[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-100-g39adc44
Fri May 1 08:00:13 PDT 2020
the project "PostGIS".
       via  39adc44a3f4ecdd4200e5bccf6dec429eeb39cf9 (commit)
       via  83c62dbf8fedcaf16ccecd416922345184fc7a67 (commit)
      from  07ca520a78c4c12fe94c5f0541887b4a15eeca16 (commit)
revisions in full, below.
commit 39adc44a3f4ecdd4200e5bccf6dec429eeb39cf9
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri May 1 14:47:41 2020 +0200
    Optimize geometry_to_point
    References #4676
diff --git a/NEWS b/NEWS
index 9da2c0a..e893b8e 100644
--- a/NEWS
+++ b/NEWS
@@ -15,6 +15,7 @@ Only tickets not included in 3.1.0alpha1
   - #4490, Tweak function costs (Raúl Marín)
   - #4672, Cache getSRSbySRID and getSRIDbySRS (Raúl Marín)
   - #4676, Avoid decompressing toasted geometries to read only the header (Raúl Marín)
+           Optimize cast to Postgresql point type (Raúl Marín)
 * Bug fixes *
   - #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
diff --git a/postgis/geometry_inout.c b/postgis/geometry_inout.c
index c5c2561..c1622c5 100644
--- a/postgis/geometry_inout.c
+++ b/postgis/geometry_inout.c
@@ -72,33 +72,22 @@ PG_FUNCTION_INFO_V1(geometry_to_point);
 Datum geometry_to_point(PG_FUNCTION_ARGS)
 	Point *point;
-	LWGEOM *lwgeom;
-	LWPOINT *lwpoint;
+	POINT4D pt;
 	GSERIALIZED *geom;
-	POSTGIS_DEBUG(2, "geometry_to_point called");
-	if ( PG_ARGISNULL(0) )
+	if (PG_ARGISNULL(0))
 		PG_RETURN_NULL();
 	geom = PG_GETARG_GSERIALIZED_P(0);
-	if ( gserialized_get_type(geom) != POINTTYPE )
+	if (gserialized_get_type(geom) != POINTTYPE)
 		elog(ERROR, "geometry_to_point only accepts Points");
-	lwgeom = lwgeom_from_gserialized(geom);
-	if ( lwgeom_is_empty(lwgeom) )
+	if (gserialized_peek_first_point(geom, &pt) == LW_FAILURE)
 		PG_RETURN_NULL();
-	lwpoint = lwgeom_as_lwpoint(lwgeom);
-	point = (Point*)palloc(sizeof(Point));
-	point->x = lwpoint_get_x(lwpoint);
-	point->y = lwpoint_get_y(lwpoint);
-	lwpoint_free(lwpoint);
-	PG_FREE_IF_COPY(geom,0);
+	point = (Point *)palloc(sizeof(Point));
+	point->x = pt.x;
+	point->y = pt.y;
 	PG_RETURN_POINT_P(point);
commit 83c62dbf8fedcaf16ccecd416922345184fc7a67
Date:   Fri May 1 12:36:10 2020 +0200
    Closes #4676
    Closes https://github.com/postgis/postgis/pull/558
index 4edb5b1..9da2c0a 100644
--- a/NEWS
+++ b/NEWS
@@ -14,6 +14,7 @@ Only tickets not included in 3.1.0alpha1
   - #4657: Avoid De-TOASTing where possible (Paul Ramsey)
+  - #4676, Avoid decompressing toasted geometries to read only the header (Raúl Marín)
 * Bug fixes *
diff --git a/libpgcommon/gserialized_gist.c b/libpgcommon/gserialized_gist.c
index c5cf7db..a1329ae 100644
--- a/libpgcommon/gserialized_gist.c
+++ b/libpgcommon/gserialized_gist.c
@@ -70,7 +70,7 @@ GIDX* gidx_new(int ndims)
 static lwflags_t
 gserialized_datum_get_flags(Datum gsdatum)
-	GSERIALIZED *gpart = (GSERIALIZED*)PG_DETOAST_DATUM_SLICE(gsdatum, 0, 40);
+	GSERIALIZED *gpart = (GSERIALIZED *)PG_DETOAST_DATUM_SLICE(gsdatum, 0, gserialized_max_header_size());
 	return gserialized_get_lwflags(gpart);
@@ -182,7 +182,7 @@ gserialized_datum_get_gidx_p(Datum gsdatum, GIDX *gidx)
 	** of floats necessary to hold the 8 floats of the largest XYZM index
 	** bounding box, so 40 bytes.
-	gpart = (GSERIALIZED*)PG_DETOAST_DATUM_SLICE(gsdatum, 0, 40);
+	gpart = (GSERIALIZED *)PG_DETOAST_DATUM_SLICE(gsdatum, 0, gserialized_max_header_size());
 	/* Do we even have a serialized bounding box? */
 	if (gserialized_has_bbox(gpart))
@@ -212,19 +212,24 @@ gserialized_datum_get_gidx_p(Datum gsdatum, GIDX *gidx)
 	else
 		/* No, we need to calculate it from the full object. */
-		GSERIALIZED *g = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
-		LWGEOM *lwgeom = lwgeom_from_gserialized(g);
+		LWGEOM *lwgeom;
 		GBOX gbox;
+		/* If we haven't, read the whole gserialized object */
+		if (LWSIZE_GET(gpart->size) >= gserialized_max_header_size())
+			POSTGIS_FREE_IF_COPY_P(gpart, gsdatum);
+			gpart = (GSERIALIZED *)PG_DETOAST_DATUM(gsdatum);
+		lwgeom = lwgeom_from_gserialized(gpart);
 		if (lwgeom_calculate_gbox(lwgeom, &gbox) == LW_FAILURE)
 			POSTGIS_DEBUG(4, "could not calculate bbox, returning failure");
 			lwgeom_free(lwgeom);
-			POSTGIS_FREE_IF_COPY_P(g, gsdatum);
 			return LW_FAILURE;
 		gidx_from_gbox_p(gbox, gidx);
diff --git a/libpgcommon/lwgeom_pg.h b/libpgcommon/lwgeom_pg.h
index 2009eff..64e35ae 100644
--- a/libpgcommon/lwgeom_pg.h
+++ b/libpgcommon/lwgeom_pg.h
@@ -90,6 +90,8 @@ void pg_install_lwgeom_handlers(void);
 #define PG_GETARG_GSERIALIZED_P(varno) ((GSERIALIZED *)PG_DETOAST_DATUM(PG_GETARG_DATUM(varno)))
 #define PG_GETARG_GSERIALIZED_P_COPY(varno) ((GSERIALIZED *)PG_DETOAST_DATUM_COPY(PG_GETARG_DATUM(varno)))
 #define PG_GETARG_GSERIALIZED_P_SLICE(varno, start, size) ((GSERIALIZED *)PG_DETOAST_DATUM_SLICE(PG_GETARG_DATUM(varno), start, size))
+#define PG_GETARG_GSERIALIZED_HEADER(varno) \
+	((GSERIALIZED *)PG_DETOAST_DATUM_SLICE(PG_GETARG_DATUM(varno), 0, gserialized_max_header_size()))
 /* Debugging macros */
 #if POSTGIS_DEBUG_LEVEL > 0
diff --git a/postgis/gserialized_gist_2d.c b/postgis/gserialized_gist_2d.c
index 086aa22..b6ce9a5 100644
--- a/postgis/gserialized_gist_2d.c
+++ b/postgis/gserialized_gist_2d.c
@@ -464,7 +464,7 @@ gserialized_datum_get_box2df_p(Datum gsdatum, BOX2DF *box2df)
 	** (though we still need to fully retrieve it from TOAST)
 	** which makes slicing worthwhile.
-	gpart = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
 	POSTGIS_DEBUGF(4, "got flags %d", gpart->gflags);
@@ -485,6 +485,13 @@ gserialized_datum_get_box2df_p(Datum gsdatum, BOX2DF *box2df)
 		GBOX gbox;
 		gbox_init(&gbox);
 		result = gserialized_get_gbox_p(gpart, &gbox);
 		if ( result == LW_SUCCESS )
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index e955d0c..8ed3302 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -1963,7 +1963,7 @@ Datum ST_Normalize(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(LWGEOM_zmflag);
 Datum LWGEOM_zmflag(PG_FUNCTION_ARGS)
-	GSERIALIZED *in = PG_GETARG_GSERIALIZED_P(0);
+	GSERIALIZED *in = PG_GETARG_GSERIALIZED_HEADER(0);
 	int ret = 0;
 	if (gserialized_has_z(in))
@@ -1977,21 +1977,21 @@ Datum LWGEOM_zmflag(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(LWGEOM_hasz);
 Datum LWGEOM_hasz(PG_FUNCTION_ARGS)
 	PG_RETURN_BOOL(gserialized_has_z(in));
 PG_FUNCTION_INFO_V1(LWGEOM_hasm);
 Datum LWGEOM_hasm(PG_FUNCTION_ARGS)
 	PG_RETURN_BOOL(gserialized_has_m(in));
 PG_FUNCTION_INFO_V1(LWGEOM_hasBBOX);
 Datum LWGEOM_hasBBOX(PG_FUNCTION_ARGS)
 	char res = gserialized_has_bbox(in);
 	PG_FREE_IF_COPY(in, 0);
 	PG_RETURN_BOOL(res);
@@ -2001,7 +2001,7 @@ Datum LWGEOM_hasBBOX(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(LWGEOM_ndims);
 Datum LWGEOM_ndims(PG_FUNCTION_ARGS)
 	int ret = gserialized_ndims(in);
 	PG_RETURN_INT16(ret);
@@ -2143,17 +2143,8 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(ST_IsCollection);
 Datum ST_IsCollection(PG_FUNCTION_ARGS)
-	GSERIALIZED *geom;
-	int type;
-	size_t size;
-	/* Pull only a small amount of the tuple, enough to get the type. */
-	/* header + srid/flags + bbox? + type number */
-	size = VARHDRSZ + 8 + 32 + 4;
-	geom = PG_GETARG_GSERIALIZED_P_SLICE(0, 0, size);
-	type = gserialized_get_type(geom);
+	GSERIALIZED *geom = PG_GETARG_GSERIALIZED_HEADER(0);
+	int type = gserialized_get_type(geom);
 	PG_RETURN_BOOL(lwtype_is_collection(type));
diff --git a/postgis/lwgeom_ogc.c b/postgis/lwgeom_ogc.c
index 3898432..6b692b8 100644
--- a/postgis/lwgeom_ogc.c
+++ b/postgis/lwgeom_ogc.c
@@ -95,7 +95,7 @@ Datum LWGEOM_isclosed(PG_FUNCTION_ARGS);
 PG_FUNCTION_INFO_V1(LWGEOM_get_srid);
 Datum LWGEOM_get_srid(PG_FUNCTION_ARGS)
-	GSERIALIZED *geom=PG_GETARG_GSERIALIZED_P(0);
 	int32_t srid = gserialized_get_srid(geom);
 	PG_RETURN_INT32(srid);
@@ -121,7 +121,7 @@ Datum LWGEOM_getTYPE(PG_FUNCTION_ARGS)
 	uint8_t type;
 	static int maxtyplen = 20;
-	gser = PG_GETARG_GSERIALIZED_P_SLICE(0, 0, gserialized_max_header_size());
+	gser = PG_GETARG_GSERIALIZED_HEADER(0);
 	text_ob = palloc0(VARHDRSZ + maxtyplen);
 	result = VARDATA(text_ob);
@@ -196,7 +196,7 @@ Datum geometry_geometrytype(PG_FUNCTION_ARGS)
 	text *type_text;
 	/* Read just the header from the toasted tuple */
 	/* Build a text type to store things in */
 	type_text = cstring_to_text(stTypeName[gserialized_get_type(gser)]);
Summary of changes:
 NEWS                             |  2 ++
 libpgcommon/gserialized_gist.c   | 17 +++++++++++------
 libpgcommon/lwgeom_pg.h          |  2 ++
 postgis/geometry_inout.c         | 25 +++++++------------------
 postgis/gserialized_gist_2d.c    |  9 ++++++++-
 postgis/lwgeom_functions_basic.c | 23 +++++++----------------
 postgis/lwgeom_ogc.c             |  6 +++---
 7 files changed, 40 insertions(+), 44 deletions(-)
hooks/post-receive
