[postgis-tickets] [SCM] PostGIS branch master updated. d5ab9d4e27d0ccbf87e0986b9cfc780e8c6d772e
Fri Jan 17 10:35:35 PST 2020
the project "PostGIS".
       via  d5ab9d4e27d0ccbf87e0986b9cfc780e8c6d772e (commit)
       via  9524ba04aeb925c8cb53d41136b8086399d60bc8 (commit)
       via  18ac14a6161abcd5377ad6f5520055ceb8299b62 (commit)
      from  4332fa3330ea651317d3c9dc3f5bd2092ba9241d (commit)
revisions in full, below.
commit d5ab9d4e27d0ccbf87e0986b9cfc780e8c6d772e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Jan 17 10:17:13 2020 -0800
    Woops remove useless reference
diff --git a/postgis/lwgeom_generate_grid.c b/postgis/lwgeom_generate_grid.c
index 769fb6a..bf84208 100644
--- a/postgis/lwgeom_generate_grid.c
+++ b/postgis/lwgeom_generate_grid.c
@@ -237,7 +237,6 @@ PG_FUNCTION_INFO_V1(ST_ShapeGrid);
 Datum ST_ShapeGrid(PG_FUNCTION_ARGS)
 	FuncCallContext *funcctx;
-	MemoryContext oldcontext;
 	GSERIALIZED *gbounds;
 	GeometryGridState *state;
@@ -250,6 +249,7 @@ Datum ST_ShapeGrid(PG_FUNCTION_ARGS)
 	if (SRF_IS_FIRSTCALL())
+		MemoryContext oldcontext;
 		const char *func_name;
 		double bounds_width, bounds_height;
 		char gbounds_is_empty;
@@ -309,7 +309,6 @@ Datum ST_ShapeGrid(PG_FUNCTION_ARGS)
 	/* stuff done on every call of the function */
 	funcctx = SRF_PERCALL_SETUP();
-	newcontext = funcctx->multi_call_memory_ctx;
 	/* get state */
 	state = funcctx->user_fctx;
commit 9524ba04aeb925c8cb53d41136b8086399d60bc8
Date:   Fri Jan 17 10:03:02 2020 -0800
    Remove unused var
index 664a5ff..769fb6a 100644
@@ -237,7 +237,7 @@ PG_FUNCTION_INFO_V1(ST_ShapeGrid);
-	MemoryContext oldcontext, newcontext;
commit 18ac14a6161abcd5377ad6f5520055ceb8299b62
Date:   Fri Jan 17 09:43:24 2020 -0800
    Apply comments from @Algunenano
diff --git a/NEWS b/NEWS
index a450ccf..3af0b21 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,8 @@ PostGIS 3.1.0
   - #2972, Add quiet mode (-q) to pgsql2shp (Kristian Thy)
   - #4617, Add configure switch `--without-phony-revision` (Raúl Marín)
   - #3057, Optional value params for Force3D*, Force4D functions (Kristian Thy)
+  - ST_HexagonGrid and ST_SquareGrid, set returning funcitons to
+    generate tilings of the plane (Paul Ramsey)
 * Enhancements *
   - #4539, Unify libm includes (Raúl Marín)
index d59c7ec..664a5ff 100644
@@ -18,7 +18,7 @@
- * Copyright 2018 Paul Ramsey <pramsey at cleverelephant.ca>
+ * Copyright 2020 Paul Ramsey <pramsey at cleverelephant.ca>
@@ -71,7 +71,7 @@ static const double hex_x[] = {-1.0, -0.5,  0.5, 1.0, 0.5, -0.5, -1.0};
 static const double hex_y[] = { 0.0, -1*H, -1*H, 0.0,   H,    H,  0.0};
 static LWGEOM *
-hexagon(double origin_x, double origin_y, double size, int cell_i, int cell_j, uint32_t srid)
+hexagon(double origin_x, double origin_y, double size, int cell_i, int cell_j, int32_t srid)
 	double height = size * 2 * H;
 	POINT4D pt;
@@ -145,10 +145,10 @@ hexagon_grid_state(double size, const GBOX *gbox, int32_t srid)
 	return state;
-static bool
+static void
 hexagon_state_next(HexagonGridState *state)
-	if (!state || state->done) return false;
+	if (!state || state->done) return;
 	/* Move up one row */
 	state->j++;
 	/* Off the end, increment column counter, reset row counter back to (appropriate) minimum */
@@ -162,13 +162,12 @@ hexagon_state_next(HexagonGridState *state)
 		state->done = true;
-	return !state->done;
 static LWGEOM *
-square(double origin_x, double origin_y, double size, int cell_i, int cell_j, uint32_t srid)
+square(double origin_x, double origin_y, double size, int cell_i, int cell_j, int32_t srid)
 	double ll_x = origin_x + (size * cell_i);
 	double ll_y = origin_y + (size * cell_j);
@@ -211,10 +210,10 @@ square_grid_state(double size, const GBOX *gbox, int32_t srid)
 	return state;
-static bool
+static void
 square_state_next(SquareGridState *state)
 	state->j++;
@@ -228,7 +227,6 @@ square_state_next(SquareGridState *state)
 		state->done = true;
@@ -275,8 +273,7 @@ Datum ST_ShapeGrid(PG_FUNCTION_ARGS)
 			SRF_RETURN_DONE(funcctx);
-		oldcontext = MemoryContextSwitchTo(newcontext);
+		oldcontext = MemoryContextSwitchTo(funcctx->multi_call_memory_ctx);
 		* Support both hexagon and square grids with one function,
Summary of changes:
 NEWS                           |  2 ++
 postgis/lwgeom_generate_grid.c | 22 +++++++++-------------
 2 files changed, 11 insertions(+), 13 deletions(-)
hooks/post-receive
