[postgis-tickets] [PostGIS] #4608: Geography GIST index fails on ST_Covers
PostGIS trac at osgeo.org
Fri Jan 3 07:16:01 PST 2020
  Reporter:  jgh      |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.0.1
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:
Comment (by Algunenano):
 I've added the tests for ST_Covers and ST_CoveredBy.
 I don't see an easy way to test the change in `st_containsproperly` since
 the bug (it was using `&&` instead of `~`) doesn't have an impact in the
 results; all cases where `a ~ b`  are included in `a && b` (but not the
 other way around) except when b is EMPTY , but then `containsproperly`
 discards empty geometries. I'm not aware of any way to check whether the
 result comes from the index operator or the C function itself.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4608#comment:9>
