[postgis-tickets] [PostGIS] #4679: rt_gdalwarp test fails with PROJ 7.0.1
PostGIS trac at osgeo.org
Sun May 3 06:30:34 PDT 2020
 Reporter:  Bas Couwenberg  |      Owner:  pramsey
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 3.0.2
Component:  postgis         |    Version:  3.0.x
 Keywords:                  |
 As reported by Lucas Nussbaum in [https://bugs.debian.org/959563 Debian
 Bug #959563]:
 > During a rebuild of all packages in sid, your package failed to build
 > on amd64.
 > Relevant part (hopefully):
 > make[9]: Entering directory '/<<PKGBUILDDIR>>/doc'
 > /bin/mkdir -p '/<<PKGBUILDDIR>>/regress/00-regress-
 install/share/contrib/postgis'
 > /usr/bin/install -c -m 644  postgis_comments.sql raster_comments.sql
 topology_comments.sql sfcgal_comments.sql '/<<PKGBUILDDIR>>/regress/00
 -regress-install/share/contrib/postgis/'
 > make[9]: Leaving directory '/<<PKGBUILDDIR>>/doc'
 > make[8]: Leaving directory '/<<PKGBUILDDIR>>/doc'
 > make[7]: Leaving directory '/<<PKGBUILDDIR>>'
 > /usr/bin/perl -pi -e 's,\$libdir,/<<PKGBUILDDIR>>/regress/00-regress-
 install/lib,g' /<<PKGBUILDDIR>>/regress/00-regress-
 install/share/contrib/postgis/*.sql
 > #make -C ../loader REGRESS=1 DESTDIR=/<<PKGBUILDDIR>>/regress/00
 -regress-install install
 > make[6]: Leaving directory '/<<PKGBUILDDIR>>/regress'
 > /usr/bin/perl ../../../regress/run_test.pl --raster -v check_gdal
 load_outdb check_raster_columns check_raster_overviews rt_io rt_bytea
 rt_wkb box3d rt_addband rt_band rt_tile rt_dimensions rt_scale
 rt_pixelsize rt_upperleft rt_rotation rt_georeference rt_set_properties
 rt_isempty rt_hasnoband rt_metadata rt_rastertoworldcoord
 rt_worldtorastercoord rt_convexhull rt_envelope rt_band_properties
 rt_set_band_properties rt_pixelaspolygons rt_pixelaspoints
 rt_pixelascentroids rt_setvalues_array rt_summarystats rt_count
 rt_histogram rt_quantile rt_valuecount rt_valuepercent rt_bandmetadata
 rt_pixelvalue rt_neighborhood rt_nearestvalue rt_pixelofvalue rt_polygon
 rt_setbandpath rt_utility rt_fromgdalraster rt_asgdalraster rt_astiff
 rt_asjpeg rt_aspng rt_reclass rt_gdalwarp rt_asraster rt_dumpvalues
 rt_makeemptycoverage rt_createoverview rt_mapalgebraexpr rt_mapalgebrafct
 rt_mapalgebraexpr_2raster rt_mapalgebrafct_2raster rt_mapalgebrafctngb
 rt_mapalgebrafctngb_userfunc rt_intersection rt_clip rt_mapalgebra
 rt_mapalgebra_expr rt_mapalgebra_mask rt_union rt_invdistweight4ma rt_4ma
 rt_setvalues_geomval rt_elevation_functions rt_colormap rt_grayscale
 rt_gist_relationships rt_intersects rt_samealignment rt_geos_relationships
 rt_iscoveragetile bug_test_car5 permitted_gdal_drivers tickets
 loader/Basic loader/Projected loader/BasicCopy loader/BasicFilename
 loader/BasicOutDB loader/Tiled10x10 loader/Tiled10x10Copy loader/Tiled8x8
 loader/TiledAuto loader/TiledAutoSkipNoData clean
 > PATH is
 /usr/lib/postgresql/12/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
 > Checking for shp2pgsql ... found
 > Checking for pgsql2shp ... found
 > Checking for raster2pgsql ... found
 > TMPDIR is /tmp/pgis_reg
 > Creating database 'postgis_reg'
 > Loading unpackaged components from /<<PKGBUILDDIR>>/regress/00-regress-
 > Loading PostGIS into 'postgis_reg'
 install/share/contrib/postgis/postgis.sql
 install/share/contrib/postgis/postgis_comments.sql
 install/share/contrib/postgis/postgis_proc_set_search_path.sql
 install/share/contrib/postgis/spatial_ref_sys.sql
 > Loading Raster into 'postgis_reg'
 install/share/contrib/postgis/rtpostgis.sql
 install/share/contrib/postgis/raster_comments.sql
 install/share/contrib/postgis/rtpostgis_proc_set_search_path.sql
 > PostgreSQL 12.2 (Debian 12.2-4) on x86_64-pc-linux-gnu, compiled by gcc
 (Debian 9.3.0-8) 9.3.0, 64-bit
 >   Postgis 3.0.1 - rec2a9aa - 2020-04-17 19:21:56
 >   scripts 3.0.1 ec2a9aa
 >   raster scripts 3.0.1 ec2a9aa
 >   GEOS: 3.8.1-CAPI-1.13.3
 >   PROJ: 7.0.1
 >   GDAL: GDAL 3.0.4, released 2020/01/28
 > Running tests
 >  check_gdal .. ok
 >  load_outdb ... ok
 >  check_raster_columns .. ok
 >  check_raster_overviews .. ok
 >  rt_io .. ok
 >  rt_bytea .. ok
 >  rt_wkb .. ok
 >  box3d .. ok
 >  rt_addband .. ok
 >  rt_band .. ok
 >  rt_tile .. ok
 >  rt_dimensions .. ok
 >  rt_scale .. ok
 >  rt_pixelsize .. ok
 >  rt_upperleft .. ok
 >  rt_rotation .. ok
 >  rt_georeference .. ok
 >  rt_set_properties .. ok
 >  rt_isempty .. ok
 >  rt_hasnoband .. ok
 >  rt_metadata .. ok
 >  rt_rastertoworldcoord .. ok
 >  rt_worldtorastercoord .. ok
 >  rt_convexhull .. ok
 >  rt_envelope .. ok
 >  rt_band_properties .. ok
 >  rt_set_band_properties .. ok
 >  rt_pixelaspolygons .. ok
 >  rt_pixelaspoints .. ok
 >  rt_pixelascentroids .. ok
 >  rt_setvalues_array .. ok
 >  rt_summarystats .. ok
 >  rt_count .. ok
 >  rt_histogram .. ok
 >  rt_quantile .. ok
 >  rt_valuecount .. ok
 >  rt_valuepercent .. ok
 >  rt_bandmetadata .. ok
 >  rt_pixelvalue .. ok
 >  rt_neighborhood .. ok
 >  rt_nearestvalue .. ok
 >  rt_pixelofvalue .. ok
 >  rt_polygon .. ok
 >  rt_setbandpath .. ok
 >  rt_utility .. ok
 >  rt_fromgdalraster .. ok
 >  rt_asgdalraster .. ok
 >  rt_astiff .. ok
 >  rt_asjpeg .. ok
 >  rt_aspng .. ok
 >  rt_reclass .. ok
 >  rt_gdalwarp .. failed (diff expected obtained:
 /tmp/pgis_reg/test_52_diff)
 > --- rt_gdalwarp_expected      2020-02-22 18:58:19.000000000 +0000
 > +++ /tmp/pgis_reg/test_52_out 2020-05-03 04:04:54.949842372 +0000
 > @@ -8,28 +8,28 @@
 >  NOTICE:  Values must be provided for both X and Y when specifying the
 scale.  Returning original raster
 >  0.0|||||||||||||
 -0.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 +0.1|993310|12|12|1|1007.902|-1007.902|0.000|0.000|952292.007|1409727.921|t|t|t
 0.10|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.11|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 0.12|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600009.000|t|t|t
 0.13|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500100.000|600950.000|t|t|t
 0.14|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
 0.15|992163|84|84|1|121.000|121.000|0.000|0.000|-500093.000|589875.000|t|t|t
 -0.16|993310|243|243|1|50.000|50.000|0.000|0.000|950710.000|1397157.000|t|t|t
 -0.17|993310|243|243|1|50.000|50.000|0.000|0.000|950710.000|1397157.000|t|t|t
 +0.16|993310|243|243|1|50.000|50.000|0.000|0.000|952260.000|1397607.000|t|t|t
 +0.17|993310|243|243|1|50.000|50.000|0.000|0.000|952260.000|1397607.000|t|t|t
 0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
 -0.19|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
 -0.2|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -0.20|993310|12|12|1|1009.894|-1009.894|1.000|3.000|950711.990|1409281.783|t|t|t
 -0.21|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
 -0.22|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
 > -0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 > -0.24|974269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 +0.19|993310|12|12|1|1007.902|-1007.902|3.000|3.000|952251.690|1409727.921|t|t|t
 +0.2|993310|12|12|1|1007.902|-1007.902|0.000|0.000|952292.007|1409727.921|t|t|t
 +0.20|993310|12|12|1|1007.902|-1007.902|1.000|3.000|952271.849|1409727.921|t|t|t
 +0.21|993310|24|24|1|500.000|500.000|3.000|3.000|952217.007|1397802.921|t|t|t
 +0.22|993310|25|25|1|500.000|500.000|0.000|6.000|951952.000|1397614.000|t|t|t
 > +0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.007|50.208|t|t|t
 > +0.24|974269|12|8|1|0.012|-0.012|0.000|0.000|-107.007|50.208|t|t|t
 >  0.25|0|5|5|1|2.000|-2.000|0.000|0.000|0.000|0.000|t|t|t
 >  0.26|0|2|2|1|5.000|-5.000|0.000|0.000|0.000|0.000|t|t|t
 >  0.27|0|100|100|1|0.100|-0.100|0.000|0.000|0.000|0.000|t|t|t
 > -0.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 -0.4|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 > +0.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.007|50.208|t|t|t
 +0.4|993310|24|24|1|500.000|500.000|0.000|0.000|952292.007|1397727.921|t|t|t
 0.5|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.6|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.7|992163|20|20|1|500.000|500.000|0.000|0.000|-500000.000|590000.000|t|t|t
 > @@ -61,21 +61,21 @@
 1.7|992163|40|40|1|250.000|250.000|0.000|0.000|-500000.000|590000.000|t|t|t
 1.8|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 1.9|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 -2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.11|993310|121|121|1|100.000|100.000|0.000|0.000|950732.188|1397181.783|t|t|t
 -2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.2|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 > -2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 +2.1|993310|12|12|1|1007.902|-1007.902|0.000|0.000|952292.007|1409727.921|t|t|t
 +2.10|993310|24|24|1|500.000|500.000|0.000|0.000|952292.007|1397727.921|t|t|t
 +2.11|993310|121|121|1|100.000|100.000|0.000|0.000|952292.007|1397627.921|t|t|t
 +2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|952292.007|1397727.921|t|t|t
 +2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|952292.007|1397727.921|t|t|t
 +2.14|993310|24|24|1|500.000|500.000|0.000|0.000|952292.007|1397727.921|t|t|t
 +2.15|993310|16|16|1|750.000|750.000|0.000|0.000|952292.007|1397727.921|t|t|t
 +2.2|993310|12|12|1|1007.902|-1007.902|0.000|0.000|952292.007|1409727.921|t|t|t
 > +2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.007|50.208|t|t|t
 >  2.4|||||||||||||
 -2.5|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 +2.5|993310|12|12|1|1007.902|-1007.902|0.000|0.000|952292.007|1409727.921|t|t|t
 >  2.6|||||||||||||
 -2.7|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.8|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.9|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 +2.7|993310|12|12|1|1007.902|-1007.902|0.000|0.000|952292.007|1409727.921|t|t|t
 +2.8|993310|12|12|1|1007.902|-1007.902|0.000|0.000|952292.007|1409727.921|t|t|t
 +2.9|993310|12|12|1|1007.902|-1007.902|0.000|0.000|952292.007|1409727.921|t|t|t
 3.1|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
 3.2|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
 3.3|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 >  rt_asraster .. ok
 >  rt_dumpvalues .. ok
 >  rt_makeemptycoverage .. ok
 >  rt_createoverview .. ok
 >  rt_mapalgebraexpr .. ok
 >  rt_mapalgebrafct .. ok
 >  rt_mapalgebraexpr_2raster .. ok
 >  rt_mapalgebrafct_2raster .. ok
 >  rt_mapalgebrafctngb .. ok
 >  rt_mapalgebrafctngb_userfunc .. ok
 >  rt_intersection .. ok
 >  rt_clip .. ok
 >  rt_mapalgebra .. ok
 >  rt_mapalgebra_expr .. ok
 >  rt_mapalgebra_mask .. ok
 >  rt_union .. ok
 >  rt_invdistweight4ma .. ok
 >  rt_4ma .. ok
 >  rt_setvalues_geomval .. ok
 >  rt_elevation_functions .. ok
 >  rt_colormap .. ok
 >  rt_grayscale .. ok
 >  rt_gist_relationships .. ok
 >  rt_intersects .. ok
 >  rt_samealignment .. ok
 >  rt_geos_relationships .. ok
 >  rt_iscoveragetile .. ok
 >  bug_test_car5 .. ok
 >  permitted_gdal_drivers .. ok
 >  tickets .. ok
 >  loader/Basic .... ok
 >  loader/Projected ..... ok
 >  loader/BasicCopy .... ok
 >  loader/BasicFilename .... ok
 >  loader/BasicOutDB .... ok
 >  loader/Tiled10x10 .... ok
 >  loader/Tiled10x10Copy .... ok
 >  loader/Tiled8x8 .... ok
 >  loader/TiledAuto .... ok
 >  loader/TiledAutoSkipNoData .... ok
 >  clean .. ok
 >  uninstall .  /<<PKGBUILDDIR>>/regress/00-regress-
 install/share/contrib/postgis/uninstall_rtpostgis.sql
 install/share/contrib/postgis/uninstall_postgis.sql
 > . ok (4725)
 > Run tests: 94
 > Failed: 1
 > make[5]: *** [Makefile:184: check] Error 1
 > The full build log is available from:
 >    http://qa-logs.debian.net/2020/05/01/postgis_3.0.1+dfsg-
 3_unstable.log
 You can't expect the exact same coordinates between PROJ versions, an
 acceptable margin needs to be applied for these kind of tests.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4679>
