[postgis-tickets] [PostGIS] #4615: Optimize lwout_geojson output
PostGIS trac at osgeo.org
Fri Jan 3 10:41:07 PST 2020
 Reporter:  Algunenano   |      Owner:  Algunenano
     Type:  enhancement  |     Status:  assigned
 Priority:  medium       |  Milestone:  PostGIS 3.1.0
Component:  postgis      |    Version:  master
 Keywords:               |
 Related to ​https://trac.osgeo.org/postgis/ticket/4543
 After #4543 is applied, around half the time spent in the output of
 ST_AsGeoJSON of a big polygon (>100k vertices) is spent in sprintf calls,
 mainly calculating the length of the strings (which we already know). It
 should be possible to remove all this time by replacing it a memcpy calls
 or writting the doubles directly in the buffer (instead of writting them
 in an auxiliar variable and then into the buffer).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4615>
