[postgis-tickets] [SCM] PostGIS branch master updated. cd6a3a996162f8838b6d52790dc89b8aed6f4dd1
Wed Jan 15 07:46:56 PST 2020
the project "PostGIS".
       via  cd6a3a996162f8838b6d52790dc89b8aed6f4dd1 (commit)
      from  930dadee1559133f306970e1388a4f60b0703190 (commit)
revisions in full, below.
commit cd6a3a996162f8838b6d52790dc89b8aed6f4dd1
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jan 15 16:46:26 2020 +0100
    Make "Short Version" of install section shorter
    Leave pointers to appropriate section for more details
diff --git a/doc/installation.xml b/doc/installation.xml
index 0a53199..e5503f5 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -14,57 +14,12 @@ cd postgis-&last_release_version;
 ./configure
 make
 make install</programlisting>
-	<para>Once postgis is installed, it needs to be enabled in each individual database you want to use it in.</para>
-	<note><para>Using the extension enable process is preferred and more user-friendly. To spatially enable your database:</para></note>
-	<programlisting>
-psql -d yourdatabase -c "CREATE EXTENSION postgis;"
--- if you built with raster support and want to install it --
-psql -d yourdatabase -c "CREATE EXTENSION postgis_raster;"
--- if you want to install topology support --
-psql -d yourdatabase -c "CREATE EXTENSION postgis_topology;"
--- if you built with sfcgal support and want to install it --
-psql -d yourdatabase -c "CREATE EXTENSION postgis_sfcgal;"
--- if you want to install tiger geocoder --
-psql -d yourdatabase -c "CREATE EXTENSION fuzzystrmatch"
-psql -d yourdatabase -c "CREATE EXTENSION postgis_tiger_geocoder;"
--- if you installed with pcre
--- you should have address standardizer extension as well
-psql -d yourdatabase -c "CREATE EXTENSION address_standardizer;"
-</programlisting>
-	<para>Please refer to <xref linkend="make_install_postgis_extensions" /> for more details about querying installed/available extensions and upgrading extensions, or switching from a non-extension install to an extension install.</para>
-	<para>For those who decided for some reason to use a non-extension
-based install, here are longer more painful instructions for you:</para>
-	<para>All the .sql files once installed will be installed in share/contrib/postgis-&last_minor_version; folder
-		of your PostgreSQL install</para>
-	<programlisting>createdb yourdatabase
-createlang plpgsql yourdatabase
-psql -d yourdatabase -f postgis.sql
-psql -d yourdatabase -f postgis_comments.sql
-psql -d yourdatabase -f spatial_ref_sys.sql
--- if you want to enable topology
-psql -d yourdatabase -f topology.sql
-psql -d yourdatabase -f topology_comments.sql
--- if you want to enable raster
--- and only if you compiled with raster (GDAL)
-psql -d yourdatabase -f rtpostgis.sql
-psql -d yourdatabase -f raster_comments.sql
--- if you want to enable sfcgal backend
--- and only if you built with sfcgal support --
-psql -d yourdatabase -f sfcgal.sql
-psql -d yourdatabase -f sfcgal_comments.sql
-</programlisting>
+	<para>
+Once PostGIS is installed, it needs to be
+enabled (<xref linkend="create_spatial_db" />)
+or upgraded (<xref linkend="upgrading" />)
+in each individual database you want to use it in.
+  </para>
   </sect1>
Summary of changes:
 doc/installation.xml | 57 ++++++----------------------------------------------
 1 file changed, 6 insertions(+), 51 deletions(-)
hooks/post-receive
