[postgis-tickets] [PostGIS] #4612: No WFS support for OGR FDW under Windows
PostGIS trac at osgeo.org
Sun Jan 5 12:26:45 PST 2020
  Reporter:  davis                  |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 3.0.1
 Component:  build/upgrade/install  |    Version:  3.0.x
Resolution:                         |   Keywords:  wfs, ogr fdw windows
Comment (by robe):
 okay I've updated
 https://winnie.postgis.net/download/windows/pg12/buildbot/extras/gdal_2.4.3
 -with-curl.zip with gdal 2.4.3 compiled against curl - 7.67.0 with libz
 support.
 Also repackaging the ogr_fdw 1.0.9 for all releases. Pg12 one is already
 done and is here -
 https://winnie.postgis.net/download/windows/pg12/buildbot/extras/ogrfdw-
 pg12-binaries-1.0.9w64gcc81.zip , but just replacing the libgdal-20.dll
 should be sufficient to fix your issue.
 I'm going to wait off on building a new PostGIS bundle installer until one
 of the following happens
 1) GDAL is changed upstream -- as EvenR alluded to on #gdal irc
 18:44:34        EvenR:  ah ok, didn't know that geoserver used that hack.
 I'll try to silence that down in the WFS driver
 2) We release PostGIS 3.0.1 which I hope happens soon like in next 2 weeks
 -- which might happen since we have a lot of semi-critical fixes ready to
 go or in route
 or
 3) Another PostgreSQL micro release comes out
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4612#comment:9>
