[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-98-g07ca520
Fri May 1 07:50:30 PDT 2020
the project "PostGIS".
       via  07ca520a78c4c12fe94c5f0541887b4a15eeca16 (commit)
       via  d427c87f27da94a67f98d4a256ed4854baa59eaa (commit)
       via  b38079d4f1fac448c2a23681034521464d743cb6 (commit)
      from  3ced96fc1a79831a26c33311a17d1f32e3c5c732 (commit)
revisions in full, below.
commit 07ca520a78c4c12fe94c5f0541887b4a15eeca16
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri May 1 12:18:09 2020 +0200
    Cache getSRIDbySRS
    Closes #4672
    Closes https://github.com/postgis/postgis/pull/557
diff --git a/NEWS b/NEWS
index 9758de6..4edb5b1 100644
--- a/NEWS
+++ b/NEWS
@@ -13,6 +13,7 @@ Only tickets not included in 3.1.0alpha1
   - #4651: ST_Simplify: Don't copy if nothing is removed (Raúl Marín)
   - #4657: Avoid De-TOASTing where possible (Paul Ramsey)
   - #4490, Tweak function costs (Raúl Marín)
+  - #4672, Cache getSRSbySRID and getSRIDbySRS (Raúl Marín)
 * Bug fixes *
   - #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
diff --git a/libpgcommon/lwgeom_cache.c b/libpgcommon/lwgeom_cache.c
index 33e2371..d505021 100644
--- a/libpgcommon/lwgeom_cache.c
+++ b/libpgcommon/lwgeom_cache.c
@@ -11,6 +11,8 @@
 #include "postgres.h"
+#include "catalog/pg_type.h" /* for CSTRINGOID */
 #include "executor/spi.h"
 #include "fmgr.h"
 #include "utils/memutils.h"
@@ -438,4 +440,108 @@ GetSRSCacheBySRID(FunctionCallInfo fcinfo, int32_t srid, bool short_crs)
 		arg->srs = getSRSbySRID(fcinfo, srid, short_crs);
 	return arg->srs;
+ * Retrieve an SRID from a given SRS
+ * Require valid spatial_ref_sys table entry
+static int32_t
+getSRIDbySRS(FunctionCallInfo fcinfo, const char *srs)
+	static const int16_t max_query_size = 512;
+	char query[512];
+	Oid argtypes[] = {CSTRINGOID};
+	Datum values[] = {CStringGetDatum(srs)};
+	int32_t srid, err;
+	postgis_initialize_cache(fcinfo);
+	snprintf(query,
+		 max_query_size,
+		 "SELECT srid "
+		 "FROM %s, "
+		 "regexp_matches($1::text, E'([a-z]+):([0-9]+)', 'gi') AS re "
+		 "WHERE re[1] ILIKE auth_name AND int4(re[2]) = auth_srid",
+		 postgis_spatial_ref_sys());
+	if (!srs)
+		return 0;
+	if (SPI_OK_CONNECT != SPI_connect())
+		elog(NOTICE, "getSRIDbySRS: could not connect to SPI manager");
+		return 0;
+	err = SPI_execute_with_args(query, 1, argtypes, values, NULL, true, 1);
+	if (err < 0)
+		elog(NOTICE, "getSRIDbySRS: error executing query %d", err);
+		SPI_finish();
+		return 0;
+	/* no entry in spatial_ref_sys */
+	if (SPI_processed <= 0)
+		snprintf(query,
+			 max_query_size,
+			 "SELECT srid "
+			 "FROM %s, "
+			 "regexp_matches($1::text, E'urn:ogc:def:crs:([a-z]+):.*:([0-9]+)', 'gi') AS re "
+		if (err < 0)
+			SPI_finish();
+			return 0;
+			SPI_finish();
+			return 0;
+	srid = atoi(SPI_getvalue(SPI_tuptable->vals[0], SPI_tuptable->tupdesc, 1));
+	SPI_finish();
+	return srid;
+static inline SRIDCache *
+SRIDCacheGet(FunctionCallInfo fcinfo)
+	const uint32_t entry_number = SRID_CACHE_ENTRY;
+	GenericCacheCollection *generic_cache = GetGenericCacheCollection(fcinfo);
+	SRIDCache *cache = (SRIDCache *)(generic_cache->entry[entry_number]);
+	if (!cache)
+		cache = MemoryContextAllocZero(PostgisCacheContext(fcinfo), sizeof(SRIDCache));
+		cache->type = entry_number;
+		generic_cache->entry[entry_number] = (GenericCache *)cache;
+	return cache;
+int32_t
+GetSRIDCacheBySRS(FunctionCallInfo fcinfo, const char *srs)
+	SRIDCache *cache = SRIDCacheGet(fcinfo);
+	SRIDCacheArgument *arg = &(cache->arg[0]);
+	if (!arg->srid || strcmp(srs, arg->srs) != 0)
+		size_t size = strlen(srs) + 1;
+		arg->srid = getSRIDbySRS(fcinfo, srs);
+		arg->srs = MemoryContextAlloc(PostgisCacheContext(fcinfo), size);
+		memcpy(arg->srs, srs, size);
+	return arg->srid;
\ No newline at end of file
diff --git a/libpgcommon/lwgeom_cache.h b/libpgcommon/lwgeom_cache.h
index 77ab5bd..825701e 100644
--- a/libpgcommon/lwgeom_cache.h
+++ b/libpgcommon/lwgeom_cache.h
@@ -28,6 +28,7 @@
 #define RECT_CACHE_ENTRY 4
 #define TOAST_CACHE_ENTRY 5
 #define SRSDESC_CACHE_ENTRY 6
+#define SRID_CACHE_ENTRY 7
 #define NUM_CACHE_ENTRIES 8
@@ -149,4 +150,19 @@ typedef struct {
 const char *GetSRSCacheBySRID(FunctionCallInfo fcinfo, int32_t srid, bool short_crs);
+#define SRIDCacheSize 1
+typedef struct {
+	char *srs;
+	int32_t srid;
+} SRIDCacheArgument;
+typedef struct {
+	int type;
+	SRIDCacheArgument arg[SRIDCacheSize];
+} SRIDCache;
+int32_t GetSRIDCacheBySRS(FunctionCallInfo fcinfo, const char *srs);
 #endif /* LWGEOM_CACHE_H_ */
diff --git a/postgis/geography_inout.c b/postgis/geography_inout.c
index 44dec05..2e899ac 100644
--- a/postgis/geography_inout.c
+++ b/postgis/geography_inout.c
@@ -42,7 +42,6 @@
 #include "lwgeom_cache.h"
 #include "lwgeom_pg.h"       /* For debugging macros. */
 #include "geography.h"	     /* For utility functions. */
-#include "lwgeom_export.h"   /* For export functions. */
 #include "lwgeom_transform.h"
 Datum geography_in(PG_FUNCTION_ARGS);
diff --git a/postgis/gserialized_typmod.c b/postgis/gserialized_typmod.c
index ef1eb79..50bedac 100644
--- a/postgis/gserialized_typmod.c
+++ b/postgis/gserialized_typmod.c
@@ -41,7 +41,6 @@
 #include "liblwgeom.h"         /* For standard geometry types. */
 #include "lwgeom_transform.h" /* for srid_is_latlon */
diff --git a/postgis/lwgeom_export.c b/postgis/lwgeom_export.c
index 7a71f51..572be45 100644
--- a/postgis/lwgeom_export.c
+++ b/postgis/lwgeom_export.c
@@ -31,7 +31,6 @@
 #include "float.h" /* for DBL_DIG */
-#include "catalog/pg_type.h" /* for CSTRINGOID */
 #include "utils/builtins.h"
 #include "utils/jsonb.h"
@@ -40,7 +39,6 @@
 Datum LWGEOM_asGML(PG_FUNCTION_ARGS);
 Datum LWGEOM_asGeoJson(PG_FUNCTION_ARGS);
@@ -51,78 +49,6 @@ Datum LWGEOM_asEncodedPolyline(PG_FUNCTION_ARGS);
 Datum geometry_to_json(PG_FUNCTION_ARGS);
 Datum geometry_to_jsonb(PG_FUNCTION_ARGS);
-* Retrieve an SRID from a given SRS
-* Require valid spatial_ref_sys table entry
-int
-getSRIDbySRS(FunctionCallInfo fcinfo, const char *srs)
-	static const int16_t max_query_size = 512;
-	char query[512];
-	Oid argtypes[] = {CSTRINGOID};
-	Datum values[] = {CStringGetDatum(srs)};
-	int32_t srid, err;
-	postgis_initialize_cache(fcinfo);
-	snprintf(query,
-		 max_query_size,
-		 "SELECT srid "
-		 "FROM %s, "
-		 "regexp_matches($1::text, E'([a-z]+):([0-9]+)', 'gi') AS re "
-		 "WHERE re[1] ILIKE auth_name AND int4(re[2]) = auth_srid",
-		 postgis_spatial_ref_sys());
-	if (!srs) return 0;
-	if (SPI_OK_CONNECT != SPI_connect())
-		elog(NOTICE, "getSRIDbySRS: could not connect to SPI manager");
-		return 0;
-	err = SPI_execute_with_args(query, 1, argtypes, values, NULL, true, 1);
-	if (err < 0)
-		elog(NOTICE, "getSRIDbySRS: error executing query %d", err);
-		SPI_finish();
-		return 0;
-	/* no entry in spatial_ref_sys */
-	if (SPI_processed <= 0)
-		snprintf(query,
-			 max_query_size,
-			 "SELECT srid "
-			 "FROM %s, "
-			 "regexp_matches($1::text, E'urn:ogc:def:crs:([a-z]+):.*:([0-9]+)', 'gi') AS re "
-		if (err < 0)
-			SPI_finish();
-			return 0;
-			SPI_finish();
-			return 0;
-	srid = atoi(SPI_getvalue(SPI_tuptable->vals[0], SPI_tuptable->tupdesc, 1));
-	SPI_finish();
-	return srid;
  * Encode feature in GML
diff --git a/postgis/lwgeom_export.h b/postgis/lwgeom_export.h
deleted file mode 100644
index cd803e4..0000000
--- a/postgis/lwgeom_export.h
+++ /dev/null
@@ -1,25 +0,0 @@
- * PostGIS - Spatial Types for PostgreSQL
- * http://postgis.net
- * PostGIS is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 2 of the License, or
- * (at your option) any later version.
- * PostGIS is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
- * Copyright 2009 Olivier Courtin <olivier.courtin at oslandia.com>
-int getSRIDbySRS(FunctionCallInfo fcinfo, const char *SRS);
diff --git a/postgis/lwgeom_in_geohash.c b/postgis/lwgeom_in_geohash.c
index f95afd6..3f7c4ad 100644
--- a/postgis/lwgeom_in_geohash.c
+++ b/postgis/lwgeom_in_geohash.c
@@ -42,7 +42,6 @@ static void geohash_lwpgerror(char *msg, __attribute__((__unused__)) int error_c
 	lwpgerror("%s", msg);
 static GBOX*
 parse_geohash(char *geohash, int precision)
diff --git a/postgis/lwgeom_in_geojson.c b/postgis/lwgeom_in_geojson.c
index 58cef93..f5bd9b5 100644
--- a/postgis/lwgeom_in_geojson.c
+++ b/postgis/lwgeom_in_geojson.c
@@ -30,7 +30,7 @@
 #include "../postgis_config.h"
+#include "lwgeom_cache.h"
 #if defined(HAVE_LIBJSON)
@@ -110,7 +110,7 @@ Datum geom_from_geojson(PG_FUNCTION_ARGS)
 	if (srs)
-		srid = getSRIDbySRS(fcinfo, srs);
+		srid = GetSRIDCacheBySRS(fcinfo, srs);
 		lwfree(srs);
diff --git a/postgis/lwgeom_inout.c b/postgis/lwgeom_inout.c
index 5a1ae15..0757de0 100644
--- a/postgis/lwgeom_inout.c
+++ b/postgis/lwgeom_inout.c
@@ -45,7 +45,7 @@
 #include "funcapi.h"
 #include "geography.h" /* for lwgeom_valid_typmod */
@@ -147,7 +147,7 @@ Datum LWGEOM_in(PG_FUNCTION_ARGS)
 		lwgeom = lwgeom_from_geojson(str, &srs);
 		if (srs)
 			lwfree(srs);
 			lwgeom_set_srid(lwgeom, srid);
commit d427c87f27da94a67f98d4a256ed4854baa59eaa
Date:   Tue Apr 28 19:54:21 2020 +0200
    ST_AsX3D: Stop calculating the srs
    It was never used and amounted to 90% of the time
diff --git a/liblwgeom/cunit/cu_out_x3d.c b/liblwgeom/cunit/cu_out_x3d.c
index 3e10d35..a7f6893 100644
--- a/liblwgeom/cunit/cu_out_x3d.c
+++ b/liblwgeom/cunit/cu_out_x3d.c
@@ -17,10 +17,10 @@
 #include "liblwgeom_internal.h"
 #include "cu_tester.h"
-static void do_x3d3_test(char * in, char * out, char * srs, int precision, int option)
+static void do_x3d3_test(char * in, char * out, int precision, int option)
 	LWGEOM *g = lwgeom_from_wkt(in, LW_PARSER_CHECK_NONE);
-	lwvarlena_t *v = lwgeom_to_x3d3(g, srs, precision, option, "");
+	lwvarlena_t *v = lwgeom_to_x3d3(g, precision, option, "");
 	ASSERT_VARLENA_EQUAL(v, out);
@@ -32,7 +32,7 @@ static void do_x3d3_test(char * in, char * out, char * srs, int precision, int o
 static void do_x3d3_unsupported(char * in, char * out)
-	lwvarlena_t *v = lwgeom_to_x3d3(g, NULL, 0, 0, "");
+	lwvarlena_t *v = lwgeom_to_x3d3(g, 0, 0, "");
 	ASSERT_STRING_EQUAL(out, cu_error_msg);
 	cu_error_msg_reset();
@@ -48,23 +48,23 @@ static void out_x3d3_test_precision(void)
 	do_x3d3_test(
 	    "POINT(1.1111111111111 1.1111111111111 2.11111111111111)",
 	    "1 1 2",
-	    NULL, 0, 0);
+	    0, 0);
 	/* 3 digits precision */
 	do_x3d3_test(
 	    "1.111 1.111 2.111",
-	    NULL, 3, 0);
+	    3, 0);
 	/* 9 digits precision */
 	do_x3d3_test(
 	    "POINT(1.2345678901234 1.2345678901234 4.123456789001)",
 	    "1.23456789 1.23456789 4.123456789",
-	    NULL, 9, 0);
+	    9, 0);
 	/* huge data */
 	do_x3d3_test(
-	    "POINT(1E300 -105E-153 4E300)", "1e+300 0 4e+300", NULL, 0, 0);
+	    "POINT(1E300 -105E-153 4E300)", "1e+300 0 4e+300", 0, 0);
@@ -74,13 +74,13 @@ static void out_x3d3_test_geoms(void)
 	do_x3d3_test(
 	    "LINESTRING(0 1 5,2 3 6,4 5 7)",
 	    "<LineSet  vertexCount='3'><Coordinate point='0 1 5 2 3 6 4 5 7' /></LineSet>",
-	    NULL, 0, 0);
+	    0, 0);
 	/* Polygon **/
 	do_x3d3_test(
 	    "POLYGON((15 10 3,13.536 6.464 3,10 5 3,6.464 6.464 3,5 10 3,6.464 13.536 3,10 15 3,13.536 13.536 3,15 10 3))",
 	    "<IndexedFaceSet  convex='false' coordIndex='0 1 2 3 4 5 6 7'><Coordinate point='15 10 3 13.536 6.464 3 10 5 3 6.464 6.464 3 5 10 3 6.464 13.536 3 10 15 3 13.536 13.536 3 ' /></IndexedFaceSet>",
-	    NULL, 3, 0);
+	    3, 0);
 	/* TODO: Polygon - with internal ring - the answer is clearly wrong */
 	/** do_x3d3_test(
@@ -92,30 +92,30 @@ static void out_x3d3_test_geoms(void)
 	do_x3d3_test(
 	    "MULTIPOINT(0 1,2 3,4 5)",
 	    "<Polypoint2D  point='0 1 2 3 4 5 ' />",
-	    NULL, 0, 0);
+	    0, 0);
 	/* 3D MultiPoint */
 	do_x3d3_test(
 	    "MULTIPOINT Z(0 1 1,2 3 4,4 5 5)",
 	    "<PointSet ><Coordinate point='0 1 1 2 3 4 4 5 5 ' /></PointSet>",
-	    NULL, 0, 0);
+	    0, 0);
 	/* 3D Multiline */
 	do_x3d3_test(
 	    "MULTILINESTRING Z((0 1 1,2 3 4,4 5 5),(6 7 5,8 9 8,10 11 5))",
 	    "<IndexedLineSet  coordIndex='0 1 2 -1 3 4 5'><Coordinate point='0 1 1 2 3 4 4 5 5 6 7 5 8 9 8 10 11 5 ' /></IndexedLineSet>",
-	    NULL, 0, 0);
+	    0, 0);
 	/* MultiPolygon */
 	do_x3d3_test(
 	    "MULTIPOLYGON(((0 1 1,2 3 1,4 5 1,0 1 1)),((6 7 1,8 9 1,10 11 1,6 7 1)))",
 	    "<IndexedFaceSet  convex='false' coordIndex='0 1 2 -1 3 4 5'><Coordinate point='0 1 1 2 3 1 4 5 1 6 7 1 8 9 1 10 11 1 ' /></IndexedFaceSet>",
-	    NULL, 0, 0);
+	    0, 0);
 	/* PolyhedralSurface */
 	do_x3d3_test(
 	    "POLYHEDRALSURFACE( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)), ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)), ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)), ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)), ((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)), ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1)) )",
 	    "<IndexedFaceSet convex='false'  coordIndex='0 1 2 3 -1 4 5 6 7 -1 8 9 10 11 -1 12 13 14 15 -1 16 17 18 19 -1 20 21 22 23'><Coordinate point='0 0 0 0 0 1 0 1 1 0 1 0 0 0 0 0 1 0 1 1 0 1 0 0 0 0 0 1 0 0 1 0 1 0 0 1 1 1 0 1 1 1 1 0 1 1 0 0 0 1 0 0 1 1 1 1 1 1 1 0 0 0 1 1 0 1 1 1 1 0 1 1' /></IndexedFaceSet>",
-	    NULL, 0, 0);
+	    0, 0);
 	/* TODO: returns garbage at moment correctly implement GeometryCollection -- */
 	/** do_x3d3_test(
@@ -147,19 +147,19 @@ static void out_x3d3_test_option(void)
 	do_x3d3_test(
 	    "POINT(3.1111111111111 1.1111111111111 2.11111111111111)",
 	    "1 3 2",
-	    NULL, 0, 1);
+	    0, 1);
 	/* geocoordinate long,lat*/
 	do_x3d3_test(
 	    "SRID=4326;POLYGON((15 10 3,13.536 6.464 3,10 5 3,6.464 6.464 3,5 10 3,6.464 13.536 3,10 15 3,13.536 13.536 3,15 10 3))",
 	    "<IndexedFaceSet  convex='false' coordIndex='0 1 2 3 4 5 6 7'><GeoCoordinate geoSystem='\"GD\" \"WE\" \"longitude_first\"' point='15 10 3 13.536 6.464 3 10 5 3 6.464 6.464 3 5 10 3 6.464 13.536 3 10 15 3 13.536 13.536 3 ' /></IndexedFaceSet>",
-	    NULL, 3, 2);
+	    3, 2);
 	/* geocoordinate lat long*/
 	do_x3d3_test(
 	    "<IndexedFaceSet  convex='false' coordIndex='0 1 2 3 4 5 6 7'><GeoCoordinate geoSystem='\"GD\" \"WE\" \"latitude_first\"' point='10 15 3 6.464 13.536 3 5 10 3 6.464 6.464 3 10 5 3 13.536 6.464 3 15 10 3 13.536 13.536 3 ' /></IndexedFaceSet>",
-	    NULL, 3, 3);
+	    3, 3);
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 6635920..7c573b5 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1700,7 +1700,7 @@ extern lwvarlena_t* lwgeom_extent_to_gml3(const LWGEOM *geom, const char *srs, i
 extern lwvarlena_t* lwgeom_to_gml3(const LWGEOM *geom, const char *srs, int precision, int opts, const char *prefix, const char *id);
 extern lwvarlena_t* lwgeom_to_kml2(const LWGEOM *geom, int precision, const char *prefix);
 extern lwvarlena_t* lwgeom_to_geojson(const LWGEOM *geo, const char *srs, int precision, int has_bbox);
-extern lwvarlena_t* lwgeom_to_x3d3(const LWGEOM *geom, const char *srs, int precision, int opts, const char *defid);
+extern lwvarlena_t* lwgeom_to_x3d3(const LWGEOM *geom, int precision, int opts, const char *defid);
 extern lwvarlena_t* lwgeom_to_svg(const LWGEOM *geom, int precision, int relative);
 extern lwvarlena_t* lwgeom_to_encoded_polyline(const LWGEOM *geom, int precision);
diff --git a/liblwgeom/lwout_x3d.c b/liblwgeom/lwout_x3d.c
index 12dd23b..c70ab82 100644
--- a/liblwgeom/lwout_x3d.c
+++ b/liblwgeom/lwout_x3d.c
@@ -34,7 +34,7 @@
 /* takes a GEOMETRY and returns a X3D representation */
 lwvarlena_t *
-lwgeom_to_x3d3(const LWGEOM *geom, const char *srs, int precision, int opts, const char *defid)
+lwgeom_to_x3d3(const LWGEOM *geom, int precision, int opts, const char *defid)
 	stringbuffer_t *sb;
 	int rv;
@@ -48,7 +48,7 @@ lwgeom_to_x3d3(const LWGEOM *geom, const char *srs, int precision, int opts, con
 	sb = stringbuffer_create();
-	rv = lwgeom_to_x3d3_sb(geom, srs, precision, opts, defid, sb);
+	rv = lwgeom_to_x3d3_sb(geom, precision, opts, defid, sb);
 	if ( rv == LW_FAILURE )
@@ -63,17 +63,17 @@ lwgeom_to_x3d3(const LWGEOM *geom, const char *srs, int precision, int opts, con
 /* takes a GEOMETRY and appends to string buffer the x3d output */
 static int
-lwgeom_to_x3d3_sb(const LWGEOM *geom, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
+lwgeom_to_x3d3_sb(const LWGEOM *geom, int precision, int opts, const char *defid, stringbuffer_t *sb)
 	int type = geom->type;
 	switch (type)
 	case POINTTYPE:
-		return asx3d3_point_sb((LWPOINT*)geom, srs, precision, opts, defid, sb);
+		return asx3d3_point_sb((LWPOINT *)geom, precision, opts, defid, sb);
 	case LINETYPE:
-		return asx3d3_line_sb((LWLINE*)geom, srs, precision, opts, defid, sb);
+		return asx3d3_line_sb((LWLINE *)geom, precision, opts, defid, sb);
 	case POLYGONTYPE:
@@ -81,27 +81,27 @@ lwgeom_to_x3d3_sb(const LWGEOM *geom, const char *srs, int precision, int opts,
 		* seems like the simplest way to go so treat just like a mulitpolygon
 		LWCOLLECTION *tmp = (LWCOLLECTION*)lwgeom_as_multi(geom);
-		asx3d3_multi_sb(tmp, srs, precision, opts, defid, sb);
+		asx3d3_multi_sb(tmp, precision, opts, defid, sb);
 		lwcollection_free(tmp);
 		return LW_SUCCESS;
 	case TRIANGLETYPE:
-		return asx3d3_triangle_sb((LWTRIANGLE*)geom, srs, precision, opts, defid, sb);
+		return asx3d3_triangle_sb((LWTRIANGLE *)geom, precision, opts, defid, sb);
 	case MULTIPOINTTYPE:
 	case MULTILINETYPE:
 	case MULTIPOLYGONTYPE:
-		return asx3d3_multi_sb((LWCOLLECTION*)geom, srs, precision, opts, defid, sb);
+		return asx3d3_multi_sb((LWCOLLECTION *)geom, precision, opts, defid, sb);
 	case POLYHEDRALSURFACETYPE:
-		return asx3d3_psurface_sb((LWPSURFACE*)geom, srs, precision, opts, defid, sb);
+		return asx3d3_psurface_sb((LWPSURFACE *)geom, precision, opts, defid, sb);
 	case TINTYPE:
-		return asx3d3_tin_sb((LWTIN*)geom, srs, precision, opts, defid, sb);
+		return asx3d3_tin_sb((LWTIN *)geom, precision, opts, defid, sb);
 	case COLLECTIONTYPE:
-		return asx3d3_collection_sb((LWCOLLECTION*)geom, srs, precision, opts, defid, sb);
+		return asx3d3_collection_sb((LWCOLLECTION *)geom, precision, opts, defid, sb);
 	default:
 		lwerror("lwgeom_to_x3d3: '%s' geometry type not supported", lwtype_name(type));
@@ -110,8 +110,11 @@ lwgeom_to_x3d3_sb(const LWGEOM *geom, const char *srs, int precision, int opts,
 static int
-asx3d3_point_sb(const LWPOINT *point, __attribute__((__unused__)) const char *srs, int precision,
-		int opts, __attribute__((__unused__)) const char *defid, stringbuffer_t *sb)
+asx3d3_point_sb(const LWPOINT *point,
+		int precision,
+		int opts,
+		__attribute__((__unused__)) const char *defid,
+		stringbuffer_t *sb)
 	/** for point we just output the coordinates **/
 	return ptarray_to_x3d3_sb(point->point, precision, opts, 0, sb);
@@ -215,8 +218,11 @@ asx3d3_mpoly_coordindex_sb(const LWMPOLY *psur, stringbuffer_t *sb)
 /** Return the linestring as an X3D LineSet */
 static int
-asx3d3_line_sb(const LWLINE *line, __attribute__((__unused__)) const char *srs, int precision,
+asx3d3_line_sb(const LWLINE *line,
+	       int precision,
+	       int opts,
 	/* int dimension=2; */
@@ -242,8 +248,12 @@ asx3d3_line_sb(const LWLINE *line, __attribute__((__unused__)) const char *srs,
 /** Compute the X3D coordinates of the polygon and add to string buffer **/
 static int
-asx3d3_poly_sb(const LWPOLY *poly, __attribute__((__unused__))  const char *srs, int precision,
-	       int opts, __attribute__((__unused__)) int is_patch, __attribute__((__unused__)) const char *defid, stringbuffer_t *sb)
+asx3d3_poly_sb(const LWPOLY *poly,
+	       int precision,
+	       int opts,
+	       __attribute__((__unused__)) int is_patch,
 	uint32_t i;
 	for (i=0; i<poly->nrings; i++)
@@ -255,8 +265,11 @@ asx3d3_poly_sb(const LWPOLY *poly, __attribute__((__unused__))  const char *srs,
 static int
-asx3d3_triangle_sb(const LWTRIANGLE *triangle, __attribute__((__unused__))  const char *srs, int precision,
+asx3d3_triangle_sb(const LWTRIANGLE *triangle,
+		   int precision,
+		   int opts,
 	return  ptarray_to_x3d3_sb(triangle->points, precision, opts, 1, sb);
@@ -266,7 +279,7 @@ asx3d3_triangle_sb(const LWTRIANGLE *triangle, __attribute__((__unused__))  cons
  * Don't call this with single-geoms inspected!
 static int
-asx3d3_multi_sb(const LWCOLLECTION *col, __attribute__((__unused__)) const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
+asx3d3_multi_sb(const LWCOLLECTION *col, int precision, int opts, const char *defid, stringbuffer_t *sb)
 	char *x3dtype;
 	uint32_t i;
@@ -317,7 +330,7 @@ asx3d3_multi_sb(const LWCOLLECTION *col, __attribute__((__unused__)) const char
 		subgeom = col->geoms[i];
 		if (subgeom->type == POINTTYPE)
-			asx3d3_point_sb((LWPOINT*)subgeom, 0, precision, opts, defid, sb);
+			asx3d3_point_sb((LWPOINT *)subgeom, precision, opts, defid, sb);
 			stringbuffer_aprintf(sb, " ");
 		else if (subgeom->type == LINETYPE)
@@ -327,7 +340,7 @@ asx3d3_multi_sb(const LWCOLLECTION *col, __attribute__((__unused__)) const char
 		else if (subgeom->type == POLYGONTYPE)
-			asx3d3_poly_sb((LWPOLY*)subgeom, 0, precision, opts, 0, defid, sb);
+			asx3d3_poly_sb((LWPOLY *)subgeom, precision, opts, 0, defid, sb);
@@ -345,7 +358,7 @@ asx3d3_multi_sb(const LWCOLLECTION *col, __attribute__((__unused__)) const char
 static int
-asx3d3_psurface_sb(const LWPSURFACE *psur, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
+asx3d3_psurface_sb(const LWPSURFACE *psur, int precision, int opts, const char *defid, stringbuffer_t *sb)
 	uint32_t i;
 	uint32_t j;
@@ -383,7 +396,7 @@ asx3d3_psurface_sb(const LWPSURFACE *psur, const char *srs, int precision, int o
 	for (i=0; i<psur->ngeoms; i++)
-		asx3d3_poly_sb(psur->geoms[i], srs, precision, opts, 1, defid, sb);
+		asx3d3_poly_sb(psur->geoms[i], precision, opts, 1, defid, sb);
 		if (i < (psur->ngeoms - 1) )
 			stringbuffer_aprintf(sb, " "); /* only add a trailing space if its not the last polygon in the set */
@@ -398,7 +411,7 @@ asx3d3_psurface_sb(const LWPSURFACE *psur, const char *srs, int precision, int o
  * Computes X3D representation of TIN (as IndexedTriangleSet and adds to string buffer)
 static int
-asx3d3_tin_sb(const LWTIN *tin, __attribute__((__unused__)) const char *srs,  int precision, int opts, const char *defid, stringbuffer_t *sb)
+asx3d3_tin_sb(const LWTIN *tin, int precision, int opts, const char *defid, stringbuffer_t *sb)
 	uint32_t i;
 	uint32_t k;
@@ -422,8 +435,7 @@ asx3d3_tin_sb(const LWTIN *tin, __attribute__((__unused__)) const char *srs,  in
 	for (i=0; i<tin->ngeoms; i++)
-		asx3d3_triangle_sb(tin->geoms[i], 0, precision,
-		                           opts, defid, sb);
+		asx3d3_triangle_sb(tin->geoms[i], precision, opts, defid, sb);
 		if (i < (tin->ngeoms - 1) )
@@ -436,7 +448,7 @@ asx3d3_tin_sb(const LWTIN *tin, __attribute__((__unused__)) const char *srs,  in
 static int
-asx3d3_collection_sb(const LWCOLLECTION *col, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
+asx3d3_collection_sb(const LWCOLLECTION *col, int precision, int opts, const char *defid, stringbuffer_t *sb)
 	uint32_t i;
 	LWGEOM *subgeom;
@@ -454,32 +466,30 @@ asx3d3_collection_sb(const LWCOLLECTION *col, const char *srs, int precision, in
 		stringbuffer_aprintf(sb, "<Shape%s>", defid);
 		if ( subgeom->type == POINTTYPE )
 		else if ( subgeom->type == LINETYPE )
-			asx3d3_line_sb((LWLINE*)subgeom, 0, precision, opts, defid, sb);
+			asx3d3_line_sb((LWLINE *)subgeom, precision, opts, defid, sb);
 		else if ( subgeom->type == POLYGONTYPE )
 		else if ( subgeom->type == TINTYPE )
-			asx3d3_tin_sb((LWTIN*)subgeom, srs,  precision, opts,  defid, sb);
+			asx3d3_tin_sb((LWTIN *)subgeom, precision, opts, defid, sb);
 		else if ( subgeom->type == POLYHEDRALSURFACETYPE )
-			asx3d3_psurface_sb((LWPSURFACE*)subgeom, srs, precision, opts,  defid, sb);
+			asx3d3_psurface_sb((LWPSURFACE *)subgeom, precision, opts, defid, sb);
 		else if ( lwgeom_is_collection(subgeom) )
 			if ( subgeom->type == COLLECTIONTYPE )
-				asx3d3_collection_sb((LWCOLLECTION*)subgeom, 0, precision, opts, defid, sb);
+				asx3d3_collection_sb((LWCOLLECTION *)subgeom, precision, opts, defid, sb);
 			else
-				asx3d3_multi_sb((LWCOLLECTION*)subgeom, 0, precision, opts, defid, sb);
+				asx3d3_multi_sb((LWCOLLECTION *)subgeom, precision, opts, defid, sb);
 		else
 			lwerror("asx3d3_collection_buf: unknown geometry type");
diff --git a/liblwgeom/lwout_x3d.h b/liblwgeom/lwout_x3d.h
index a5fc752..ca8c6db 100644
--- a/liblwgeom/lwout_x3d.h
+++ b/liblwgeom/lwout_x3d.h
@@ -31,16 +31,18 @@
 #include "stringbuffer.h"
 /** defid is the id of the coordinate can be used to hold other elements DEF='abc' transform='' etc. **/
-static int lwgeom_to_x3d3_sb(const LWGEOM *geom, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int lwgeom_to_x3d3_sb(const LWGEOM *geom, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_point_sb(const LWPOINT *point, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_line_sb(const LWLINE *line, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_point_sb(const LWPOINT *point, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_line_sb(const LWLINE *line, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_triangle_sb(const LWTRIANGLE *triangle, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int
+asx3d3_triangle_sb(const LWTRIANGLE *triangle, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_multi_sb(const LWCOLLECTION *col, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_psurface_sb(const LWPSURFACE *psur, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_tin_sb(const LWTIN *tin, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_multi_sb(const LWCOLLECTION *col, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_psurface_sb(const LWPSURFACE *psur, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_tin_sb(const LWTIN *tin, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_collection_sb(const LWCOLLECTION *col, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int
+asx3d3_collection_sb(const LWCOLLECTION *col, int precision, int opts, const char *defid, stringbuffer_t *sb);
 static int ptarray_to_x3d3_sb(POINTARRAY *pa, int precision, int opts, int is_closed, stringbuffer_t *sb );
index 22eb58f..7a71f51 100644
@@ -388,8 +388,6 @@ Datum LWGEOM_asX3D(PG_FUNCTION_ARGS)
 	GSERIALIZED *geom;
 	LWGEOM *lwgeom;
 	int version;
-	const char *srs;
-	int32_t srid;
 	int option = 0;
 	int precision = DBL_DIG;
 	static const char* default_defid = "x3d:"; /* default defid */
@@ -424,7 +422,6 @@ Datum LWGEOM_asX3D(PG_FUNCTION_ARGS)
 		option = PG_GETARG_INT32(3);
 	/* retrieve defid */
 	if (PG_NARGS() >4 && !PG_ARGISNULL(4))
@@ -447,15 +444,10 @@ Datum LWGEOM_asX3D(PG_FUNCTION_ARGS)
 	lwgeom = lwgeom_from_gserialized(geom);
-	srid = gserialized_get_srid(geom);
-	if (srid == SRID_UNKNOWN)      srs = NULL;
-	else if (option & 1)
-		srs = GetSRSCacheBySRID(fcinfo, srid, false);
-	else
-		srs = GetSRSCacheBySRID(fcinfo, srid, true);
 	if (option & LW_X3D_USE_GEOCOORDS) {
-		if (srid != 4326) {
+		if (lwgeom->srid != 4326)
 			PG_FREE_IF_COPY(geom, 0);
 			/** TODO: we need to support UTM and other coordinate systems supported by X3D eventually
 			http://www.web3d.org/documents/specifications/19775-1/V3.2/Part01/components/geodata.html#t-earthgeoids **/
@@ -464,7 +456,7 @@ Datum LWGEOM_asX3D(PG_FUNCTION_ARGS)
-	PG_RETURN_TEXT_P(lwgeom_to_x3d3(lwgeom, srs, precision, option, defid));
+	PG_RETURN_TEXT_P(lwgeom_to_x3d3(lwgeom, precision, option, defid));
commit b38079d4f1fac448c2a23681034521464d743cb6
Date:   Tue Apr 28 19:10:49 2020 +0200
    Cache getSRSbySRID
index aa7f74c..6635920 100644
@@ -1699,8 +1699,8 @@ extern lwvarlena_t* lwgeom_extent_to_gml2(const LWGEOM *geom, const char *srs, i
 extern lwvarlena_t* lwgeom_extent_to_gml3(const LWGEOM *geom, const char *srs, int precision, int opts, const char *prefix);
-extern lwvarlena_t* lwgeom_to_geojson(const LWGEOM *geo, char *srs, int precision, int has_bbox);
-extern lwvarlena_t* lwgeom_to_x3d3(const LWGEOM *geom, char *srs, int precision, int opts, const char *defid);
+extern lwvarlena_t* lwgeom_to_geojson(const LWGEOM *geo, const char *srs, int precision, int has_bbox);
+extern lwvarlena_t* lwgeom_to_x3d3(const LWGEOM *geom, const char *srs, int precision, int opts, const char *defid);
diff --git a/liblwgeom/lwout_geojson.c b/liblwgeom/lwout_geojson.c
index 3b53f83..2a5a6ce 100644
--- a/liblwgeom/lwout_geojson.c
+++ b/liblwgeom/lwout_geojson.c
@@ -28,14 +28,14 @@
 #include <string.h>	/* strlen */
 #include <assert.h>
-static lwvarlena_t *asgeojson_point(const LWPOINT *point, char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_line(const LWLINE *line, char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_triangle(const LWTRIANGLE *tri, char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_poly(const LWPOLY *poly, char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_multipoint(const LWMPOINT *mpoint, char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_multiline(const LWMLINE *mline, char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_multipolygon(const LWMPOLY *mpoly, char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_collection(const LWCOLLECTION *col, char *srs, GBOX *bbox, int precision);
+static lwvarlena_t *asgeojson_point(const LWPOINT *point, const char *srs, GBOX *bbox, int precision);
+static lwvarlena_t *asgeojson_line(const LWLINE *line, const char *srs, GBOX *bbox, int precision);
+static lwvarlena_t *asgeojson_triangle(const LWTRIANGLE *tri, const char *srs, GBOX *bbox, int precision);
+static lwvarlena_t *asgeojson_poly(const LWPOLY *poly, const char *srs, GBOX *bbox, int precision);
+static lwvarlena_t *asgeojson_multipoint(const LWMPOINT *mpoint, const char *srs, GBOX *bbox, int precision);
+static lwvarlena_t *asgeojson_multiline(const LWMLINE *mline, const char *srs, GBOX *bbox, int precision);
+static lwvarlena_t *asgeojson_multipolygon(const LWMPOLY *mpoly, const char *srs, GBOX *bbox, int precision);
+static lwvarlena_t *asgeojson_collection(const LWCOLLECTION *col, const char *srs, GBOX *bbox, int precision);
 static size_t asgeojson_geom_size(const LWGEOM *geom, GBOX *bbox, int precision);
 static size_t asgeojson_geom_buf(const LWGEOM *geom, char *output, GBOX *bbox, int precision);
@@ -46,7 +46,7 @@ static size_t pointArray_geojson_size(POINTARRAY *pa, int precision);
  * Takes a GEOMETRY and returns a GeoJson representation
 lwvarlena_t *
-lwgeom_to_geojson(const LWGEOM *geom, char *srs, int precision, int has_bbox)
+lwgeom_to_geojson(const LWGEOM *geom, const char *srs, int precision, int has_bbox)
 	GBOX *bbox = NULL;
@@ -96,7 +96,7 @@ lwgeom_to_geojson(const LWGEOM *geom, char *srs, int precision, int has_bbox)
  * Handle SRS
 static size_t
-asgeojson_srs_size(char *srs)
+asgeojson_srs_size(const char *srs)
 	int size;
@@ -108,7 +108,7 @@ asgeojson_srs_size(char *srs)
 static size_t
-asgeojson_srs_buf(char *output, char *srs)
+asgeojson_srs_buf(char *output, const char *srs)
 	char *ptr = output;
@@ -166,7 +166,7 @@ asgeojson_bbox_buf(char *output, GBOX *bbox, int hasz, int precision)
 static size_t
-asgeojson_point_size(const LWPOINT *point, char *srs, GBOX *bbox, int precision)
+asgeojson_point_size(const LWPOINT *point, const char *srs, GBOX *bbox, int precision)
 	int size;
@@ -184,7 +184,7 @@ asgeojson_point_size(const LWPOINT *point, char *srs, GBOX *bbox, int precision)
 static size_t
-asgeojson_point_buf(const LWPOINT *point, char *srs, char *output, GBOX *bbox, int precision)
+asgeojson_point_buf(const LWPOINT *point, const char *srs, char *output, GBOX *bbox, int precision)
 	char *ptr = output;
@@ -202,7 +202,7 @@ asgeojson_point_buf(const LWPOINT *point, char *srs, char *output, GBOX *bbox, i
-asgeojson_point(const LWPOINT *point, char *srs, GBOX *bbox, int precision)
+asgeojson_point(const LWPOINT *point, const char *srs, GBOX *bbox, int precision)
 	uint32_t size = asgeojson_point_size(point, srs, bbox, precision);
 	lwvarlena_t *output = (lwvarlena_t *)lwalloc(size + LWVARHDRSZ);
@@ -216,7 +216,7 @@ asgeojson_point(const LWPOINT *point, char *srs, GBOX *bbox, int precision)
 static size_t
-asgeojson_triangle_size(const LWTRIANGLE *tri, char *srs, GBOX *bbox, int precision)
+asgeojson_triangle_size(const LWTRIANGLE *tri, const char *srs, GBOX *bbox, int precision)
 	int size;
@@ -232,7 +232,7 @@ asgeojson_triangle_size(const LWTRIANGLE *tri, char *srs, GBOX *bbox, int precis
 static size_t
-asgeojson_triangle_buf(const LWTRIANGLE *tri, char *srs, char *output, GBOX *bbox, int precision)
+asgeojson_triangle_buf(const LWTRIANGLE *tri, const char *srs, char *output, GBOX *bbox, int precision)
 	char *ptr = output;
@@ -249,7 +249,7 @@ asgeojson_triangle_buf(const LWTRIANGLE *tri, char *srs, char *output, GBOX *bbo
-asgeojson_triangle(const LWTRIANGLE *tri, char *srs, GBOX *bbox, int precision)
+asgeojson_triangle(const LWTRIANGLE *tri, const char *srs, GBOX *bbox, int precision)
 	uint32_t size = asgeojson_triangle_size(tri, srs, bbox, precision);
@@ -263,7 +263,7 @@ asgeojson_triangle(const LWTRIANGLE *tri, char *srs, GBOX *bbox, int precision)
 static size_t
-asgeojson_line_size(const LWLINE *line, char *srs, GBOX *bbox, int precision)
+asgeojson_line_size(const LWLINE *line, const char *srs, GBOX *bbox, int precision)
 	int size;
@@ -277,7 +277,7 @@ asgeojson_line_size(const LWLINE *line, char *srs, GBOX *bbox, int precision)
 static size_t
-asgeojson_line_buf(const LWLINE *line, char *srs, char *output, GBOX *bbox, int precision)
+asgeojson_line_buf(const LWLINE *line, const char *srs, char *output, GBOX *bbox, int precision)
 	char *ptr=output;
@@ -292,7 +292,7 @@ asgeojson_line_buf(const LWLINE *line, char *srs, char *output, GBOX *bbox, int
-asgeojson_line(const LWLINE *line, char *srs, GBOX *bbox, int precision)
+asgeojson_line(const LWLINE *line, const char *srs, GBOX *bbox, int precision)
 	uint32_t size = asgeojson_line_size(line, srs, bbox, precision);
@@ -308,7 +308,7 @@ asgeojson_line(const LWLINE *line, char *srs, GBOX *bbox, int precision)
 static size_t
-asgeojson_poly_size(const LWPOLY *poly, char *srs, GBOX *bbox, int precision)
+asgeojson_poly_size(const LWPOLY *poly, const char *srs, GBOX *bbox, int precision)
 	size_t size;
 	uint32_t i;
@@ -329,7 +329,7 @@ asgeojson_poly_size(const LWPOLY *poly, char *srs, GBOX *bbox, int precision)
 static size_t
-asgeojson_poly_buf(const LWPOLY *poly, char *srs, char *output, GBOX *bbox, int precision)
+asgeojson_poly_buf(const LWPOLY *poly, const char *srs, char *output, GBOX *bbox, int precision)
 	uint32_t i;
@@ -352,7 +352,7 @@ asgeojson_poly_buf(const LWPOLY *poly, char *srs, char *output, GBOX *bbox, int
-asgeojson_poly(const LWPOLY *poly, char *srs, GBOX *bbox, int precision)
+asgeojson_poly(const LWPOLY *poly, const char *srs, GBOX *bbox, int precision)
 	uint32_t size = asgeojson_poly_size(poly, srs, bbox, precision);
@@ -368,7 +368,7 @@ asgeojson_poly(const LWPOLY *poly, char *srs, GBOX *bbox, int precision)
 static size_t
-asgeojson_multipoint_size(const LWMPOINT *mpoint, char *srs, GBOX *bbox, int precision)
+asgeojson_multipoint_size(const LWMPOINT *mpoint, const char *srs, GBOX *bbox, int precision)
 	LWPOINT * point;
 	int size;
@@ -390,7 +390,7 @@ asgeojson_multipoint_size(const LWMPOINT *mpoint, char *srs, GBOX *bbox, int pre
 static size_t
-asgeojson_multipoint_buf(const LWMPOINT *mpoint, char *srs, char *output, GBOX *bbox, int precision)
+asgeojson_multipoint_buf(const LWMPOINT *mpoint, const char *srs, char *output, GBOX *bbox, int precision)
 	LWPOINT *point;
 	uint32_t i;
@@ -413,7 +413,7 @@ asgeojson_multipoint_buf(const LWMPOINT *mpoint, char *srs, char *output, GBOX *
-asgeojson_multipoint(const LWMPOINT *mpoint, char *srs, GBOX *bbox, int precision)
+asgeojson_multipoint(const LWMPOINT *mpoint, const char *srs, GBOX *bbox, int precision)
 	uint32_t size = asgeojson_multipoint_size(mpoint, srs, bbox, precision);
@@ -429,7 +429,7 @@ asgeojson_multipoint(const LWMPOINT *mpoint, char *srs, GBOX *bbox, int precisio
 static size_t
-asgeojson_multiline_size(const LWMLINE *mline, char *srs, GBOX *bbox, int precision)
+asgeojson_multiline_size(const LWMLINE *mline, const char *srs, GBOX *bbox, int precision)
 	LWLINE * line;
 	int size;
@@ -452,7 +452,7 @@ asgeojson_multiline_size(const LWMLINE *mline, char *srs, GBOX *bbox, int precis
 static size_t
-asgeojson_multiline_buf(const LWMLINE *mline, char *srs, char *output, GBOX *bbox, int precision)
+asgeojson_multiline_buf(const LWMLINE *mline, const char *srs, char *output, GBOX *bbox, int precision)
 	LWLINE *line;
 	uint32_t i;
@@ -478,7 +478,7 @@ asgeojson_multiline_buf(const LWMLINE *mline, char *srs, char *output, GBOX *bbo
-asgeojson_multiline(const LWMLINE *mline, char *srs, GBOX *bbox, int precision)
+asgeojson_multiline(const LWMLINE *mline, const char *srs, GBOX *bbox, int precision)
 	uint32_t size = asgeojson_multiline_size(mline, srs, bbox, precision);
@@ -494,7 +494,7 @@ asgeojson_multiline(const LWMLINE *mline, char *srs, GBOX *bbox, int precision)
 static size_t
-asgeojson_multipolygon_size(const LWMPOLY *mpoly, char *srs, GBOX *bbox, int precision)
+asgeojson_multipolygon_size(const LWMPOLY *mpoly, const char *srs, GBOX *bbox, int precision)
 	LWPOLY *poly;
 	int size;
@@ -522,7 +522,7 @@ asgeojson_multipolygon_size(const LWMPOLY *mpoly, char *srs, GBOX *bbox, int pre
 static size_t
-asgeojson_multipolygon_buf(const LWMPOLY *mpoly, char *srs, char *output, GBOX *bbox, int precision)
+asgeojson_multipolygon_buf(const LWMPOLY *mpoly, const char *srs, char *output, GBOX *bbox, int precision)
 	LWPOLY *poly;
 	uint32_t i, j;
@@ -552,7 +552,7 @@ asgeojson_multipolygon_buf(const LWMPOLY *mpoly, char *srs, char *output, GBOX *
-asgeojson_multipolygon(const LWMPOLY *mpoly, char *srs, GBOX *bbox, int precision)
+asgeojson_multipolygon(const LWMPOLY *mpoly, const char *srs, GBOX *bbox, int precision)
 	uint32_t size = asgeojson_multipolygon_size(mpoly, srs, bbox, precision);
@@ -568,7 +568,7 @@ asgeojson_multipolygon(const LWMPOLY *mpoly, char *srs, GBOX *bbox, int precisio
 static size_t
-asgeojson_collection_size(const LWCOLLECTION *col, char *srs, GBOX *bbox, int precision)
+asgeojson_collection_size(const LWCOLLECTION *col, const char *srs, GBOX *bbox, int precision)
 	uint32_t i;
 	size_t size;
@@ -591,7 +591,7 @@ asgeojson_collection_size(const LWCOLLECTION *col, char *srs, GBOX *bbox, int pr
 static size_t
-asgeojson_collection_buf(const LWCOLLECTION *col, char *srs, char *output, GBOX *bbox, int precision)
+asgeojson_collection_buf(const LWCOLLECTION *col, const char *srs, char *output, GBOX *bbox, int precision)
 	uint32_t i;
 	char *ptr=output;
@@ -615,7 +615,7 @@ asgeojson_collection_buf(const LWCOLLECTION *col, char *srs, char *output, GBOX
-asgeojson_collection(const LWCOLLECTION *col, char *srs, GBOX *bbox, int precision)
+asgeojson_collection(const LWCOLLECTION *col, const char *srs, GBOX *bbox, int precision)
 	uint32_t size = asgeojson_collection_size(col, srs, bbox, precision);
index 0564406..12dd23b 100644
@@ -34,7 +34,7 @@
 lwvarlena_t *
-lwgeom_to_x3d3(const LWGEOM *geom, char *srs, int precision, int opts, const char *defid)
+lwgeom_to_x3d3(const LWGEOM *geom, const char *srs, int precision, int opts, const char *defid)
 	stringbuffer_t *sb;
 	int rv;
@@ -63,7 +63,7 @@ lwgeom_to_x3d3(const LWGEOM *geom, char *srs, int precision, int opts, const cha
 static int
-lwgeom_to_x3d3_sb(const LWGEOM *geom, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
+lwgeom_to_x3d3_sb(const LWGEOM *geom, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
@@ -110,7 +110,7 @@ lwgeom_to_x3d3_sb(const LWGEOM *geom, char *srs, int precision, int opts, const
 static int
-asx3d3_point_sb(const LWPOINT *point, __attribute__((__unused__)) char *srs, int precision,
+asx3d3_point_sb(const LWPOINT *point, __attribute__((__unused__)) const char *srs, int precision,
@@ -215,7 +215,7 @@ asx3d3_mpoly_coordindex_sb(const LWMPOLY *psur, stringbuffer_t *sb)
 static int
-asx3d3_line_sb(const LWLINE *line, __attribute__((__unused__)) char *srs, int precision,
+asx3d3_line_sb(const LWLINE *line, __attribute__((__unused__)) const char *srs, int precision,
@@ -242,7 +242,7 @@ asx3d3_line_sb(const LWLINE *line, __attribute__((__unused__)) char *srs, int pr
 static int
-asx3d3_poly_sb(const LWPOLY *poly, __attribute__((__unused__))  char *srs, int precision,
+asx3d3_poly_sb(const LWPOLY *poly, __attribute__((__unused__))  const char *srs, int precision,
 	uint32_t i;
@@ -255,7 +255,7 @@ asx3d3_poly_sb(const LWPOLY *poly, __attribute__((__unused__))  char *srs, int p
 static int
-asx3d3_triangle_sb(const LWTRIANGLE *triangle, __attribute__((__unused__))  char *srs, int precision,
+asx3d3_triangle_sb(const LWTRIANGLE *triangle, __attribute__((__unused__))  const char *srs, int precision,
@@ -266,7 +266,7 @@ asx3d3_triangle_sb(const LWTRIANGLE *triangle, __attribute__((__unused__))  char
 static int
-asx3d3_multi_sb(const LWCOLLECTION *col, __attribute__((__unused__)) char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
+asx3d3_multi_sb(const LWCOLLECTION *col, __attribute__((__unused__)) const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
 	char *x3dtype;
 	uint32_t i;
@@ -345,7 +345,7 @@ asx3d3_multi_sb(const LWCOLLECTION *col, __attribute__((__unused__)) char *srs,
 static int
-asx3d3_psurface_sb(const LWPSURFACE *psur, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
+asx3d3_psurface_sb(const LWPSURFACE *psur, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
 	uint32_t i;
 	uint32_t j;
@@ -398,7 +398,7 @@ asx3d3_psurface_sb(const LWPSURFACE *psur, char *srs, int precision, int opts, c
 static int
-asx3d3_tin_sb(const LWTIN *tin, __attribute__((__unused__)) char *srs,  int precision, int opts, const char *defid, stringbuffer_t *sb)
+asx3d3_tin_sb(const LWTIN *tin, __attribute__((__unused__)) const char *srs,  int precision, int opts, const char *defid, stringbuffer_t *sb)
 	uint32_t i;
 	uint32_t k;
@@ -436,7 +436,7 @@ asx3d3_tin_sb(const LWTIN *tin, __attribute__((__unused__)) char *srs,  int prec
 static int
-asx3d3_collection_sb(const LWCOLLECTION *col, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
+asx3d3_collection_sb(const LWCOLLECTION *col, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb)
 	uint32_t i;
 	LWGEOM *subgeom;
index 31a3515..a5fc752 100644
@@ -31,16 +31,16 @@
-static int lwgeom_to_x3d3_sb(const LWGEOM *geom, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int lwgeom_to_x3d3_sb(const LWGEOM *geom, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_point_sb(const LWPOINT *point, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_line_sb(const LWLINE *line, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_point_sb(const LWPOINT *point, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_line_sb(const LWLINE *line, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_triangle_sb(const LWTRIANGLE *triangle, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_triangle_sb(const LWTRIANGLE *triangle, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_multi_sb(const LWCOLLECTION *col, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_psurface_sb(const LWPSURFACE *psur, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_tin_sb(const LWTIN *tin, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_multi_sb(const LWCOLLECTION *col, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_psurface_sb(const LWPSURFACE *psur, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_tin_sb(const LWTIN *tin, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
-static int asx3d3_collection_sb(const LWCOLLECTION *col, char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
+static int asx3d3_collection_sb(const LWCOLLECTION *col, const char *srs, int precision, int opts, const char *defid, stringbuffer_t *sb);
index 797fb66..33e2371 100644
@@ -333,3 +333,109 @@ ToastCacheGetGeometry(FunctionCallInfo fcinfo, uint32_t argnum)
 		return (GSERIALIZED*)PG_DETOAST_DATUM(datum);
+ * Retrieve an SRS from a given SRID
+ * Could return SRS as short one (i.e EPSG:4326)
+ * or as long one: (i.e urn:ogc:def:crs:EPSG::4326)
+static char *
+getSRSbySRID(FunctionCallInfo fcinfo, int32_t srid, bool short_crs)
+	static const uint16_t max_query_size = 512;
+	char query[512];
+	char *srs, *srscopy;
+	int size, err;
+		elog(NOTICE, "%s: could not connect to SPI manager", __func__);
+		SPI_finish();
+		return NULL;
+	if (short_crs)
+		snprintf(query,
+			 max_query_size,
+			 "SELECT auth_name||':'||auth_srid \
+		        FROM %s WHERE srid='%d'",
+			 postgis_spatial_ref_sys(),
+			 srid);
+	else
+		snprintf(query,
+			 max_query_size,
+			 "SELECT 'urn:ogc:def:crs:'||auth_name||'::'||auth_srid \
+			 srid);
+	err = SPI_exec(query, 1);
+	if (err < 0)
+		elog(NOTICE, "%s: error executing query %d", __func__, err);
+		SPI_finish();
+		return NULL;
+		SPI_finish();
+		return NULL;
+	/* get result  */
+	srs = SPI_getvalue(SPI_tuptable->vals[0], SPI_tuptable->tupdesc, 1);
+	/* NULL result */
+	if (!srs)
+		SPI_finish();
+		return NULL;
+	size = strlen(srs) + 1;
+	srscopy = MemoryContextAllocZero(PostgisCacheContext(fcinfo), size);
+	memcpy(srscopy, srs, size);
+	/* disconnect from SPI */
+	SPI_finish();
+	return srscopy;
+static inline SRSDescCache *
+SRSDescCacheGet(FunctionCallInfo fcinfo)
+	const uint32_t entry_number = SRSDESC_CACHE_ENTRY;
+	SRSDescCache *cache = (SRSDescCache *)(generic_cache->entry[entry_number]);
+	if (!cache)
+		cache = MemoryContextAllocZero(PostgisCacheContext(fcinfo), sizeof(SRSDescCache));
+	return cache;
+const char *
+GetSRSCacheBySRID(FunctionCallInfo fcinfo, int32_t srid, bool short_crs)
+	SRSDescCache *cache = SRSDescCacheGet(fcinfo);
+	SRSDescCacheArgument *arg = &(cache->arg[0]);
+	if (arg->srid != srid || arg->short_mode != short_crs || !arg->srs)
+		arg->srid = srid;
+		arg->short_mode = short_crs;
+		if (arg->srs)
+			pfree(arg->srs);
+		arg->srs = getSRSbySRID(fcinfo, srid, short_crs);
+	return arg->srs;
index 4bdd310..77ab5bd 100644
@@ -27,6 +27,7 @@
 #define CIRC_CACHE_ENTRY 3
+#define SRSDESC_CACHE_ENTRY 6
@@ -132,5 +133,20 @@ typedef struct
 GSERIALIZED* ToastCacheGetGeometry(FunctionCallInfo fcinfo, uint32_t argnum);
+#define SRSDescCacheSize 1
+typedef struct {
+	int32_t srid;
+	bool short_mode;
+	char *srs;
+} SRSDescCacheArgument;
+typedef struct {
+	int type;
+	SRSDescCacheArgument arg[SRSDescCacheSize];
+} SRSDescCache;
+const char *GetSRSCacheBySRID(FunctionCallInfo fcinfo, int32_t srid, bool short_crs);
index 8db14c8..44dec05 100644
@@ -39,6 +39,7 @@
@@ -206,7 +207,7 @@ Datum geography_as_gml(PG_FUNCTION_ARGS)
 	GSERIALIZED *g = NULL;
 	lwvarlena_t *v;
 	int version;
-	char *srs;
+	const char *srs;
 	int32_t srid = SRID_DEFAULT;
 	int option = 0;
@@ -283,9 +284,9 @@ Datum geography_as_gml(PG_FUNCTION_ARGS)
 	if (option & 1)
-		srs = getSRSbySRID(fcinfo, srid, false);
+		srs = GetSRSCacheBySRID(fcinfo, srid, false);
 	else
-		srs = getSRSbySRID(fcinfo, srid, true);
+		srs = GetSRSCacheBySRID(fcinfo, srid, true);
 	if (!srs)
 		elog(ERROR, "SRID %d unknown in spatial_ref_sys table", SRID_DEFAULT);
@@ -397,7 +398,7 @@ Datum geography_as_geojson(PG_FUNCTION_ARGS)
 	lwvarlena_t *geojson;
 	int has_bbox = 0;
-	char * srs = NULL;
+	const char *srs = NULL;
 	GSERIALIZED *g = PG_GETARG_GSERIALIZED_P(0);
 	int precision = PG_GETARG_INT32(1);
 	int option = PG_GETARG_INT32(2);
@@ -419,9 +420,9 @@ Datum geography_as_geojson(PG_FUNCTION_ARGS)
 		/* Geography only handle srid SRID_DEFAULT */
 		if (option & 2)
-			srs = getSRSbySRID(fcinfo, SRID_DEFAULT, true);
+			srs = GetSRSCacheBySRID(fcinfo, SRID_DEFAULT, true);
 		if (option & 4)
-			srs = getSRSbySRID(fcinfo, SRID_DEFAULT, false);
+			srs = GetSRSCacheBySRID(fcinfo, SRID_DEFAULT, false);
 		if (!srs)
@@ -435,7 +436,6 @@ Datum geography_as_geojson(PG_FUNCTION_ARGS)
 	geojson = lwgeom_to_geojson(lwgeom, srs, precision, has_bbox);
 	lwgeom_free(lwgeom);
 	PG_FREE_IF_COPY(g, 0);
-	if (srs) pfree(srs);
 	PG_RETURN_TEXT_P(geojson);
index 585dcce..22eb58f 100644
@@ -37,6 +37,7 @@
@@ -51,81 +52,6 @@ Datum geometry_to_json(PG_FUNCTION_ARGS);
- * Retrieve an SRS from a given SRID
- * Require valid spatial_ref_sys table entry
- * Could return SRS as short one (i.e EPSG:4326)
- * or as long one: (i.e urn:ogc:def:crs:EPSG::4326)
-char *
-getSRSbySRID(FunctionCallInfo fcinfo, int32_t srid, bool short_crs)
-	static const uint16_t max_query_size = 512;
-	char query[512];
-	char *srs, *srscopy;
-	int size, err;
-	if (SPI_OK_CONNECT != SPI_connect ())
-		elog(NOTICE, "getSRSbySRID: could not connect to SPI manager");
-		SPI_finish();
-		return NULL;
-	if (short_crs)
-		snprintf(query,
-			 max_query_size,
-			 "SELECT auth_name||':'||auth_srid \
-		        FROM %s WHERE srid='%d'",
-			 postgis_spatial_ref_sys(),
-			 srid);
-	else
-		snprintf(query,
-			 max_query_size,
-			 "SELECT 'urn:ogc:def:crs:'||auth_name||'::'||auth_srid \
-			 srid);
-	err = SPI_exec(query, 1);
-	if ( err < 0 )
-		elog(NOTICE, "getSRSbySRID: error executing query %d", err);
-		SPI_finish();
-		return NULL;
-		SPI_finish();
-		return NULL;
-	/* get result  */
-	srs = SPI_getvalue(SPI_tuptable->vals[0], SPI_tuptable->tupdesc, 1);
-	/* NULL result */
-	if ( ! srs )
-		SPI_finish();
-		return NULL;
-	/* copy result to upper executor context */
-	size = strlen(srs)+1;
-	srscopy = SPI_palloc(size);
-	memcpy(srscopy, srs, size);
-	/* disconnect from SPI */
-	SPI_finish();
-	return srscopy;
@@ -207,7 +133,7 @@ Datum LWGEOM_asGML(PG_FUNCTION_ARGS)
 	LWGEOM *lwgeom;
 	lwvarlena_t *v = NULL;
 	int version;
-	char *srs;
+	const char *srs;
 	int32_t srid;
 	int option = 0;
 	int lwopts = LW_GML_IS_DIMS;
@@ -286,9 +212,9 @@ Datum LWGEOM_asGML(PG_FUNCTION_ARGS)
 	else
 	if (option & 2) lwopts &= ~LW_GML_IS_DIMS;
 	if (option & 4) lwopts |= LW_GML_SHORTLINE;
@@ -334,13 +260,12 @@ Datum LWGEOM_asGeoJson(PG_FUNCTION_ARGS)
 	GSERIALIZED *geom;
 	LWGEOM *lwgeom;
-	lwvarlena_t *geojson;
 	int output_bbox = LW_FALSE;
 	int output_long_crs = LW_FALSE;
 	int output_short_crs = LW_FALSE;
 	int output_guess_short_srid = LW_FALSE;
-	char *srs = NULL;
 	int32_t srid;
 	/* Get the geometry */
@@ -383,7 +308,7 @@ Datum LWGEOM_asGeoJson(PG_FUNCTION_ARGS)
 	if (srid != SRID_UNKNOWN && (output_short_crs || output_long_crs))
-		srs = getSRSbySRID(fcinfo, srid, !output_long_crs);
+		srs = GetSRSCacheBySRID(fcinfo, srid, !output_long_crs);
 		if (!srs)
@@ -393,13 +318,7 @@ Datum LWGEOM_asGeoJson(PG_FUNCTION_ARGS)
-	geojson = lwgeom_to_geojson(lwgeom, srs, precision, output_bbox);
-	lwgeom_free(lwgeom);
-	PG_FREE_IF_COPY(geom, 0);
-	PG_RETURN_TEXT_P(geojson);
+	PG_RETURN_TEXT_P(lwgeom_to_geojson(lwgeom, srs, precision, output_bbox));
@@ -469,7 +388,7 @@ Datum LWGEOM_asX3D(PG_FUNCTION_ARGS)
 	GSERIALIZED *geom;
 	LWGEOM *lwgeom;
 	int version;
-	char *srs;
+	const char *srs;
 	int32_t srid;
 	int option = 0;
@@ -531,9 +450,9 @@ Datum LWGEOM_asX3D(PG_FUNCTION_ARGS)
 	else
 		if (srid != 4326) {
index b5de2ba..cd803e4 100644
+++ b/postgis/lwgeom_export.h
@@ -22,5 +22,4 @@
-char *getSRSbySRID(FunctionCallInfo fcinfo, int32_t SRID, bool short_crs);
Summary of changes:
 NEWS                         |   1 +
 liblwgeom/cunit/cu_out_x3d.c |  34 +++----
 liblwgeom/liblwgeom.h.in     |   4 +-
 liblwgeom/lwout_geojson.c    |  70 +++++++-------
 liblwgeom/lwout_x3d.c        |  84 +++++++++--------
 liblwgeom/lwout_x3d.h        |  18 ++--
 libpgcommon/lwgeom_cache.c   | 212 +++++++++++++++++++++++++++++++++++++++++++
 libpgcommon/lwgeom_cache.h   |  32 +++++++
 postgis/geography_inout.c    |  15 ++-
 postgis/gserialized_typmod.c |   1 -
 postgis/lwgeom_export.c      | 183 ++-----------------------------------
 postgis/lwgeom_export.h      |  26 ------
 postgis/lwgeom_in_geohash.c  |   1 -
 postgis/lwgeom_in_geojson.c  |   4 +-
 postgis/lwgeom_inout.c       |   4 +-
 15 files changed, 377 insertions(+), 312 deletions(-)
 delete mode 100644 postgis/lwgeom_export.h
hooks/post-receive
