[postgis-tickets] [SCM] PostGIS branch master updated. 892fcde0d9cef66b215a149a290c2bcf0a7879c8
git at osgeo.org
git at osgeo.org
Mon Jan 27 02:14:55 PST 2020
the project "PostGIS".
via 892fcde0d9cef66b215a149a290c2bcf0a7879c8 (commit)
from 0752db58ac990161981de417248edb918318f17f (commit)
revisions in full, below.
commit 892fcde0d9cef66b215a149a290c2bcf0a7879c8
Author: Raúl Marín <git at rmr.ninja>
Date: Fri Jan 17 18:17:54 2020 +0100
Geojson: Print doubles directly on the output buffer
Closes #4615
Closes https://github.com/postgis/postgis/pull/537
diff --git a/NEWS b/NEWS
index b4539b9..8d1a472 100644
--- a/NEWS
+++ b/NEWS
@@ -31,6 +31,7 @@ PostGIS 3.1.0
- #4589, Disable C asserts when building without "--enable-debug" (Raúl Marín)
- #4543, Introduce ryu to print doubles (Raúl Marín)
- #4626, Support pkg-config for libxml2 (Bas Couwenberg)
+ - #4615, Speed up geojson output (Raúl Marín)
* Bug fixes *
- #4544, Fix leak when parsing a WKT geometry_list (Raúl Marín)
diff --git a/liblwgeom/lwout_geojson.c b/liblwgeom/lwout_geojson.c
index f571279..c9c7888 100644
--- a/liblwgeom/lwout_geojson.c
+++ b/liblwgeom/lwout_geojson.c
@@ -722,49 +722,56 @@ asgeojson_geom_buf(const LWGEOM *geom, char *output, GBOX *bbox, int precision)
static size_t
pointArray_to_geojson(POINTARRAY *pa, char *output, int precision)
- uint32_t i;
- char *ptr;
- char x[OUT_DOUBLE_BUFFER_SIZE];
- char y[OUT_DOUBLE_BUFFER_SIZE];
- char z[OUT_DOUBLE_BUFFER_SIZE];
+ char *ptr = output;
assert ( precision <= OUT_MAX_DOUBLE_PRECISION );
- ptr = output;
- /* TODO: rewrite this loop to be simpler and possibly quicker */
if (!FLAGS_GET_Z(pa->flags))
- for (i=0; i<pa->npoints; i++)
+ for (uint32_t i = 0; i < pa->npoints; i++)
- const POINT2D *pt;
- pt = getPoint2d_cp(pa, i);
- lwprint_double(
- pt->x, precision, x, OUT_DOUBLE_BUFFER_SIZE);
- lwprint_double(
- pt->y, precision, y, OUT_DOUBLE_BUFFER_SIZE);
- if ( i ) ptr += sprintf(ptr, ",");
- ptr += sprintf(ptr, "[%s,%s]", x, y);
+ if (i)
+ *ptr = ',';
+ ptr++;
+ const POINT2D *pt = getPoint2d_cp(pa, i);
+ *ptr = '[';
+ ptr++;
+ ptr += lwprint_double(pt->x, precision, ptr, OUT_DOUBLE_BUFFER_SIZE);
+ *ptr = ',';
+ ptr++;
+ ptr += lwprint_double(pt->y, precision, ptr, OUT_DOUBLE_BUFFER_SIZE);
+ *ptr = ']';
+ ptr++;
else
- const POINT3D *pt = getPoint3d_cp(pa, i);
- lwprint_double(
- lwprint_double(
- lwprint_double(
- pt->z, precision, z, OUT_DOUBLE_BUFFER_SIZE);
+ if (i)
+ *ptr = ',';
+ ptr++;
- ptr += sprintf(ptr, "[%s,%s,%s]", x, y, z);
+ const POINT3D *pt = getPoint3d_cp(pa, i);
+ *ptr = '[';
+ ptr++;
+ *ptr = ',';
+ ptr++;
+ *ptr = ',';
+ ptr++;
+ ptr += lwprint_double(pt->z, precision, ptr, OUT_DOUBLE_BUFFER_SIZE);
+ *ptr = ']';
+ ptr++;
+ *ptr = '\0';
return (ptr-output);
Summary of changes:
NEWS | 1 +
liblwgeom/lwout_geojson.c | 65 ++++++++++++++++++++++++++---------------------
2 files changed, 37 insertions(+), 29 deletions(-)
hooks/post-receive
