[postgis-tickets] [PostGIS] #4674: lwgeom_cache doesn't live through not inline functions
PostGIS trac at osgeo.org
Mon May 4 02:46:58 PDT 2020
  Reporter:  Raúl Marín  |      Owner:  pramsey
      Type:  defect      |     Status:  reopened
  Priority:  medium      |  Milestone:  PostGIS 3.1.0
 Component:  postgis     |    Version:  master
Resolution:              |   Keywords:
Comment (by Raúl Marín):
 I tried reverting this change but it seems that `fcinfo->flinfo` might be
 NULL in some cases and it's crashing with the new geojson cache:
 (gdb) bt
 #0  0x00007f24776bda8a in GetGenericCacheCollection
 (fcinfo=0x7ffe6199df80) at lwgeom_cache.c:79
 #1  SRIDCacheGet (fcinfo=0x7ffe6199df80) at lwgeom_cache.c:506
 #2  GetSRIDCacheBySRS (fcinfo=0x7ffe6199df80, srs=0x558057f24260
 "EPSG:3005") at lwgeom_cache.c:520
 #3  0x00007f24776517fd in LWGEOM_in (fcinfo=0x7ffe6199df80) at
 lwgeom_inout.c:150
 #4  0x0000558056faab75 in DirectFunctionCall1Coll (func=0x7f2477651670
 <LWGEOM_in>, collation=1475494496, arg1=0) at fmgr.c:803
 #5  0x00007f247765257e in parse_WKT_lwgeom (fcinfo=0x558057eef4f0) at
 lwgeom_inout.c:662
 #6  0x0000558056cc350d in ExecInterpExpr (state=0x558057eef410,
 econtext=0x558057eef570, isnull=<optimized out>) at execExprInterp.c:649
 #7  0x0000558056d92a8e in ExecEvalExprSwitchContext (state=<optimized
 out>, econtext=0x558057f24260, isNull=0x7ffe6199e11f) at
 ../../../../src/include/executor/executor.h:307
 #8  evaluate_expr (expr=<optimized out>, result_type=10775331,
 result_typmod=-1, result_collation=0) at clauses.c:4812
 #9  0x0000558056d93664 in evaluate_function (funcid=10775691,
 result_type=10775331, result_typmod=-1, result_collid=0, input_collid=100,
 args=0x55805832d138, funcvariadic=<optimized out>, context=0x7ffe6199e660,
 func_tuple=<optimized out>)
     at clauses.c:4354
 #10 simplify_function (funcid=10775691, result_type=10775331,
 result_typmod=-1, result_collid=0, input_collid=100, args_p=<optimized
 out>, funcvariadic=<optimized out>, process_args=<optimized out>,
 allow_non_const=true, context=0x7ffe6199e660)
     at clauses.c:3984
 #11 0x0000558056d91864 in eval_const_expressions_mutator
 (node=0x558057e0a1b0, context=0x7ffe6199e660) at clauses.c:2477
 #12 0x0000558056d26b06 in expression_tree_mutator (node=<optimized out>,
 mutator=0x558056d90c30 <eval_const_expressions_mutator>,
 context=0x7ffe6199e660) at nodeFuncs.c:3012
 #13 0x0000558056d933e0 in simplify_function (funcid=10775573,
 result_type=25, result_typmod=-1, result_collid=100, input_collid=0,
 args_p=0x7ffe6199e470, funcvariadic=<optimized out>,
 process_args=<optimized out>, allow_non_const=<optimized out>,
     context=0x7ffe6199e660) at clauses.c:3975
 #14 0x0000558056d91864 in eval_const_expressions_mutator
 (node=0x55805832c5b8, context=0x7ffe6199e660) at clauses.c:2477
 #15 0x0000558056d26829 in expression_tree_mutator (node=0x55805832c608,
 context=0x7ffe6199e660) at nodeFuncs.c:2762
 #16 0x0000558056d90d4e in eval_const_expressions_mutator
 (node=0x55805832c608, context=0x7ffe6199e660) at clauses.c:3539
 #17 0x0000558056d26b06 in expression_tree_mutator (node=<optimized out>,
 #18 0x0000558056d90d4e in eval_const_expressions_mutator
 (node=0x558057e099d0, context=0x7ffe6199e660) at clauses.c:3539
 #19 0x0000558056d90c10 in eval_const_expressions (root=<optimized out>,
 node=0x0) at clauses.c:2269
 #20 0x0000558056d794ab in preprocess_expression (root=<optimized out>,
 expr=0x558057f24260, kind=1) at planner.c:1087
 #21 subquery_planner (glob=<optimized out>, parse=0x558057e09800,
 parent_root=<optimized out>, hasRecursion=<optimized out>,
 tuple_fraction=0) at planner.c:769
 #22 0x0000558056d78aaf in standard_planner (parse=0x558057e09800,
 cursorOptions=<optimized out>, boundParams=0x0) at planner.c:406
 #23 0x0000558056e51e60 in pg_plan_query (querytree=0x558057e09800,
 cursorOptions=256, boundParams=0x0) at postgres.c:878
 #24 pg_plan_queries (querytrees=<optimized out>, cursorOptions=256,
 boundParams=0x0) at postgres.c:968
 #25 0x0000558056e562b4 in exec_simple_query (query_string=0x558057e08500
 "SELECT 'cast2', ST_AsEWKT(st_asgeojson('SRID=3005;MULTIPOINT(1 1, 1
 1)'::geometry)::geometry);") at postgres.c:1143
 #26 0x0000558056e53d34 in PostgresMain (argc=<optimized out>,
 argv=<optimized out>, dbname=<optimized out>, username=<optimized out>) at
 postgres.c:4243
 #27 0x0000558056dc2ef7 in BackendRun (port=0x558057e2f5b0) at
 postmaster.c:4437
 #28 0x0000558056dc24df in BackendStartup (port=<optimized out>) at
 postmaster.c:4128
 #29 ServerLoop () at postmaster.c:1704
 #30 0x0000558056dbf036 in PostmasterMain (argc=3, argv=0x558057e02230) at
 postmaster.c:1377
 #31 0x0000558056d247d5 in main (argc=3, argv=0x558057e02230) at main.c:228
 (gdb) f 0
 79              GenericCacheCollection* cache = fcinfo->flinfo->fn_extra;
 (gdb) p *fcinfo
 $6 = {flinfo = 0x0, context = 0x0, resultinfo = 0x0, fncollation = 0,
 isnull = false, nargs = 1, args = 0x7ffe6199dfa0}
 It seems that DirectFunctionCall1 needs to be replaced by
 CallerFInfoFunctionCall1 to ensure `flinfo` is initialized.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4674#comment:7>
