[postgis-tickets] [PostGIS] #4619: ST_TileEnvelope test failure in 32 bit
PostGIS trac at osgeo.org
Tue Jan 14 10:28:53 PST 2020
  Reporter:  Algunenano  |      Owner:  Algunenano
      Type:  defect      |     Status:  assigned
  Priority:  medium      |  Milestone:  PostGIS 3.0.1
 Component:  postgis     |    Version:  3.0.x
Resolution:              |   Keywords:
Comment (by Algunenano):
 I tried reordering the floating point operations to see if doing first the
 operations in closer to zero gave any better result but it didn't work, so
 I'll simply reduce the number of decimals in that test and move on.
 PR: https://github.com/postgis/postgis/pull/534
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4619#comment:1>
