin($2), 0,  sin($2),  cos($2), 0, 0, 0, 1, @extschema at .ST_X($3) - cos($2) * @extschema at .ST_X($3) + sin($2) * @extschema at .ST_Y($3), @extschema at .ST_Y($3) - sin($2) * @extschema at .ST_X($3) - cos($2) * @extschema at .ST_Y($3), 0)'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_RotateZ(geometry,float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Rotate($1, $2)'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_RotateX(geometry,float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Affine($1, 1, 0, 0, 0, cos($2), -sin($2), 0, sin($2), cos($2), 0, 0, 0)'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_RotateY(geometry,float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Affine($1,  cos($2), 0, sin($2),  0, 1, 0,  -sin($2), 0, cos($2), 0,  0, 0)'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Translate(geometry,float8,float8,float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Affine($1, 1, 0, 0, 0, 1, 0, 0, 0, 1, $2, $3, $4)'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Translate(geometry,float8,float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Translate($1, $2, $3, 0)'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Scale(geometry,geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_Scale'
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Scale(geometry,geometry,origin geometry)
 	RETURNS geometry
-	_COST_MEDIUM;
+	_COST_LOW;
 	RETURNS geometry
+        _COST_LOW;
 	RETURNS geometry
+        _COST_LOW;
 	RETURNS geometry
+        _COST_LOW;
 -- Dumping
@@ -1886,7 +1944,7 @@ CREATE OR REPLACE FUNCTION ST_DumpPoints(geometry)
-	COST 100;
+	_COST_HIGH;
 -- SPATIAL_REF_SYS
@@ -2680,13 +2738,13 @@ CREATE OR REPLACE FUNCTION ST_SetSRID(geom geometry, srid int4)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_set_srid'
-	_COST_LOW;
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_SRID(geom geometry)
 	RETURNS int4
 	AS 'MODULE_PATHNAME','LWGEOM_get_srid'
-	_COST_LOW;
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION postgis_transform_geometry(geom geometry, text, text, int)
 	RETURNS geometry
@@ -2699,27 +2757,30 @@ CREATE OR REPLACE FUNCTION ST_Transform(geometry,integer)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','transform'
-	_COST_MEDIUM;
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, to_proj text)
 	RETURNS geometry AS
 	'SELECT @extschema at .postgis_transform_geometry($1, proj4text, $2, 0)
 	FROM spatial_ref_sys WHERE srid=@extschema at .ST_SRID($1);'
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, from_proj text, to_proj text)
 	RETURNS geometry AS
 	'SELECT @extschema at .postgis_transform_geometry($1, $2, $3, 0)'
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, from_proj text, to_srid integer)
 	RETURNS geometry AS
 	'SELECT @extschema at .postgis_transform_geometry($1, $2, proj4text, $3)
 	FROM spatial_ref_sys WHERE srid=$3;'
+	_COST_HIGH;
 -- POSTGIS_VERSION()
@@ -3203,17 +3264,17 @@ CREATE OR REPLACE FUNCTION ST_Simplify(geometry, float8)
 	RETURNS geometry
-	_COST_HIGH;
+	_COST_MEDIUM;
 	RETURNS geometry
-	_COST_HIGH;
+	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_SimplifyVW(geometry,  float8)
+CREATE OR REPLACE FUNCTION ST_SimplifyVW(geometry, float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_SetEffectiveArea'
@@ -3224,21 +3285,21 @@ CREATE OR REPLACE FUNCTION ST_SetEffectiveArea(geometry,  float8 default -1, int
 	RETURNS geometry
-	_COST_MEDIUM;
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_FilterByM(geometry, double precision, double precision default null, boolean default false)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_FilterByM'
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_ChaikinSmoothing(geometry, integer default 1, boolean default false)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_ChaikinSmoothing'
-	_COST_HIGH;
+	_COST_MEDIUM;
 -- ST_SnapToGrid(input, xoff, yoff, xsize, ysize)
@@ -3246,7 +3307,7 @@ CREATE OR REPLACE FUNCTION ST_SnapToGrid(geometry, float8, float8, float8, float
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_snaptogrid'
-	_COST_MEDIUM;
+	_COST_LOW;
 -- ST_SnapToGrid(input, xsize, ysize) # offsets=0
@@ -3254,14 +3315,15 @@ CREATE OR REPLACE FUNCTION ST_SnapToGrid(geometry, float8, float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_SnapToGrid($1, 0, 0, $2, $3)'
-	_COST_MEDIUM;
+	_COST_LOW;
 -- ST_SnapToGrid(input, size) # xsize=ysize=size, offsets=0
 CREATE OR REPLACE FUNCTION ST_SnapToGrid(geometry, float8)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_SnapToGrid($1, 0, 0, $2, $2)'
+	_COST_LOW;
 -- ST_SnapToGrid(input, point_offsets, xsize, ysize, zsize, msize)
@@ -3269,7 +3331,7 @@ CREATE OR REPLACE FUNCTION ST_SnapToGrid(geom1 geometry, geom2 geometry, float8,
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_snaptogrid_pointoff'
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Segmentize(geometry, float8)
@@ -3369,7 +3431,8 @@ CREATE OR REPLACE FUNCTION ST_Buffer(geom geometry, radius float8, options text
 CREATE OR REPLACE FUNCTION ST_Buffer(geom geometry, radius float8, quadsegs integer)
 	RETURNS geometry
 	AS $$ SELECT @extschema at .ST_Buffer($1, $2, CAST('quad_segs='||CAST($3 AS text) as text)) $$
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_MinimumBoundingRadius(geometry, OUT center geometry, OUT radius double precision)
@@ -3404,14 +3467,14 @@ CREATE OR REPLACE FUNCTION ST_GeneratePoints(area geometry, npoints integer)
 RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_GeneratePoints'
 	LANGUAGE 'c' VOLATILE STRICT PARALLEL SAFE
-	_COST_HIGH;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GeneratePoints(area geometry, npoints integer, seed integer)
 RETURNS geometry
-	_COST_HIGH;
+	_COST_MEDIUM;
 -- PostGIS equivalent function: convexhull(geometry)
 CREATE OR REPLACE FUNCTION ST_ConvexHull(geometry)
@@ -3456,13 +3519,15 @@ CREATE OR REPLACE FUNCTION ST_IsValidReason(geometry, int4)
 		SELECT (@extschema at .ST_isValidDetail($1, $2)).*
 	) foo
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_IsValid(geometry, int4)
 	RETURNS boolean
 	AS 'SELECT (@extschema at .ST_isValidDetail($1, $2)).valid'
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_HausdorffDistance(geom1 geometry, geom2 geometry)
@@ -3545,14 +3610,14 @@ CREATE OR REPLACE FUNCTION ST_RemoveRepeatedPoints(geom geometry, tolerance floa
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_RemoveRepeatedPoints'
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_ClipByBox2d(geom geometry, box box2d)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_ClipByBox2d'
-	_COST_HIGH;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_Subdivide(geom geometry, maxvertices integer DEFAULT 256)
@@ -3762,19 +3827,22 @@ CREATE OR REPLACE FUNCTION ST_VoronoiLines(g1 geometry, tolerance float8 DEFAULT
 CREATE OR REPLACE FUNCTION ST_CombineBBox(box3d,geometry)
 	RETURNS box3d
 	AS 'MODULE_PATHNAME', 'BOX3D_combine'
-	LANGUAGE 'c' IMMUTABLE PARALLEL SAFE;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_CombineBBox(box3d,box3d)
 	RETURNS box3d
 	AS 'MODULE_PATHNAME', 'BOX3D_combine_BOX3D'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_CombineBbox(box2d,geometry)
 	RETURNS box2d
 	AS 'MODULE_PATHNAME', 'BOX2D_combine'
+	_COST_LOW;
 -- Changed: 2.2.0 to use non-deprecated ST_CombineBBox (r13535)
@@ -3803,7 +3871,8 @@ CREATE AGGREGATE ST_3DExtent(geometry)(
 CREATE OR REPLACE FUNCTION ST_Collect(geom1 geometry, geom2 geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_collect'
+	_COST_LOW;
 -- Changed: 2.3.0 to support PostgreSQL 9.6
@@ -3819,7 +3888,8 @@ CREATE AGGREGATE ST_MemCollect(geometry)(
 CREATE OR REPLACE FUNCTION ST_Collect(geometry[])
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_collect_garray'
+	_COST_LOW;
@@ -3837,69 +3907,79 @@ CREATE AGGREGATE ST_MemUnion(geometry) (
 CREATE OR REPLACE FUNCTION pgis_geometry_accum_transfn(internal, geometry)
 	RETURNS internal
+	_COST_LOW;
 -- Changed: 2.5.0 use 'internal' transfer type
 CREATE OR REPLACE FUNCTION pgis_geometry_accum_transfn(internal, geometry, float8)
 	RETURNS internal
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION pgis_geometry_accum_transfn(internal, geometry, float8, int)
 	RETURNS internal
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION pgis_geometry_union_finalfn(internal)
 	RETURNS geometry
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION pgis_geometry_collect_finalfn(internal)
 	RETURNS geometry
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION pgis_geometry_polygonize_finalfn(internal)
 	RETURNS geometry
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION pgis_geometry_clusterintersecting_finalfn(internal)
 	RETURNS geometry[]
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION pgis_geometry_clusterwithin_finalfn(internal)
 	RETURNS geometry[]
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION pgis_geometry_makeline_finalfn(internal)
 	RETURNS geometry
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_Union (geometry[])
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','pgis_union_geometry_array'
+	_COST_HIGH;
 -- Changed but upgrader helper no touch: 2.4.0 marked parallel safe
@@ -4425,7 +4505,7 @@ CREATE OR REPLACE FUNCTION ST_IsCollection(geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'ST_IsCollection'
-	_COST_MEDIUM;
+	_COST_DEFAULT;
 -- Deprecation in 1.2.3
 -- TODO: drop in 2.0.0 !
@@ -4455,13 +4535,15 @@ CREATE OR REPLACE FUNCTION ST_GeomFromGML(text, int4)
 	RETURNS geometry
+        _COST_MEDIUM;
 	RETURNS geometry
+        _COST_MEDIUM;
@@ -4529,7 +4611,7 @@ CREATE OR REPLACE FUNCTION ST_AsEncodedPolyline(geom geometry, nprecision int4 D
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asEncodedPolyline'
-	_COST_LOW;
+	_COST_MEDIUM;
@@ -4542,7 +4624,7 @@ CREATE OR REPLACE FUNCTION ST_AsSVG(geom geometry, rel int4 DEFAULT 0, maxdecima
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asSVG'
-	_COST_LOW;
+	_COST_MEDIUM;
 -- GML OUTPUT
@@ -4565,7 +4647,8 @@ CREATE OR REPLACE FUNCTION _ST_AsGML(int4, geometry, int4, int4, text, text)
 CREATE OR REPLACE FUNCTION ST_AsGML(geom geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0)
 	RETURNS TEXT
+        _COST_MEDIUM;
@@ -4577,7 +4660,8 @@ CREATE OR REPLACE FUNCTION ST_AsGML(geom geometry, maxdecimaldigits int4 DEFAULT
 CREATE OR REPLACE FUNCTION ST_AsGML(version int4, geom geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0, nprefix text DEFAULT null, id text DEFAULT null)
 	RETURNS TEXT
+        _COST_MEDIUM;
 -- KML OUTPUT
@@ -4589,7 +4673,7 @@ CREATE OR REPLACE FUNCTION ST_AsKML(geom geometry, maxdecimaldigits int4 DEFAULT
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asKML'
-	_COST_LOW;
+	_COST_MEDIUM;
 -- GEOJSON OUTPUT
@@ -4603,26 +4687,28 @@ CREATE OR REPLACE FUNCTION ST_AsGeoJson(geom geometry, maxdecimaldigits int4 DEF
 	RETURNS text
 	AS 'MODULE_PATHNAME','LWGEOM_asGeoJson'
-	_COST_LOW;
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', maxdecimaldigits int4 DEFAULT 9, pretty_bool bool DEFAULT false)
 	RETURNS text
 	AS 'MODULE_PATHNAME','ST_AsGeoJsonRow'
 	LANGUAGE 'c' STABLE STRICT PARALLEL SAFE
-	_COST_LOW;
+	_COST_MEDIUM;
 	RETURNS json
+        _COST_MEDIUM;
 	RETURNS jsonb
+        _COST_MEDIUM;
@@ -4638,31 +4724,36 @@ CREATE CAST (geometry AS jsonb) WITH FUNCTION jsonb(geometry);
 	RETURNS internal
+        _COST_MEDIUM;
 	RETURNS internal
+        _COST_MEDIUM;
 	RETURNS internal
+        _COST_MEDIUM;
 	RETURNS internal
+        _COST_MEDIUM;
 	RETURNS internal
+        _COST_MEDIUM;
@@ -4761,7 +4852,8 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text, text)
 CREATE OR REPLACE FUNCTION ST_AsMVTGeom(geom geometry, bounds box2d, extent int4 default 4096, buffer int4 default 256, clip_geom bool default true)
 	RETURNS geometry
+        _COST_MEDIUM;
@@ -4778,13 +4870,15 @@ CREATE OR REPLACE FUNCTION postgis_libprotobuf_version()
 CREATE OR REPLACE FUNCTION pgis_asgeobuf_transfn(internal, anyelement)
 	RETURNS internal
 	AS 'MODULE_PATHNAME', 'pgis_asgeobuf_transfn'
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION pgis_asgeobuf_transfn(internal, anyelement, text)
 	RETURNS internal
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION pgis_asgeobuf_finalfn(internal)
@@ -4821,7 +4915,7 @@ CREATE OR REPLACE FUNCTION ST_GeoHash(geom geometry, maxchars int4 DEFAULT 0)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME', 'ST_GeoHash'
-	_COST_MEDIUM;
+	_COST_LOW;
 -- GeoHash input
@@ -4832,21 +4926,21 @@ CREATE OR REPLACE FUNCTION ST_Box2dFromGeoHash(text, int4 DEFAULT NULL)
 	RETURNS box2d
 	AS 'MODULE_PATHNAME','box2d_from_geohash'
-	_COST_MEDIUM;
+	_COST_LOW;
 -- ST_PointFromGeoHash(geohash text, precision int4)
 CREATE OR REPLACE FUNCTION ST_PointFromGeoHash(text, int4 DEFAULT NULL)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','point_from_geohash'
-	_COST_MEDIUM;
+	_COST_LOW;
 -- ST_GeomFromGeoHash(geohash text, precision int4)
 CREATE OR REPLACE FUNCTION ST_GeomFromGeoHash(text, int4 DEFAULT NULL)
 	RETURNS geometry
 	AS $$ SELECT CAST(@extschema at .ST_Box2dFromGeoHash($1, $2) AS geometry); $$
-	_COST_MEDIUM;
+	_COST_LOW;
 -- OGC defined
@@ -4912,14 +5006,14 @@ CREATE OR REPLACE FUNCTION GeometryType(geometry)
 	RETURNS text
 	AS 'MODULE_PATHNAME', 'LWGEOM_getTYPE'
-	_COST_LOW;
+	_COST_DEFAULT;
 -- Not quite equivalent to GeometryType
 CREATE OR REPLACE FUNCTION ST_GeometryType(geometry)
 	RETURNS text
 	AS 'MODULE_PATHNAME', 'geometry_geometrytype'
-	_COST_LOW;
+	_COST_DEFAULT;
 -- PostGIS equivalent function: PointN(geometry,integer)
 CREATE OR REPLACE FUNCTION ST_PointN(geometry,integer)
@@ -4936,7 +5030,8 @@ CREATE OR REPLACE FUNCTION ST_NumPatches(geometry)
 	THEN @extschema at .ST_NumGeometries($1)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_PatchN(geometry, integer)
@@ -4946,7 +5041,8 @@ CREATE OR REPLACE FUNCTION ST_PatchN(geometry, integer)
 	THEN @extschema at .ST_GeometryN($1, $2)
 	ELSE NULL END
+	_COST_LOW;
 -- PostGIS equivalent function of old StartPoint(geometry))
 CREATE OR REPLACE FUNCTION ST_StartPoint(geometry)
@@ -5049,7 +5145,8 @@ CREATE OR REPLACE FUNCTION ST_PointFromText(text)
 	THEN @extschema at .ST_GeomFromText($1)
 	ELSE NULL END
+	_COST_MEDIUM;
 -- PostGIS equivalent function: PointFromText(text, int4)
 -- TODO: improve this ... by not duplicating constructor time.
@@ -5060,7 +5157,8 @@ CREATE OR REPLACE FUNCTION ST_PointFromText(text, int4)
 	THEN @extschema at .ST_GeomFromText($1, $2)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_LineFromText(text)
@@ -5070,7 +5168,8 @@ CREATE OR REPLACE FUNCTION ST_LineFromText(text)
 	ELSE NULL END
+	_COST_MEDIUM;
 -- PostGIS equivalent function: LineFromText(text, int4)
 CREATE OR REPLACE FUNCTION ST_LineFromText(text, int4)
@@ -5080,7 +5179,8 @@ CREATE OR REPLACE FUNCTION ST_LineFromText(text, int4)
 	THEN @extschema at .ST_GeomFromText($1,$2)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_PolyFromText(text)
@@ -5090,7 +5190,8 @@ CREATE OR REPLACE FUNCTION ST_PolyFromText(text)
 	ELSE NULL END
+	_COST_MEDIUM;
 -- PostGIS equivalent function: ST_PolygonFromText(text, int4)
 CREATE OR REPLACE FUNCTION ST_PolyFromText(text, int4)
@@ -5100,19 +5201,22 @@ CREATE OR REPLACE FUNCTION ST_PolyFromText(text, int4)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_PolygonFromText(text, int4)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_PolyFromText($1, $2)'
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_PolygonFromText(text)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_PolyFromText($1)'
+	_COST_MEDIUM;
 -- PostGIS equivalent function: MLineFromText(text, int4)
 CREATE OR REPLACE FUNCTION ST_MLineFromText(text, int4)
@@ -5123,7 +5227,8 @@ CREATE OR REPLACE FUNCTION ST_MLineFromText(text, int4)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_MLineFromText(text)
@@ -5133,19 +5238,22 @@ CREATE OR REPLACE FUNCTION ST_MLineFromText(text)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_MultiLineStringFromText(text)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_MLineFromText($1)'
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_MultiLineStringFromText(text, int4)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_MLineFromText($1, $2)'
+	_COST_MEDIUM;
 -- PostGIS equivalent function: MPointFromText(text, int4)
 CREATE OR REPLACE FUNCTION ST_MPointFromText(text, int4)
@@ -5155,7 +5263,8 @@ CREATE OR REPLACE FUNCTION ST_MPointFromText(text, int4)
 	THEN ST_GeomFromText($1, $2)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_MPointFromText(text)
@@ -5165,13 +5274,15 @@ CREATE OR REPLACE FUNCTION ST_MPointFromText(text)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_MultiPointFromText(text)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_MPointFromText($1)'
+	_COST_MEDIUM;
 -- PostGIS equivalent function: MPolyFromText(text, int4)
 CREATE OR REPLACE FUNCTION ST_MPolyFromText(text, int4)
@@ -5181,7 +5292,8 @@ CREATE OR REPLACE FUNCTION ST_MPolyFromText(text, int4)
 	ELSE NULL END
+	_COST_MEDIUM;
 --Availability: 1.2.2
 CREATE OR REPLACE FUNCTION ST_MPolyFromText(text)
@@ -5191,19 +5303,22 @@ CREATE OR REPLACE FUNCTION ST_MPolyFromText(text)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_MultiPolygonFromText(text, int4)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_MPolyFromText($1, $2)'
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_MultiPolygonFromText(text)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_MPolyFromText($1)'
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GeomCollFromText(text, int4)
@@ -5214,7 +5329,8 @@ CREATE OR REPLACE FUNCTION ST_GeomCollFromText(text, int4)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GeomCollFromText(text)
@@ -5225,19 +5341,22 @@ CREATE OR REPLACE FUNCTION ST_GeomCollFromText(text)
 	ELSE NULL END
+	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_GeomFromWKB(bytea)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_from_WKB'
+	_COST_LOW;
 -- PostGIS equivalent function: GeomFromWKB(bytea, int)
 CREATE OR REPLACE FUNCTION ST_GeomFromWKB(bytea, int)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_SetSRID(@extschema at .ST_GeomFromWKB($1), $2)'
+	_COST_LOW;
 -- PostGIS equivalent function: PointFromWKB(bytea, int)
 CREATE OR REPLACE FUNCTION ST_PointFromWKB(bytea, int)
@@ -5247,7 +5366,8 @@ CREATE OR REPLACE FUNCTION ST_PointFromWKB(bytea, int)
 	THEN @extschema at .ST_GeomFromWKB($1, $2)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_PointFromWKB(bytea)
@@ -5257,7 +5377,8 @@ CREATE OR REPLACE FUNCTION ST_PointFromWKB(bytea)
 	THEN @extschema at .ST_GeomFromWKB($1)
 	ELSE NULL END
+	_COST_LOW;
 -- PostGIS equivalent function: LineFromWKB(bytea, int)
 CREATE OR REPLACE FUNCTION ST_LineFromWKB(bytea, int)
@@ -5267,7 +5388,8 @@ CREATE OR REPLACE FUNCTION ST_LineFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_LineFromWKB(bytea)
@@ -5277,7 +5399,8 @@ CREATE OR REPLACE FUNCTION ST_LineFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_LinestringFromWKB(bytea, int)
@@ -5287,7 +5410,8 @@ CREATE OR REPLACE FUNCTION ST_LinestringFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_LinestringFromWKB(bytea)
@@ -5297,7 +5421,8 @@ CREATE OR REPLACE FUNCTION ST_LinestringFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 -- PostGIS equivalent function: PolyFromWKB(text, int)
 CREATE OR REPLACE FUNCTION ST_PolyFromWKB(bytea, int)
@@ -5307,7 +5432,8 @@ CREATE OR REPLACE FUNCTION ST_PolyFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_PolyFromWKB(bytea)
@@ -5317,7 +5443,8 @@ CREATE OR REPLACE FUNCTION ST_PolyFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_PolygonFromWKB(bytea, int)
@@ -5327,7 +5454,8 @@ CREATE OR REPLACE FUNCTION ST_PolygonFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_PolygonFromWKB(bytea)
@@ -5337,7 +5465,8 @@ CREATE OR REPLACE FUNCTION ST_PolygonFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 -- PostGIS equivalent function: MPointFromWKB(text, int)
 CREATE OR REPLACE FUNCTION ST_MPointFromWKB(bytea, int)
@@ -5347,7 +5476,8 @@ CREATE OR REPLACE FUNCTION ST_MPointFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_MPointFromWKB(bytea)
@@ -5357,7 +5487,8 @@ CREATE OR REPLACE FUNCTION ST_MPointFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_MultiPointFromWKB(bytea, int)
@@ -5367,7 +5498,8 @@ CREATE OR REPLACE FUNCTION ST_MultiPointFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_MultiPointFromWKB(bytea)
@@ -5377,7 +5509,8 @@ CREATE OR REPLACE FUNCTION ST_MultiPointFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_MultiLineFromWKB(bytea)
@@ -5387,7 +5520,8 @@ CREATE OR REPLACE FUNCTION ST_MultiLineFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 -- PostGIS equivalent function: MLineFromWKB(text, int)
 CREATE OR REPLACE FUNCTION ST_MLineFromWKB(bytea, int)
@@ -5397,7 +5531,8 @@ CREATE OR REPLACE FUNCTION ST_MLineFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_MLineFromWKB(bytea)
@@ -5407,7 +5542,8 @@ CREATE OR REPLACE FUNCTION ST_MLineFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 -- PostGIS equivalent function: MPolyFromWKB(bytea, int)
@@ -5418,7 +5554,8 @@ CREATE OR REPLACE FUNCTION ST_MPolyFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_MPolyFromWKB(bytea)
@@ -5438,7 +5575,8 @@ CREATE OR REPLACE FUNCTION ST_MultiPolyFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_MultiPolyFromWKB(bytea)
@@ -5448,7 +5586,8 @@ CREATE OR REPLACE FUNCTION ST_MultiPolyFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_GeomCollFromWKB(bytea, int)
@@ -5459,7 +5598,8 @@ CREATE OR REPLACE FUNCTION ST_GeomCollFromWKB(bytea, int)
 	ELSE NULL END
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_GeomCollFromWKB(bytea)
@@ -5470,7 +5610,8 @@ CREATE OR REPLACE FUNCTION ST_GeomCollFromWKB(bytea)
 	ELSE NULL END
+	_COST_LOW;
 -- Maximum distance between linestrings.
@@ -5485,7 +5626,8 @@ CREATE OR REPLACE FUNCTION _ST_MaxDistance(geom1 geometry, geom2 geometry)
 CREATE OR REPLACE FUNCTION ST_MaxDistance(geom1 geometry, geom2 geometry)
 	RETURNS float8
 	AS 'SELECT @extschema at ._ST_MaxDistance(@extschema at .ST_ConvexHull($1), @extschema at .ST_ConvexHull($2))'
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_ClosestPoint(geom1 geometry, geom2 geometry)
 	RETURNS geometry
@@ -5508,7 +5650,8 @@ CREATE OR REPLACE FUNCTION _ST_LongestLine(geom1 geometry, geom2 geometry)
 CREATE OR REPLACE FUNCTION ST_LongestLine(geom1 geometry, geom2 geometry)
 	RETURNS geometry
 	AS 'SELECT @extschema at ._ST_LongestLine(@extschema at .ST_ConvexHull($1), @extschema at .ST_ConvexHull($2))'
+	_COST_HIGH;
@@ -5524,7 +5667,7 @@ CREATE OR REPLACE FUNCTION ST_FlipCoordinates(geometry)
 	RETURNS geometry
-	_COST_MEDIUM;
+	_COST_LOW;
 -- SFSQL 1.1
@@ -5877,7 +6020,7 @@ CREATE OR REPLACE FUNCTION ST_CoordDim(Geometry geometry)
 	RETURNS smallint
 	AS 'MODULE_PATHNAME', 'LWGEOM_ndims'
-	_COST_LOW;
+	_COST_DEFAULT;
 -- SQL-MM
@@ -5924,7 +6067,8 @@ CREATE OR REPLACE FUNCTION ST_LineToCurve(Geometry geometry)
 CREATE OR REPLACE FUNCTION ST_Point(float8, float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_makepoint'
-	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE _COST_LOW;
+	_COST_LOW;
 -- PostGIS equivalent function: ST_MakePolygon(Geometry geometry)
 CREATE OR REPLACE FUNCTION ST_Polygon(geometry, int)
@@ -5932,7 +6076,8 @@ CREATE OR REPLACE FUNCTION ST_Polygon(geometry, int)
 	AS $$
 	SELECT @extschema at .ST_SetSRID(@extschema at .ST_MakePolygon($1), $2)
+	_COST_LOW;
 -- PostGIS equivalent function: GeomFromWKB(WKB bytea))
 -- Note: Defaults to an SRID=-1, not 0 as per SQL/MM specs.
@@ -5984,7 +6129,7 @@ CREATE OR REPLACE FUNCTION ST_Hexagon(size float8, cell_i integer, cell_j intege
 	AS 'MODULE_PATHNAME', 'ST_Hexagon'
 	PARALLEL SAFE
-	_COST_MEDIUM;
+	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_Square(size float8, cell_i integer, cell_j integer, origin geometry DEFAULT 'POINT(0 0)')
@@ -5992,7 +6137,7 @@ CREATE OR REPLACE FUNCTION ST_Square(size float8, cell_i integer, cell_j integer
 	AS 'MODULE_PATHNAME', 'ST_Square'
 	PARALLEL SAFE
-	_COST_MEDIUM;
+	_COST_LOW;
@@ -6269,13 +6414,15 @@ LANGUAGE 'plpgsql' IMMUTABLE STRICT PARALLEL SAFE _COST_HIGH;
 	RETURNS TEXT
+        _COST_MEDIUM;
 	RETURNS TEXT
+        _COST_MEDIUM;
 -- ST_Angle
@@ -6284,7 +6431,8 @@ CREATE OR REPLACE FUNCTION ST_AsX3D(geom geometry, maxdecimaldigits integer DEFA
 -- has to be here because need ST_StartPoint
+        _COST_LOW;
@@ -6295,7 +6443,8 @@ GRANT SELECT ON TABLE spatial_ref_sys TO public;
 	RETURNS geometry
+        _COST_LOW;
Summary of changes:
 NEWS                     |   1 +
 postgis/geography.sql.in |  38 +--
 postgis/postgis.sql.in   | 673 +++++++++++++++++++++++++++++------------------
 postgis/sqldefines.h.in  |   4 +-
 4 files changed, 436 insertions(+), 280 deletions(-)
hooks/post-receive
