[postgis-tickets] [PostGIS] #4676: Use PG_GETARG_GSERIALIZED_P_SLICE to access geometry headers
PostGIS trac at osgeo.org
Fri May 1 08:00:19 PDT 2020
  Reporter:  Raúl Marín   |      Owner:  pramsey
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 3.1.0
 Component:  postgis      |    Version:  master
Resolution:  fixed        |   Keywords:
Changes (by Raúl Marín <git@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"83c62dbf8fedcaf16ccecd416922345184fc7a67/git" 83c62db/git]:
 #!CommitTicketReference repository="git"
 revision="83c62dbf8fedcaf16ccecd416922345184fc7a67"
 Avoid decompressing toasted geometries to read only the header
 Closes #4676
 Closes https://github.com/postgis/postgis/pull/558
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4676#comment:2>
