[postgis-tickets] [PostGIS] #4543: Use Ryū to output floating point numbers
PostGIS trac at osgeo.org
Mon Jan 27 01:29:00 PST 2020
  Reporter:  Algunenano   |      Owner:  Algunenano
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 3.1.0
 Component:  liblwgeom    |    Version:  master
Resolution:  fixed        |   Keywords:
Comment (by Raúl Marín <git@…>):
 In [changeset:"0752db58ac990161981de417248edb918318f17f/git" 0752db5/git]:
 #!CommitTicketReference repository="git"
 revision="0752db58ac990161981de417248edb918318f17f"
 lwprint: Avoid using snprintf
 It can be simplified with simple pointer writes
 Closes https://github.com/postgis/postgis/pull/539
 References #4543
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4543#comment:8>
