[postgis-tickets] [SCM] PostGIS branch master updated. 8033b2844f14708e84ea9ae29e3129a03e457bd0
Fri Jan 24 07:37:53 PST 2020
the project "PostGIS".
       via  8033b2844f14708e84ea9ae29e3129a03e457bd0 (commit)
      from  8ebafdd358205de4d5392a469f2f39744ed02618 (commit)
revisions in full, below.
commit 8033b2844f14708e84ea9ae29e3129a03e457bd0
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Jan 24 16:24:40 2020 +0100
    Support pkg-config for libxml2
    Patch by Bas Couwenberg
    References #4626
diff --git a/NEWS b/NEWS
index 3009eab..b4539b9 100644
--- a/NEWS
+++ b/NEWS
@@ -30,6 +30,7 @@ PostGIS 3.1.0
   - #4473, Silence yacc warnings (Raúl Marín)
   - #4589, Disable C asserts when building without "--enable-debug" (Raúl Marín)
   - #4543, Introduce ryu to print doubles (Raúl Marín)
+  - #4626, Support pkg-config for libxml2 (Bas Couwenberg)
 * Bug fixes *
   - #4544, Fix leak when parsing a WKT geometry_list (Raúl Marín)
diff --git a/configure.ac b/configure.ac
index 9f0813a..2ba040f 100644
--- a/configure.ac
+++ b/configure.ac
@@ -313,6 +313,16 @@ fi
 AC_SUBST([MATHML2_DTD])
 dnl ===========================================================================
+dnl Detect if pkg-config installed
+dnl ===========================================================================
+# check for pkg-config
+PKG_PROG_PKG_CONFIG
+if test -z "$PKG_CONFIG"; then
+   AC_MSG_WARN([Cannot find pkg-config, make sure it is installed in your PATH])
+fi
 dnl Detect CUnit if it is installed (used for unit testing)
 dnl
 dnl Note that we pass any specified CPPFLAGS and LDFLAGS into the Makefile
@@ -589,13 +599,31 @@ AC_ARG_WITH([xml2config],
 	[AS_HELP_STRING([--with-xml2config=FILE], [specify an alternative xml2-config file])],
 	[XML2CONFIG="$withval"], [XML2CONFIG=""])
+XML2_LDFLAGS=""
+XML2_CPPFLAGS=""
 if test "x$XML2CONFIG" = "x"; then
 	dnl XML2CONFIG was not specified, so search within the current path
 	AC_PATH_PROG([XML2CONFIG], [xml2-config])
-	dnl If we couldn't find xml2-config, display a warning
+	dnl If we couldn't find xml2-config, display a warning if pkg-config fails too
-		AC_MSG_ERROR([could not find xml2-config from libxml2 within the current path. You may need to try re-running configure with a --with-xml2config parameter.])
+		if test ! -z "$PKG_CONFIG"; then
+			PKG_CHECK_MODULES([LIBXML2], [libxml-2.0], [
+				XML2_CPPFLAGS="$LIBXML2_CFLAGS"
+				XML2_LDFLAGS="$LIBXML2_LIBS"
+				POSTGIS_LIBXML2_VERSION=`$PKG_CONFIG libxml-2.0 --modversion`
+		else
+			AC_MSG_ERROR([could not find xml2-config from libxml2 within the current path. You may need to try re-running configure with a --with-xml2config parameter.])
+		fi
+	else
+		dnl Extract the linker and include flags
+		XML2_LDFLAGS=`$XML2CONFIG --libs`
+		XML2_CPPFLAGS=`$XML2CONFIG --cflags`
+		dnl Extract the version
+		POSTGIS_LIBXML2_VERSION=`$XML2CONFIG --version`
 	fi
 else
 	dnl XML2CONFIG was specified; display a message to the user
@@ -604,6 +632,13 @@ else
 	else
 		if test -f $XML2CONFIG; then
 			AC_MSG_RESULT([Using user-specified xml2-config file: $XML2CONFIG])
 		else
 			AC_MSG_ERROR([the user-specified xml2-config file $XML2CONFIG does not exist])
 		fi
@@ -611,11 +646,6 @@ else
 fi
-dnl Extract the linker and include flags
-XML2_LDFLAGS=`$XML2CONFIG --libs`
-XML2_CPPFLAGS=`$XML2CONFIG --cflags`
 dnl
 dnl XCode in 10.12 supplies bad flags in xml2config resulting
 dnl in compile errors. For that one version, we force the prefix
@@ -638,10 +668,6 @@ case $host_os in
 esac
-dnl Extract the version
-POSTGIS_LIBXML2_VERSION=`$XML2CONFIG --version`
 dnl Check headers file
 CPPFLAGS_SAVE="$CPPFLAGS"
 CPPFLAGS="$XML2_CPPFLAGS"
@@ -830,16 +856,6 @@ CFLAGS="$CFLAGS_SAVE"
-dnl Detect if pkg-config installed
-dnl ===========================================================================
-# check for pkg-config
-PKG_PROG_PKG_CONFIG
-if test -z "$PKG_CONFIG"; then
-   AC_MSG_WARN([Cannot find pkg-config, make sure it is installed in your PATH])
-fi
 dnl Detect the version of PROJ.4 installed
Summary of changes:
 NEWS         |  1 +
 configure.ac | 58 +++++++++++++++++++++++++++++++++++++---------------------
 2 files changed, 38 insertions(+), 21 deletions(-)
hooks/post-receive
