[postgis-tickets] [PostGIS] #4612: No WFS support for OGR FDW under Windows
PostGIS trac at osgeo.org
Sun Jan 5 09:53:57 PST 2020
  Reporter:  davis                  |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 3.0.1
 Component:  build/upgrade/install  |    Version:  3.0.x
Resolution:                         |   Keywords:  wfs, ogr fdw windows
Comment (by robe):
 okay I looked closer at the issue, and I think issue is my old curl didn't
 have a libz dependency and the new one does.  The curl_global_init check
 fails because for some reason gdal can't find the libz file.  trying to
 fix that now.  At anyrate unless you are requiring new features of curl, I
 think the .dll I posted above should work fine as the newer curl is
 downward compatible with 7.54 one.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4612#comment:7>
