[postgis-tickets] [SCM] PostGIS branch master updated. 9f22d34b5a0c6a697d4e4aa303642ff5bd450019
Tue Jan 7 03:21:03 PST 2020
the project "PostGIS".
       via  9f22d34b5a0c6a697d4e4aa303642ff5bd450019 (commit)
      from  694937a19831c83bc947b5a89e519b8453be819c (commit)
revisions in full, below.
commit 9f22d34b5a0c6a697d4e4aa303642ff5bd450019
Author: Kristian Thy <thy at 42.dk>
Date:   Fri Jan 3 09:18:34 2020 +0100
    pgsql2shp: Add -q toggle for quiet mode
    Closes #2972
    Closes https://github.com/postgis/postgis/pull/527
    Signed-off-by: Raúl Marín <git at rmr.ninja>
diff --git a/NEWS b/NEWS
index 83f083f..a7ab9ba 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,7 @@ PostGIS 3.1.0
 * New features *
   - #4601, Add ST_TileEnvelope margin argument (Yuri Astrakhan)
+  - #2972, Add quiet mode (-q) to pgsql2shp (Kristian Thy)
 * Enhancements *
   - #4539, Unify libm includes (Raúl Marín)
diff --git a/loader/pgsql2shp-cli.c b/loader/pgsql2shp-cli.c
index 803f0c2..6fa975f 100644
--- a/loader/pgsql2shp-cli.c
+++ b/loader/pgsql2shp-cli.c
@@ -25,7 +25,7 @@
 static void
 usage(int status)
-  /* TODO: if status != 0 print all to stderr */
+	/* TODO: if status != 0 print all to stderr */
 	printf(_( "RELEASE: %s (%s)\n" ), POSTGIS_LIB_VERSION,
 		xstr(POSTGIS_REVISION));
@@ -50,6 +50,7 @@ usage(int status)
 	         "     leading space. For example:\n"
 	         "         COLUMNNAME DBFFIELD1\n"
 	         "         AVERYLONGCOLUMNNAME DBFFIELD2\n" ));
+	printf(_("  -q Quiet mode. No messages to stdout.\n" ));
 	printf(_("  -? Display this help screen.\n\n" ));
 	exit(status);
@@ -72,7 +73,7 @@ main(int argc, char **argv)
 	config = malloc(sizeof(SHPDUMPERCONFIG));
 	set_dumper_config_defaults(config);
-	while ((c = pgis_getopt(argc, argv, "bf:h:du:p:P:g:rkm:")) != EOF)
+	while ((c = pgis_getopt(argc, argv, "bf:h:du:p:P:g:rkm:q")) != EOF)
 		switch (c)
@@ -110,6 +111,9 @@ main(int argc, char **argv)
 		case 'k':
 			config->keep_fieldname_case = 1;
 			break;
+		case 'q':
+			config->quiet = 1;
+			break;
 		default:
 			usage(pgis_optopt == '?' ? 0 : 1);
@@ -144,25 +148,25 @@ main(int argc, char **argv)
 			char *strptr = argv[pgis_optind];
 			char *chrptr = strchr(strptr, '.');
-				/* OK, this is a schema-qualified table name... */
-      if (chrptr)
-        if ( chrptr == strptr )
-          /* table is ".something" display help  */
-          usage(0);
-          exit(0);
-        /* Null terminate at the '.' */
-        *chrptr = '\0';
-        /* Copy in the parts */
-        config->schema = strdup(strptr);
-        config->table = strdup(chrptr+1);
-      else
-        config->table = strdup(strptr);
+			/* OK, this is a schema-qualified table name... */
+			if (chrptr)
+				if ( chrptr == strptr )
+					/* table is ".something" display help  */
+					usage(0);
+					exit(0);
+				/* Null terminate at the '.' */
+				*chrptr = '\0';
+				/* Copy in the parts */
+				config->schema = strdup(strptr);
+				config->table = strdup(chrptr+1);
+			else
+				config->table = strdup(strptr);
 	else
@@ -188,8 +192,11 @@ main(int argc, char **argv)
 	/* Open the table ready to return rows */
-	fprintf(stdout, _("Initializing... \n"));
-	fflush(stdout);
+	if (!state->config->quiet)
+		fprintf(stdout, _("Initializing... \n"));
+		fflush(stdout);
 	ret = ShpDumperOpenTable(state);
 	if (ret != SHPDUMPEROK)
@@ -201,15 +208,18 @@ main(int argc, char **argv)
 			exit(1);
-	fprintf(stdout, _("Done (postgis major version: %d).\n"), state->pgis_major_version);
-	fprintf(stdout, _("Output shape: %s\n"), shapetypename(state->outshptype));
-	fprintf(stdout, _("Dumping: "));
-	fflush(stdout);
+		fprintf(stdout, _("Done (postgis major version: %d).\n"), state->pgis_major_version);
+		fprintf(stdout, _("Output shape: %s\n"), shapetypename(state->outshptype));
+		fprintf(stdout, _("Dumping: "));
+		fflush(stdout);
 	for (i = 0; i < ShpDumperGetRecordCount(state); i++)
 		/* Mimic existing behaviour */
-		if (!(state->currow % state->config->fetchsize))
+		if (!state->config->quiet && !(state->currow % state->config->fetchsize))
 			fprintf(stdout, "X");
 			fflush(stdout);
@@ -226,8 +236,11 @@ main(int argc, char **argv)
-	fprintf(stdout, _(" [%d rows].\n"), ShpDumperGetRecordCount(state));
-	fflush(stdout);
+		fprintf(stdout, _(" [%d rows].\n"), ShpDumperGetRecordCount(state));
+		fflush(stdout);
 	ret = ShpDumperCloseTable(state);
diff --git a/loader/pgsql2shp-core.c b/loader/pgsql2shp-core.c
index 168511d..1596dc2 100644
--- a/loader/pgsql2shp-core.c
+++ b/loader/pgsql2shp-core.c
@@ -832,16 +832,16 @@ projFileCreate(SHPDUMPERSTATE *state)
 				else
-				    result = fputs (srtext,fp);
-                    LWDEBUGF(3, "\n result %d proj SRText is %s .\n", result, srtext);
-                    if (result == EOF)
-                        fclose( fp );
-                        free( pszFullname );
-                        PQclear(res);
-                        free(query);
-                        return 0;
+					result = fputs (srtext,fp);
+					LWDEBUGF(3, "\n result %d proj SRText is %s .\n", result, srtext);
+					if (result == EOF)
+						fclose( fp );
+						free( pszFullname );
+						PQclear(res);
+						free(query);
+						return 0;
 				fclose( fp );
@@ -883,14 +883,14 @@ getTableInfo(SHPDUMPERSTATE *state)
 			query = malloc(150 + 4 * strlen(state->geo_col_name) + strlen(state->schema) + strlen(state->table));
 			sprintf(query, "SELECT count(1), max(ST_zmflag(\"%s\"::geometry)), geometrytype(\"%s\"::geometry) FROM \"%s\".\"%s\" GROUP BY 3",
-			state->geo_col_name, state->geo_col_name, state->schema, state->table);
+			        state->geo_col_name, state->geo_col_name, state->schema, state->table);
 		else
 			query = malloc(150 + 4 * strlen(state->geo_col_name) + strlen(state->table));
 			sprintf(query, "SELECT count(1), max(ST_zmflag(\"%s\"::geometry)), geometrytype(\"%s\"::geometry) FROM \"%s\" GROUP BY 3",
-			state->geo_col_name, state->geo_col_name, state->table);
+			        state->geo_col_name, state->geo_col_name, state->table);
 	else
@@ -1144,6 +1144,7 @@ set_dumper_config_defaults(SHPDUMPERCONFIG *config)
 	config->keep_fieldname_case = 0;
 	config->fetchsize = 100;
 	config->column_map_filename = NULL;
+	config->quiet = 0;
 /* Create a new shapefile state object */
@@ -1535,11 +1536,11 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
 		 * use this to create the dbf field name from
 		 * the PostgreSQL column name */
-		  const char *mapped = colmap_dbf_by_pg(&state->column_map, dbffieldname);
-		  if (mapped)
-			  strncpy(dbffieldname, mapped, 10);
-			  dbffieldname[10] = '\0';
+			const char *mapped = colmap_dbf_by_pg(&state->column_map, dbffieldname);
+			if (mapped)
+				strncpy(dbffieldname, mapped, 10);
+				dbffieldname[10] = '\0';
@@ -1569,7 +1570,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
 		if (strcasecmp(dbffieldname, pgfieldname))
 			if ( snprintf(buf, 256, _("Warning, field %s renamed to %s\n"),
-							 pgfieldname, dbffieldname) >= 256 )
+			              pgfieldname, dbffieldname) >= 256 )
 				buf[255] = '\0';
@@ -1884,7 +1885,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
 		else
 			sprintf(buf, "asbinary(%s::geometry, 'XDR') AS _geoX",
-				quote_identifier(state->geo_col_name) );
+			        quote_identifier(state->geo_col_name) );
 #else
 		if (state->pgis_major_version > 0)
@@ -1894,7 +1895,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
 		else
 			sprintf(buf, "asbinary(%s::geometry, 'NDR') AS _geoX",
 #endif
diff --git a/loader/pgsql2shp-core.h b/loader/pgsql2shp-core.h
index b26a288..6b26702 100644
--- a/loader/pgsql2shp-core.h
+++ b/loader/pgsql2shp-core.h
@@ -88,6 +88,9 @@ typedef struct shp_dumper_config
 	/* Name of the column map file if specified */
 	char *column_map_filename;
+	/* 0=normal output to stdout, 1=no output to stdout */
+	int quiet;
 } SHPDUMPERCONFIG;
@@ -182,7 +185,7 @@ typedef struct shp_dumper_state
 	char message[SHPDUMPERMSGLEN];
 	/* Column map */
-  colmap column_map;
+	colmap column_map;
 } SHPDUMPERSTATE;
Summary of changes:
 NEWS                    |  1 +
 loader/pgsql2shp-cli.c  | 73 +++++++++++++++++++++++++++++--------------------
 loader/pgsql2shp-core.c | 41 +++++++++++++--------------
 loader/pgsql2shp-core.h |  5 +++-
 4 files changed, 69 insertions(+), 51 deletions(-)
hooks/post-receive
