[postgis-tickets] [SCM] PostGIS branch master updated. 558af7a63d1b2057ad0cc05b9ed601659787508b
Thu Jan 9 08:28:06 PST 2020
the project "PostGIS".
       via  558af7a63d1b2057ad0cc05b9ed601659787508b (commit)
      from  413b47356205b181427ccb5a16e86271d00bbd96 (commit)
revisions in full, below.
commit 558af7a63d1b2057ad0cc05b9ed601659787508b
Author: Raúl Marín <git at rmr.ninja>
Date:   Wed Jan 8 13:16:55 2020 +0100
    Add option to disable phony revision
    Closes #4617
    Closes https://github.com/postgis/postgis/pull/532/
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 865ee2d..499bf6c 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -172,7 +172,12 @@ fmt:
 commit:
 	$(MAKE) fmt && $(MAKE) clean && $(MAKE) check && svn commit
+ifeq (@PHONY_REVISION@,yes)
+.PHONY: postgis_revision.h
+endif
 postgis_revision.h:
 	$(PERL) utils/repo_revision.pl
-.PHONY: utils liblwgeom ChangeLog raster postgis_revision.h
+.PHONY: utils liblwgeom ChangeLog raster
diff --git a/NEWS b/NEWS
index 822c1bd..108c3c1 100644
--- a/NEWS
+++ b/NEWS
@@ -13,6 +13,7 @@ PostGIS 3.1.0
 * New features *
   - #4601, Add ST_TileEnvelope margin argument (Yuri Astrakhan)
   - #2972, Add quiet mode (-q) to pgsql2shp (Kristian Thy)
+  - #4617, Add configure switch `--without-phony-revision` (Raúl Marín)
 * Enhancements *
   - #4539, Unify libm includes (Raúl Marín)
diff --git a/configure.ac b/configure.ac
index 4298fed..3521b56 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1130,6 +1130,18 @@ else
     CPPFLAGS="-DNDEBUG $CPPFLAGS"
 fi
+dnl ===========================================================================
+dnl Allow the developer to disable the automatic updates of postgis_revision.h
+dnl with --without-phony-revision
+dnl
+AC_ARG_WITH([phony-revision], AC_HELP_STRING([--without-phony-revision], [Disable automatic updates of postgis_revision.h]), [], [])
+if test "x$with_phony_revision" != "xno"; then
+    PHONY_REVISION="yes"
+else
+    PHONY_REVISION="no"
+fi
+AC_MSG_RESULT([phony-revision: $with_phony_revision])
+AC_SUBST([PHONY_REVISION])
 dnl Define version macros
diff --git a/doc/installation.xml b/doc/installation.xml
index fe60ce9..86b9a1e 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -606,6 +606,14 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
 			</para>
 		  </listitem>
 		</varlistentry>
+		<varlistentry>
+		  <term><command>--without-phony-revision</command></term>
+		  <listitem>
+			<para>
+			  Disable updating postgis_revision.h to match current HEAD of the git repository.
+			</para>
+		  </listitem>
+		</varlistentry>
 	  </variablelist>
 	  <note>
 		<para>
Summary of changes:
 GNUmakefile.in       |  7 ++++++-
 NEWS                 |  1 +
 configure.ac         | 12 ++++++++++++
 doc/installation.xml |  8 ++++++++
 4 files changed, 27 insertions(+), 1 deletion(-)
hooks/post-receive
